Filesize and filenames with brackets
daveyw
Post by daveyw »
Hi all,
I am currently working on an arexx script that uses filesize. However, I'm finding that, even with quotes, it doesn't like filenames with brackets.
For example,
filesize "SMBFS0:Temp/Avengers.Endgame.2019" format %L
results in "3,219,186,473".
However,
filesize "SMBFS0:Temp/Avengers.Endgame(2019)" format %L
results in nothing - in my script which does >T:FS1, the result is an empty file, and in a shell, the result is nothing returns.
Has anyone encountered this before? Is there a workaround?
Thanks for any info.
Re: Filesize and filenames with brackets
I'll just delete what I wrote as it is rubbish.
I see that testing such a file name in RAM: and an NGFS volume shows the same fault. I'll get Colin onto this...
Meantime, the file is stored on the volume with the right name (including the parentheses) and if you list the directory, the file appears.
I created a file in RAM:called "Avengers(2019)". If I "list RAM:, the file appears with its name intact, but you can't access it by name. You CAN access it by typing "type RAM:#?", so you may have some luck that way.
Post by thomasrapp »
Brackets are wildcard characters. The program will list the directory SMBFS0:Temp and find all files which match the wildcard pattern. In this case the only match would be a file called Avengers.Endgame2019. It does not exist, hence the output is empty.
If you need to use brackets in file names, you have to escape them with the ' charater.
This should work:
filesize "SMBFS0:Temp/Avengers.Endgame'(2019')" format %L
daveyw
Post by daveyw »
Thanks for the reply. This seems odd - it's not listed as a wildcard.
Since this is a script, I would need to write a function that searches the filename string character by character, and insert ' before every bracket?
BandiT
Post by BandiT »
thomasrapp wrote:Brackets are wildcard characters. The program will list the directory SMBFS0:Temp and find all files which match the wildcard pattern. In this case the only match would be a file called Avengers.Endgame2019. It does not exist, hence the output is empty.
This should work:
I have also noticed this when using the version command. On RadeonHD(3) for example, it wont return the version. Delete the (3) and it works fine on the same file.
Is that intended use?
Regards
Anthony
AmigaOne X1000, Boing Ball Fractal R3 white case, XFX Radeon 4890 XXX edition 1 GB, OCZ Vertex 3 SSD & 1TB Sata HD, AmigaOne Keyboard and
Boing Ball mouse (white), 4 GB Kingston HyperX RAM, Official DVD burner. CoolerMaster GX750, Realtek 8169 (Netgear GA311), BenQ 24" Widescreen.
daveyw wrote:Thanks for the reply. This seems odd - it's not listed as a wildcard.
https://wiki.amigaos.net/wiki/Pattern_Matching:
Parentheses group special characters. The expression within the parentheses is a subpattern."
It's probably technically wrong to call them wildcards, but they are interpreted as having a role in pattern matching before being seen as the parenthesis characters themselves.
In ARexx, you do have a few shortcuts over the simple looping over all characters - you can use pos() and overlay() etc., although you'd still have to loop until you don't find any more parentheses/end of string - but in pure ARexx there is unfortunately no direct function for replacing all occurrences of one character with a string of two. There is probably something in one of the helper libraries (rexxtools, rmh etc.), but I don't remember it specifically.
