Youtube not working anymore with ArcticFox and SpiderWeb?
When I have lately tried to run videos from Youtube, there has been several problems...
Firstly, both ArcticFox and Spiderweb show this message when you go to Youtube:
"We’ll stop supporting this browser soon. For the best experience please update your browser."
What does this mean?
Secondly, ViewTube does not seem to work at all with ArcticFox! (Yes, it is activated from the Plugins menu and I have downloaded the last version from Sebaros site). The ViewTube user interphase is not shown at all when I open a vdeo...
Thirdly, though in Spiderweb the Viewtube interphase still appears, the videos has now wrong colors! Earlier this problem was corrected by Viewtube...
So, are are we out of Youtube from now on?
Re: Youtube not working anymore with ArcticFox and SpiderWeb?
Roland wrote: Tue Feb 04, 2020 5:19 pm Firstly, both ArcticFox and Spiderweb show this message when you go to Youtube:
I have the same error message on YouTube.
Roland wrote: Tue Feb 04, 2020 5:19 pm What does this mean?
Nothing currently.
Roland wrote: Tue Feb 04, 2020 5:19 pm Secondly, ViewTube does not seem to work at all with ArcticFox! (Yes, it is activated from the Plugins menu and I have downloaded the last version from Sebaros site). The ViewTube user interphase is not shown at all when I open a vdeo...
The latest version 2020.01.24 works on my Fienix installation.
Roland wrote: Tue Feb 04, 2020 5:19 pm Thirdly, though in Spiderweb the Viewtube interphase still appears, the videos has now wrong colors! Earlier this problem was corrected by Viewtube...
I have no wrong colors with ViewTube in SpiderWeb on Fienix. Did you install the ViewTube version from the following thread?
Link: YouTube videos in HD with ViewTube and SpiderWeb
xeno74 wrote: Wed Feb 05, 2020 12:44 am
That's what I have installed in ArcticFox/Fienix, too. I have two different versions of GreaseMonkey (the original one from Fienix Depot, and a newer one from Github), but the Youtube interphase does not appear with either of them. Could you please send the gm_scrips drawer you have installed in your ArcticFox? I could then see if the problem is there.
I think so, and when I now reinstalled the gm_scripts drawer from your link (with the old viewtube.user.js script from 2019), it had the right colors. But as soon as I replaced it with the 2020.01.24 viewtube.user.js which I copied from the link you gave, the colors got distorted! Is there something else than replacing that script that should be done...?
I was finally able to get the latest ViewTube script to work with ArcticFox, after some removal and reinstallation steps (don't quite understand what happened there...). But the 2020.01.24 is running videos slowly (probably too high default resolution or fps), so I had to go back to an older version.
The color problem with Spiderweb is still unresolved. And I checked that also Palemoon has the same 'blue' problem with that 2020.01.24!
How to fix this...?
Hi Roland,
Please post the output of glxinfo | grep -i opengl.
xeno74 wrote: Wed Feb 05, 2020 5:38 pm Please post the output of glxinfo | grep -i opengl.
Here you are:
OpenGL vendor string: X.Org
OpenGL renderer string: AMD CEDAR (DRM 2.50.0 / 5.5.0_A-EON_X5000, LLVM 9.0.1)
OpenGL core profile version string: 3.2 (Core Profile) Mesa 19.3.2
OpenGL core profile shading language version string: 1.50
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 3.1 Mesa 19.3.2
OpenGL shading language version string: 1.40
OpenGL context flags: (none)
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 2.0 Mesa 19.3.2
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 1.0.16
OpenGL ES profile extensions:
Roland,
OK, you can use hardware 3D acceleration. What about your VLC settings? (Menu Tools - Preferences - Video)
I currently use the OpenGL GLX video output (XCB). Additionally I use 'Accelerated video output (Overlay)'.
As input codec I use the 'VA-API video decoder via DRM' for hardware-accelerated decoding on my X5000 and X1000 (Menu Tools - Preferences - Input / Codecs).
caseycullen
Post by caseycullen »
YouTube was working perfectly for me yesterday; today it isn't. All my config seems to be fine. Could someone else verify whether or not they're able to use YouTube with VLC/Greasemonkey/ViewTube?
-Casey
caseycullen wrote: Sun Apr 12, 2020 2:04 am YouTube was working perfectly for me yesterday; today it isn't. All my config seems to be fine. Could someone else verify whether or not they're able to use YouTube with VLC/Greasemonkey/ViewTube?
-Casey
Hi Casey,
I have the same issue but I figured out, that an old ViewTube script still works. I successfully installed it in SpiderWeb yesterday.
Instructions:
  1. Start SpiderWeb and install the add-on greasemonkey-3.10.0.1rc3pre-sw.xpi (Download and then File - Open File... - greasemonkey-3.10.0.1rc3pre-sw.xpi)
  2. Restart SpiderWeb
  3. After that, download the ViewTube script
  4. Decompress the package and copy the folder gm_scripts to /home/<your user directory>/.wicknix/spiderweb/<profile directory>
    For example:
    cp -R gm_scripts /home/amigaone/.wicknix/spiderweb/xa4ue3g6.default/
  5. Restart SpiderWeb
Casey,
I figured out, that only InterWeb with ViewTube is affected with this issue. Arctic Fox with the latest ViewTube version and SpiderWeb with the old ViewTube version work without any problems.
