I installed ibus quite some time ago, and I can set the symbol in the upper panel to say I am set to type Japanese, but it doesn't do so.
Googling about it a few minutes ago suggested running ibus-setup, and that brought a different result from starting ibus in the menu:
fienix@Fienix:~$ ibus-setup
/usr/share/ibus-anthy/setup/main.py:119: DeprecationWarning: Gtk.Window.set_wmclass is deprecated
toplevel.set_wmclass(parent_wmname, parent_wmclass)
(ibus-setup:7427): IBUS-WARNING **: 15:36:28.971: Unable to connect to ibus: Could not connect: Connection refused
fienix@Fienix:~$ I might mention that I have no problem in Ubuntu, and Fienix' /usr/share/ibus-anthy looks just about the same as Ubuntu's, Fienix having
fienix@Fienix:~$ ls /usr/share/ibus-anthy -R
/usr/share/ibus-anthy:
dicts engine setup
/usr/share/ibus-anthy/dicts:
emoji.t era.t oldchar.t symbol.t zipcode.t
/usr/share/ibus-anthy/engine:
_config.py engine.py jastring.py main.py romaji.py tables.py
default.xml factory.py kana.py __pycache__ segment.py thumb.py
/usr/share/ibus-anthy/engine/__pycache__:
_config.cpython-37.pyc kana.cpython-37.pyc tables.cpython-37.pyc
engine.cpython-37.pyc main.cpython-37.pyc thumb.cpython-37.pyc
factory.cpython-37.pyc romaji.cpython-37.pyc
jastring.cpython-37.pyc segment.cpython-37.pyc
/usr/share/ibus-anthy/setup:
anthyprefs.py _config.py main.py prefs.py __pycache__ setup.ui
/usr/share/ibus-anthy/setup/__pycache__:
anthyprefs.cpython-37.pyc main.cpython-37.pyc
_config.cpython-37.pyc prefs.cpython-37.pyc
