Kernel 5.4
Kernel 5.4
The Linux 5.4 kernel merge window is open for merging. Linus Torvalds has added a lot of new source code to the Linux Git.
Here is the first alpha of kernel 5.4 for the X1000, X5000, and A1222.
Download: linux-image-5.4-alpha1-X1000_X5000_A1222.tar.gz
Screenshot of Fienix with the first alpha of kernel 5.4:
Re: Kernel 5.4
I released the second alpha of kernel 5.4 for the X1000, X5000, and A1222 today.
Download: linux-image-5.4-alpha2-X1000_X5000_A1222.tar.gz
Unfortunately it doesn't boot with my Radeon Northern Islands graphics cards anymore. I tested it with a Radeon HD6870 and with a Radeon HD4870.
The kernel boots with a Radeon SI graphics card. (R7 240)
I reverted the latest DRM updates and after that the kernel boots with my Radeon HD6870 and with my Radeon HD4870 without any problems. If you have the same issue please test the kernels from the following package.
Download: linux-image-5.4-alpha2-X1000_X5000_without_DRM_updates--2019-09-18.tar.gz
I reported this issue on the mesa-dev mailing list today.
Screenshot of Debian 10 PowerPCSPE with the second alpha of kernel 5.4:
Re: Kernel 5.4
I created a bug report because of the boot problem with Radeon NI graphics cards today.
Link: Bug 111761 - Latest Git Kernel doesn’t boot with Radeon NI with the drm-next-2019-09-18 updates
Re: Kernel 5.4
xeno74 wrote:Hi All,
The changes of the following files are responsible for the boot issue.
  • drivers/gpu/drm/drm_*
  • include/drm/*
The kernel doesn't boot with the updates in the files above from the drm-next-2019-09-18.
I updated the bug report "Bug 111761 - Latest Git Kernel doesn’t boot with Radeon NI with the drm-next-2019-09-18 updates" today.
PLEASE test the alpha2 with your Radeon SI graphics card.
Re: Kernel 5.4
I created a patch today. This patch reverts the changes in the following files.
  • include/drm/*
It also reverts all files which depends on these files above.
Now I can boot the latest Git kernel with my Radeon HD NI graphics cards again.
Download: drm2.patch
Re: Kernel 5.4
Here is the third alpha of kernel 5.4 for testing.
Download: linux-image-5.4-alpha3-X1000_X5000_A1222.tar.gz
Screenshot of Debian 10 PowerPCSPE with the third alpha of kernel 5.4 on the A1222:
Re: Kernel 5.4
Great news! :-)
Alex released a new DRM patch because of the boot issue with Radeon NI graphics cards yesterday. I compiled the latest Git kernel with this patch today. After that I could boot this kernel with my Radeon NI graphics cards without any problems! :-)
drm3.patch:
diff --git a/drivers/gpu/drm/drm_drv.c b/drivers/gpu/drm/drm_drv.c
index c456c3d..769feef 100644
--- a/drivers/gpu/drm/drm_drv.c
+++ b/drivers/gpu/drm/drm_drv.c
@@ -976,14 +976,14 @@ int drm_dev_register(struct drm_device *dev, unsigned long flags)
 	if (ret)
 		goto err_minors;
+	dev->registered = true;
 	if (dev->driver->load) {
 		ret = dev->driver->load(dev, flags);
 		if (ret)
 			goto err_minors;
-	dev->registered = true;
 	if (drm_core_check_feature(dev, DRIVER_MODESET))
 		drm_modeset_register_all(dev);
diff --git a/drivers/gpu/drm/drm_mode_object.c b/drivers/gpu/drm/drm_mode_object.c
index c355ba8..6a23e36 100644
--- a/drivers/gpu/drm/drm_mode_object.c
+++ b/drivers/gpu/drm/drm_mode_object.c
@@ -42,7 +42,7 @@ int __drm_mode_object_add(struct drm_device *dev, struct drm_mode_object *obj,
 	int ret;
-	WARN_ON(dev->registered && !obj_free_cb);
+	WARN_ON(!dev->driver->load && dev->registered && !obj_free_cb);
 	mutex_lock(&dev->mode_config.idr_mutex);
 	ret = idr_alloc(&dev->mode_config.object_idr, register_obj ? obj : NULL,
@@ -104,7 +104,7 @@ void drm_mode_object_register(struct drm_device *dev,
 void drm_mode_object_unregister(struct drm_device *dev,
 				struct drm_mode_object *object)
-	WARN_ON(dev->registered && !object->free_cb);
+	WARN_ON(!dev->driver->load && dev->registered && !object->free_cb);
 	if (object->id) {
Link to the bug report: Bug 111761 - Latest Git Kernel doesn’t boot with Radeon NI with the drm-next-2019-09-18 updates
Re: Kernel 5.4
I released the alpha4 of kernel 5.4 for the X1000, X5000, and A1222 today.
Download: linux-image-5.4-alpha4-X1000_X5000_A1222.tar.gz
Screenshot of Debian 10 PowerPCSPE with the alpha4 of kernel 5.4 on the A1222 (Tabor board):
Re: Kernel 5.4
The new drm3.patch has been added to the latest Git kernel. :-)
Link: DRM fixes drm-next-2019-09-27
Re: Kernel 5.4
