1HD with OS4.1 Final (update1) + CDRom on on channel
and second HD with DVD Burner on second channel
after having replaced battery on the board I had to set again uBoot config,
but now there is no way I can boot again from SIL0680
I only succeed to boot from original IDE OS4.1 CD (update1 or Final)
I always get:
Bus 0 not available, Bus 1 not available
no SLB found in any of the designated boot sources
I have set:
sii0680ide_conf=1212
sii0680ide_xfer=GGGG
there were other commands to type,
what was the way to tell uBoot to scan SIL0680 devices instead of original IDEs ones ?
I have tried also from OS4.1 Final CDRom and uBoot prefs
setting as boot options
1. parallel sil CDRom
2. parallel sil HD
3. IDE Cdrom
with no chance
many thanks in advance for any help !!!!
