SpiderWeb
SpiderWeb
SpiderWeb has been released for PowerPC Linux! :-)
Wart Hog Matt wrote: I've been a busy beaver. Here's another UXP based seamonkey-like browser and UXP based thunderbird-like mail/news/rss client for powerpc linux. More info here: https://github.com/wicknix/SpiderWeb/wiki/Download
I compiled SpiderWeb for old Linux distributions for example the A-EON Live Remix DVD and Ubuntu 12.04 or higher today.
It needs GCC 4.9 and the following patch:
--- a/js/src/jsmath.cpp
+++ b/js/src/jsmath.cpp
@@ -63,16 +63,29 @@
// Older glibc versions don't define SYS_getrandom, so we define it here
# if defined(__x86_64__)
# define GETRANDOM_NR 318
# elif defined(__i386__)
# define GETRANDOM_NR 355
# elif defined(__arm__)
# define GETRANDOM_NR 384
+// Added powerpc architecture:
+# elif defined(__powerpc__)
+# define GETRANDOM_NR 359
GCC 4.9 installation instructions for Ubuntu 12.04:
sudo add-apt-repository ppa:ubuntu-toolchain-r/test
sudo apt-get update; sudo apt-get install gcc-4.9 g++-4.9
update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-4.9 50
gcc -v
Output:
gcc version 4.9.4 (Ubuntu 4.9.4-2ubuntu1~12.04)
update-alternatives --install /usr/bin/g++ g++ /usr/bin/g++-4.9 50
g++ -v
After compiling with ./mach build you have to copy the icudt58b.dat to obj-powerpc-linux-gnu/dist/bin.
cd mozilla/config/external/icu/data/
cp icudt58b.dat ../../../../../obj-powerpc-linux-gnu/dist/bin
./mach run
./mach package
After that you need to add icudt58b.dat to the SpiderWeb compressed package as well.
Download: spiderweb-2.1.0-ubuntu_12.04-powerpc.tar.bz2
I successfully tested it on a Lubuntu 12.04.0 PowerPC Live DVD and on the A-EON Live Remix DVD today. You need to install the GCC 4.9 and the libatomic1 via the repository 'ppa:ubuntu-toolchain-r/test'.
Screenshots:
Re: SpiderWeb
YouTube videos in HD with ViewTube and SpiderWeb
Installation instructions for ubuntu MATE 16.04.6 PowerPC
  1. Install VLC and the VLC browser plugin with the following command:
    sudo apt-get install browser-plugin-vlc
  2. Start SpiderWeb and install the add-on greasemonkey-3.10.0.1rc3pre-sw.xpi (Download and then File - Open File... - greasemonkey-3.10.0.1rc3pre-sw.xpi)
  3. Restart SpiderWeb
  4. After that, download the ViewTube script
  5. Decompress the package and copy the folder gm_scripts to /home/<your user directory>/.wicknix/spiderweb/<profile directory>
    For example:
    cp -R gm_scripts /home/amigaone/.wicknix/spiderweb/xa4ue3g6.default/
  6. Restart SpiderWeb
  7. Then you have to activate the VLC plugin. You can activate it via Menu Tools - Add-ons Manager - Plugins.
Image Image
Re: SpiderWeb
I was able to compile SpiderWeb on Fedora PPC64 after the following commands today.
grep -r " -m32" *
:%s/-m32/-m64/g
Download: spiderweb-2.1.0.linux-powerpc64.tar.bz2
It could be, that you have to install some packages for example libffi7 for using SpiderWeb. I successfully tested it on Fedora 27 PPC64 and on openSUSE Tumbleweed 20190722 PPC64 today.
Screenshots:
Image Image
Re: SpiderWeb
Wicknix wrote: SpiderWeb 2.2.1 is now available for Ubuntu12/14 and Debian8.
Wicknix wrote:About: shows version 2.1.0 because i forgot to change version.txt before building. It is however built with the latest UXP code base.
Download: spiderweb-2.2.1.ubu12deb8.linux-powerpc.deb
Re: SpiderWeb
I compiled SpiderWeb 2.2.1 for Linux PPC64 yesterday.
Download: spiderweb-2.2.1.linux-powerpc64.tar.bz2
Support thread: forums.macrumors.com
Re: SpiderWeb
SpiderWeb 2.2.2 is now available
Wicknix wrote: Over the last few months powerpc fixes were added to upstream UXP. You can build any UXP application on ppc now, except you still need to swap the icu.dat file around. So changelog will always be the about same as upstream. https://www.palemoon.org/releasenotes.shtml
Download: github.com/wicknix/SpiderWeb
sailorMH
Re: SpiderWeb
Post by sailorMH »
32-bit version 2.2.2 works on Debian 8
https://img34.rajce.idnes.cz/d3403/16/1 ... derweb.jpg
64 bit version is 2.2.1 here https://github.com/wicknix/SpiderWeb/wi ... rm0xI9hdCw
spiderweb-2.2.1.linux-powerpc64.tar.bz2 with Debian Sid don't work:
tata@amigaone:~/Downloads/spiderweb$ ./spiderweb
XPCOMGlueLoad error for file /home/tata/Downloads/spiderweb/libxul.so:
libffi.so.6: cannot open shared object file: No such file or directory
Couldn't load XPCOM.
libffi7 is installed and spiderweb run from unpacked archive directory.
Re: SpiderWeb
sailorMH wrote: Mon Jun 08, 2020 8:49 pm 32-bit version 2.2.2 works on Debian 8
Hi SailorMH,
Thank you for testing! You need the symbolic link "libffi.so.6" to "libffi.so.7". Please create this symbolic link with the following command:
ln -s /usr/lib/powerpc64-linux-gnu/libffi.so.7 /usr/lib/powerpc64-linux-gnu/libffi.so.6
After that please try SpiderWeb again.
sailorMH
Re: SpiderWeb
Post by sailorMH »
xeno74 wrote: Mon Jun 08, 2020 11:52 pm
Thanks - it works fine!
btw: canberra-gtk-module is something with sound on web pages?
Re: SpiderWeb
I compiled SpiderWeb 2.2.2 for Linux PPC64 today.
Download: spiderweb-2.2.2.linux-powerpc64.tar.bz2
It could be, that you have to install some packages for example libffi7 for using SpiderWeb. I successfully tested it on Fedora 27 PPC64 and on openSUSE Tumbleweed 20190722 PPC64 today. If you use Debian Sid PPC64, then you need the symbolic link "libffi.so.6" to "libffi.so.7". Please create this symbolic link with the following command:
Please test the new SpiderWeb.
