I have put Radeon RX 580 NItro+ Polaris 20 in my AmigaOne X5000, everything works normal, but have few questions:
1. AmigaOS4.1 (latest version| shows it is Radeon RX Polaris 10, and shows only 2GB memory
2. is there a software that utilze, sets this graphic card?
3. [update] I have noticed that since this new graphic card in case - the warm reset (Ctrl+LAmiga+RAmiga) going into black screen ("System reboot" button on the Dock lead to the same result)
only physical "RESET" button helps reset AmigaOne for real
I have the latest Software Enhancer Plus update
Thank you
-jan
Radeon RX 580 in X5K
Re: Radeon RX 580 in X5K
Several graphic cards need a full reset
ctrl-amiga-amiga is considered a soft reset
ctrl-alt-alt forces a hard reset.
Unfortunately, the newer graphic cards do not support the soft reboot. Hans deRuiter explained somewhere in the forums that the driver cannot do anything about it.dzanino wrote:I have noticed that since this new graphic card in case - the warm reset (Ctrl+LAmiga+RAmiga) going into black screen
The Rear Window blog
aaah thank you
Thought I did something wrong when I attached the card to PCI, or there is a lack of power...
Have a nice day
Have a nice day
I've had a hell of a time with Polaris 10. After reading this post and a previous I got an RX580 only to find it has known issues with 3D support that causes lockups. I tested this myself and removed that card. The 580 I got was this one here: https://www.bestbuy.com/site/xfx-amd-ra ... Id=6092641
I talked with Trevor and he was the one that mentioned to me the bug int he driver and that I should get an RC560 or 570. So I got a Gigabyte RX570 with 8GB and the same issues happen. It loks up on anything 3D or will not load anything calling for 3D. I have 100% verified this by putting my HD7770 back in and have funn support again. Put the 580 and 570 in I lose it all.
I have been told by a friend with the XFX RX550 its working fine however. My issue is I dont want to pull out a 4GB card to use a 2GB card.
Solutions?
Solutions?
@Acill
There is nothing on amigaos4 which need more than 1gb of GPU.
There is list of games which at least utilize somehow GPU:
RTCW Reboorn on full details - need about 900mb of GPU
SuperTuxKart 0.8 need about 350 mb of GPU
HCraft - 300mb of GPU
Night of The Zombies : 400mb of GPU
And probably Spencer need about 100-200mb.
So having 2gb card on amigaos4 is capable for everything.
There are RX550 and RX560 models with 4GB that work well.
I have the two models below :
https://www.sapphiretech.com/en/consume ... -550-4g-g5
https://www.asus.com/us/Graphics-Cards/ ... 4G-GAMING/
Acill wrote: ↑Mon Feb 24, 2020 3:43 am I've had a hell of a time with Polaris 10. After reading this post and a previous I got an RX580 only to find it has known issues with 3D support that causes lockups. I tested this myself and removed that card. The 580 I got was this one here: https://www.bestbuy.com/site/xfx-amd-ra ... Id=6092641
Solutions?
