X5000 Mac addresses
Tijatjj
X5000 Mac addresses
Post by Tijatjj »
Hi is there any way to install MAC address as mine were lost when I had to redo the sd card shows blank after reset of Mac address Thanks
msalcedo
Re: X5000 Mac addresses
Post by msalcedo »
to reset your MAC address after flashing the firmware using the uboot prompt..
Setenv eth1addr xx:xx:xx:xx:xx:xx
Setenv eth2addr xx:xx:xx:xx:xx:xx
Saveenv
you did write down the addresses?
Don't forget at uboot prompt type "help" and get all the commands
Tijatjj
Post by Tijatjj »
Some one mentioned that they are printed in the corner of the board I hope.
Tijatjj wrote:Some one mentioned that they are printed in the corner of the board I hope.
No, the newer batches of boards dont have the mac addresses printed on there..so what u need is:
Boot the system with an Old U-Boot version. This version will probe the HW macs.Write them down. Insert the newer U-Boot SD and program them as mentioned above.
I have also found out the hard way, see my ticket below... ps the links dont work anymore..
Date Submitted: Tuesday 23 January, 2018
The comments for your ticket are as follows:
Sorry for delay,
Ok, you need Win32 Disk Imager. Please download that on your PC.
One downloaded, run and insert your SD card. Download and unzip this file;
http://technical.leamancomputing.com/Te ... s_5020.zip <---------OLD FIRMWARE
http://technical.leamancomputing.com/Te ... 7-4-17.zip <---------CURRENT FIRMWARE
Extract and point Win32 Disk Imager to the bin file. Then click "WRITE". Make sure you have the correct drive selected before pressing "WRITE".
Once its written, place in motherboard. Boot, go to Startup Menu and select system info. It will display MAC addresses (stored internally in chips). Note them down. Power down and insert old SD card.
Boot back up and go into Startup Menu and select "Command Line". Now type; set ethaddr "YOUR NOTED MAC ADDRESS" press return to temp store command, then do same for ethaddr1. Once done. Type saveenv and then press enter. It should now permanantly store the values.
You can check by typing printenv and then press Retur n. It should have MAC addresses stored.
**DO NOT REPLY TO THIS EMAIL- USE THE SUPPORT TICKET SYSTEM TO ADD COMMENTS**
Tijatjj
Post by Tijatjj »
Oh boy thanks
khayoz
Post by khayoz »
@Skateman
What´s new in the latest X5000 firmware?
Where do I get it?
1989--> A500, A600, A3000, A4000, A1200, CD32, µA1, PegII, A1XE, CDTV, Amy/416D79, A1X5000/20, Amy-ITXv1.6, Amy-ITXv1.8, A500 rev8A & rev8A.1, Denise, A1X5000/40 <--2025
