Onboard ethernet of X5000
At what stage is the support for onboard ethernet of X5000...? For AmigaOS there has been driver for a while, and MorphOS should also have it now with 3.12 update.
I would very much like to free the legacy PCI slot, occupied currently by a RTL8039, for another card...
Re: Onboard ethernet of X5000
Roland wrote:At what stage is the support for onboard ethernet of X5000...? For AmigaOS there has been driver for a while, and MorphOS should also have it now with 3.12 update.
Unfortunately the onboard ethernet isn't supported currently. We are looking for someone who can fix the issue with the onboard ethernet. The A1222 and the X1000 have support for their onboard ethernet.
To get rid of the PCI adapter you could use a USB to Ethernet adapter for just linux. Thats what i did for now.
I am using ASIX AX88772B USB 2.0 Ethernet,
What is your output of dmesg | grep eth ? mine is..
skateman@X5000LNX:~$ dmesg | grep eth
[ 4.740603] fsl_dpaa_mac ffe4e6000.ethernet: FMan dTSEC version: 0x08240101
[ 4.741026] fsl_dpaa_mac ffe4e6000.ethernet: FMan MAC address: 00:04:a3:6b:41:7c
[ 4.741387] fsl_dpaa_mac ffe4e8000.ethernet: FMan dTSEC version: 0x08240101
[ 4.741740] fsl_dpaa_mac ffe4e8000.ethernet: FMan MAC address: 00:1e:c0:f8:31:b5
[ 4.742001] fsl_dpaa_mac ffe4e0000.ethernet: of_get_mac_address(/soc@ffe000000/fman@400000/ethernet@e0000) failed
[ 4.742203] fsl_dpaa_mac: probe of ffe4e0000.ethernet failed with error -22
[ 4.742382] fsl_dpaa_mac ffe4e2000.ethernet: of_get_mac_address(/soc@ffe000000/fman@400000/ethernet@e2000) failed
[ 4.742568] fsl_dpaa_mac: probe of ffe4e2000.ethernet failed with error -22
[ 4.742749] fsl_dpaa_mac ffe4e4000.ethernet: of_get_mac_address(/soc@ffe000000/fman@400000/ethernet@e4000) failed
[ 4.747328] fsl_dpaa_mac: probe of ffe4e4000.ethernet failed with error -22
[ 4.751918] fsl_dpaa_mac ffe4f0000.ethernet: of_get_mac_address(/soc@ffe000000/fman@400000/ethernet@f0000) failed
[ 4.756660] fsl_dpaa_mac: probe of ffe4f0000.ethernet failed with error -22
[ 4.763988] fsl_dpaa_mac ffe4e6000.ethernet eth0: Probed interface eth0
[ 4.771622] fsl_dpaa_mac ffe4e8000.ethernet eth1: Probed interface eth1
[ 9.866008] asix 2-1.1.4.2:1.0 eth2: register 'asix' at usb-fsl-ehci.1-1.1.4.2, ASIX AX88772B USB 2.0 Ethernet, 9c:eb:e8:0a:0e:ed
[ 12.980453] asix 2-1.1.4.2:1.0 enx9cebe80a0eed: renamed from eth2
Skateman wrote: To get rid of the PCI adapter you could use a USB to Ethernet adapter for just linux. Thats what i did for now.
I would prefer some 'internal' solution... Do PCIe ethernet boards generally work with our Linux distros?
~$ dmesg | grep eth
[ 2.685280] fsl_dpaa_mac ffe4e6000.ethernet: of_get_mac_address(/soc@ffe000000/fman@400000/ethernet@e6000) failed
[ 2.685479] fsl_dpaa_mac: probe of ffe4e6000.ethernet failed with error -22
[ 2.685652] fsl_dpaa_mac ffe4e8000.ethernet: of_get_mac_address(/soc@ffe000000/fman@400000/ethernet@e8000) failed
[ 2.685841] fsl_dpaa_mac: probe of ffe4e8000.ethernet failed with error -22
[ 2.686030] fsl_dpaa_mac ffe4e0000.ethernet: of_get_mac_address(/soc@ffe000000/fman@400000/ethernet@e0000) failed
[ 2.686219] fsl_dpaa_mac: probe of ffe4e0000.ethernet failed with error -22
[ 2.686395] fsl_dpaa_mac ffe4e2000.ethernet: of_get_mac_address(/soc@ffe000000/fman@400000/ethernet@e2000) failed
[ 2.686584] fsl_dpaa_mac: probe of ffe4e2000.ethernet failed with error -22
[ 2.686762] fsl_dpaa_mac ffe4e4000.ethernet: of_get_mac_address(/soc@ffe000000/fman@400000/ethernet@e4000) failed
[ 2.686958] fsl_dpaa_mac: probe of ffe4e4000.ethernet failed with error -22
[ 2.687144] fsl_dpaa_mac ffe4f0000.ethernet: of_get_mac_address(/soc@ffe000000/fman@400000/ethernet@f0000) failed
[ 2.691606] fsl_dpaa_mac: probe of ffe4f0000.ethernet failed with error -22
[ 2.729819] 8139too 1000:04:05.0 eth0: RealTek RTL8139 at 0x(____ptrval____), 00:06:4f:1e:19:85, IRQ 19
[ 10.809436] 8139too 1000:04:05.0 enP4096p4s5: renamed from eth0
I have used this adapter before the OS4.1 driver for the onboard X5000 adapter became available.. Also works with linux.
https://www.tp-link.com/us/home-network ... r/tg-3468/
