SoundBlaster Live!
SoundBlaster Live!
Do the latest Kernel versions still have the 3.5M Ram limit when using SoundBlaster Live! soundboard? Is there any other bord without this limitation, which would work with ALL operating systems (AmigaOS, Linux, MorphOS) available for X5000?
Re: SoundBlaster Live!
As far as i can remember is the memory limit gone. If not, i use the M-Audio Revolution pci soundcard. Its Envy based and works perfect with AmigaOS4.1 FE and Linux.Roland wrote:Do the latest Kernel versions still have the 3.5M Ram limit when using SoundBlaster Live! soundboard? Is there any other bord without this limitation, which would work with ALL operating systems (AmigaOS, Linux, MorphOS) available for X5000?
Hi Roland,
This patch has been added with the PowerPC updates 5.1-1 to the official Linux kernel. (5.1-alpha2).
Did you test the Soundblaster Live! sound card with the latest kernels? You don't have to add the 3.5M RAM limit to the boot arguments when you have a SoundBlaster Live! installed since the kernel 4.19.Roland wrote:Do the latest Kernel versions still have the 3.5M Ram limit when using SoundBlaster Live! soundboard? Is there any other bord without this limitation, which would work with ALL operating systems (AmigaOS, Linux, MorphOS) available for X5000?
Patch for solving the SoundBlaster Live! issue:xeno74 wrote:Hi All,
Greg Kroah-Hartman released the final version of kernel 4.19 today. In the development time, Darren created a new Nemo patch and the kernel developers added Darren's Nemo/PASEMI updates to the official kernel. Many thanks to Darren for the Nemo patch and for the Nemo/PASEMI updates. There were some USB issues with the kernel 4.19 on the X5000. Darren figured out where the problem is. He did a bisect and found the bad commit. He also found a bad kernel config option. Disabling 'HAVE_ARCH_PREL32_RELOCATIONS' in arch/powerpc/Kconfig fixed the problems. He reported the bad commit to the Linuxppc-dev mailing list and after that the kernel developers removed 'HAVE_ARCH_PREL32_RELOCATIONS' in arch/powerpc/Kconfig. He also solved the mem issue with the SoundBlaster Live! It works without the mem=3500M boot argument now.
Thanks a lot to Tom for testing the kernels on his X1000 and many thanks to Skateman, kilaueabart, and acefnq for testing the kernels on the X5000.
diff -rupN a/arch/powerpc/sysdev/fsl_pci.c b/arch/powerpc/sysdev/fsl_pci.c
--- a/arch/powerpc/sysdev/fsl_pci.c 2018-09-02 23:37:30.000000000 +0200
+++ b/arch/powerpc/sysdev/fsl_pci.c 2018-09-03 09:08:35.193482962 +0200
@@ -127,9 +127,6 @@ static inline void setup_swiotlb_ops(str
static int fsl_pci_dma_set_mask(struct device *dev, u64 dma_mask)
- if (!dev->dma_mask || !dma_supported(dev, dma_mask))
- return -EIO;
* Fix up PCI devices that are able to DMA to the large inbound
* mapping that allows addressing any RAM address from across PCI.
Thanks for the tip! Is that M-Audio still in production, or do you need to find a second-hand board? I wonder whether it works also with MOS... What chip set has it?Skateman wrote: As far as i can remember is the memory limit gone. If not, i use the M-Audio Revolution pci soundcard. Its Envy based and works perfect with AmigaOS4.1 FE and Linux.
I do not have that card yet... I have currently an Envy24HT which works with AmigaOS and (partly) with MOS, but _not_ with Linux, and also a second card, CMI8738 (PCI-e, unfortunately with Revision 1 bridge), which works only with Linux. But now I'm looking for a card which would work perfectly with all OSs, so that I would not need to move cables when I switch from one OS to another.xeno74 wrote: Did you test the Soundblaster Live! sound card with the latest kernels? You don't have to add the 3.5M RAM limit to the boot arguments when you have a SoundBlaster Live! installed since the kernel 4.19.
A CMI8738 with newer bridge chip would be one possibility, but they are very difficult to find. Most mail-order shops do not know what they really have...
The M-Audio card is not being made and bought it second hand.
It does work perfect and also with linux.
Big picture http://www.skateman.nl/wp-content/uploa ... 214817.png
As show in dmesg:
5.435182] ALSA device list:
[ 5.445353] #0: Virtual MIDI Card 1
[ 5.450484] #1: HDA ATI HDMI at 0xc10040000 irq 43
[ 5.455608] #2: M Audio Revolution-5.1 at 0x8000080000022000, irq 19
As show in dmesg:
