USB floppy disk?
icbrkr
USB floppy disk?
Post by icbrkr »
I'm fairly certain I know the answer to this - but is it possible to mount a USB floppy drive under 4.1?
Re: USB floppy disk?
Most of todays USB devices come either with a driver on it's hardware or with a software driver.
The latter won't work since the software won't run.
IF it features a hardware driver AND mounts itself as some kind of (slow) mass storage device, it *could* be possible to use (read/write - albeit i doubt it will support any of amiga's special floppy methods).
Normally i'd go with "No", since there is no USB driver"
People are dying.
How dare you!
– Greta Thunberg
Amigo1
Post by Amigo1 »
icbrkr wrote:I'm fairly certain I know the answer to this - but is it possible to mount a USB floppy drive under 4.1?
luckily I found a drive an was abler to test it. The result:
it does work on x1000 with a TEAC UFD-03 external Floppy Drive Unit.
It does not read floppies from the "Classic" Commodore Amiga 68k-hardware-Era formatted floppies however.
so we learned something new today.. :)
icbrkr
Post by icbrkr »
I didn't expect to read original floppy disks so I'm good there. Was it just plug and play? Or did you do something differently?
Amigo1
Post by Amigo1 »
Just plug&play
icbrkr
Post by icbrkr »
Just plug&play[/quote]
Awesome, thanks. I'm off to find one of these to use.
