I have an X5000 Computer with an old U-Boot 4 - Jun - 2016
The Environmental variables don't function as they should.
Any Ideas where I can't get one.
Trying to find X5000 U-Boot File
Re: Trying to find X5000 U-Boot File
Same issue here, when I execute : version full bootsd.resource , I'm getting version number 54.5 which doesn't look very fresh.
If someone has a moment to do a "dd" of his U-Boot SD card, it would be greatly appreciated
Bootsd.resource is not UBoot, it is a resource in the OS used to interact with it.
Getting an update to UBoot (including documentation and guidelines for installing and using it correctly) is something your dealer should help you with.
Thanks a lot for the clarifications, I'll check with my dealer then !
I've tried that since the beginning of July.nbache wrote:Bootsd.resource is not UBoot, it is a resource in the OS used to interact with it.
AmigaKit who I purchased from no response.
@donfirth
Have you tried giving them a ring? You know, to see if there's someone in the office during the summertime?I've tried that since the beginning of July. AmigaKit who I purchased from no response.
The Rear Window blog
Turns out to be a great suggestion.trixie wrote: Have you tried giving them a ring? You know, to see if there's someone in the office during the summertime?
At first I was uneasy about calling AmigaKit with the default Phone Number, but when you click your currency you get a proper phone number.
By calling first, my email is answered with the attachment of a new U-Boot file
Cheers
Out of curiosity.. what IS the latest version?
From AmigaKit: 22-10-2018icbrkr wrote:Out of curiosity.. what IS the latest version?
Oh rly. Thanks for that, I'll hit up AOTL and see if I can get the latest.
