CMI8738 PCIe sound cards?
Do the kernels for X5000 support CMI8738 PCIe sound cards? Do they work reliably...? Can anyone recommend a source from where to get a working one (with a bridge revision 3, so that it would work also with AmigaOS)?
As I already have the legacy PCI slots reserved, it should indeed be a PCIe version!
Re: CMI8738 PCIe sound cards?
Roland wrote:Do the kernels for X5000 support CMI8738 PCIe sound cards? Do they work reliably...? Can anyone recommend a source from where to get a working one (with a bridge revision 3, so that it would work also with AmigaOS)?
Yes, the X5000 Linux kernel supports the CMI8738 PCIe sound cards.
CONFIG_SND_CMIPCI=y
Further information: CONFIG_SND_CMIPCI: C-Media 8338, 8738, 8768, 8770
Experiences:
xeno74 wrote: Yes, the X5000 Linux kernel supports the CMI8738 PCIe sound cards.
Thnks for the info!
Experiences:
In this thread it was unclear whether the PCIe version of CMI8738 really works. Spectre660, can you comment...? Did find those working PCIe cards you were looking for?
