Dvd-rw
Re: Dvd-rw
I've had this problem in the past on my x1000. What I had to do was erase it on a windows system & then it showed up & worked, no idea why.Tijatjj wrote:Trying to burn iso to dvd but dvd not being seen ,brand new dvd 4gig one is that the problem thanks
Re: Dvd-rw
If you're using the P5020 sata device, I believe CD/DVD writing is not yet supported.
Re: Dvd-rw
Oh , I’ll try the suggestion anyway but thanks that will save a lot of fruitless looking
