CodeBench for OS4.1
simulant
CodeBench for OS4.1
Post by simulant »
Hi does anyone know where I can download and obtain CodeBench?
The downloads link is broken on codebench.co.uk
If I use the Way Back Machine and go back a year I can get the missing page and download but it doesn't install on OS4 and crashes...
Thanks for any help
Re: CodeBench for OS4.1
If you use the Downloads "menu" at the top of the page, you'll get to a page on which clicking the Download link worked for me. I just tried re-downloading the SDK version, and the resulting archive was equal to the one I downloaded last year, and which I presently have installed and use.
simulant
Post by simulant »
ah great thanks that is working. They just need to rename the links on their homepage and from other sites from /downloads.html to /downloads.php or put an additional redirect in place haha
Thanks again :)
simulant wrote:They just need to rename the links on their homepage and from other sites from /downloads.html to /downloads.php or put an additional redirect in place haha
Yeah, or omit the ".html" altogether (IIRC).
