problem detected
problem detected
It seems to me that as long as I have been running Ubuntu, I have gotten, right away, a notice on the order of, "Sorry, Ubuntu 16.04 has experienced an internal error." I never worried about this much. If I checked for details it would be something about Bluetooth.
For a couple weeks now, I have been getting another, more immediate, notice: "System program problem detected." The details are given as
polkit.subject-pid: 5828
polkit.caller-pid: 6313
Action: com.ubuntu.appart.appart-gtk-ret
I have not noticed any new problems aside from this notice. Is it something I should look into further?
I used to get the first message mentioning Bluetooth in the details even when I had given up trying to make my dongle work and stopped plugging it in. But lately I tried again, successfuly, but still the strange details. I attach pictures in case anybody has any idea whether they mean anything important.
Re: problem detected
The bluetooth daemon crashed. I don’t know why. Have you seen any other error messages? You can look in the log file /var/log/syslog because of the error messages.
xeno74 wrote:The bluetooth daemon crashed. I don’t know why. Have you seen any other error messages? You can look in the log file /var/log/syslog because of the error messages.
Syslog looks weird. Mostly this, over and over again:
Mar 23 09:23:15 X5000 systemd[1]: Time has been changed
Mar 23 09:23:15 X5000 rsyslogd-2007: action 'action 10' suspended, next retry is Sat Mar 23 09:24:45 2019 [v8.16.0 try http://www.rsyslog.com/e/2007 ]
Mar 23 09:29:54 X5000 systemd[1]: Time has been changed
Mar 23 09:29:54 X5000 systemd[5658]: Time has been changed
Mar 23 09:29:54 X5000 rsyslogd-2007: action 'action 10' suspended, next retry is Sat Mar 23 09:31:24 2019 [v8.16.0 try http://www.rsyslog.com/e/2007 ]
Mar 23 09:38:20 X5000 systemd[5658]: Time has been changed
I tried searching "blue" and "blu." Not found.
Meanwhile, as I noted, Bluetooth is working fine:
That brings up another question. Is there any way of finding out what "9C-30-5B-0F-64-EC" and "KSMT" are? Or which of my Tiles is referenced? (BLKBOX POP360 is really a speaker, not a microphone, but I can play music on it from Ubuntu now.)
I looked again, the next day, and found lots of bluetooth stuff that doesn't tell me anything:
Mar 23 07:47:45 X5000 bluetoothd[4479]: Bluetooth daemon 5.37
Mar 23 07:47:47 X5000 systemd[1]: Started Bluetooth service.
Mar 23 07:47:47 X5000 bluetoothd[4479]: Starting SDP server
Mar 23 07:47:48 X5000 bluetoothd[4479]: Failed to obtain handles for "Service Changed" characteristic
Mar 23 07:47:48 X5000 bluetoothd[4479]: Not enough free handles to register service
Mar 23 07:47:48 X5000 bluetoothd[4479]: Error adding Link Loss service
Mar 23 07:47:48 X5000 bluetoothd[4479]: message repeated 2 times: [ Not enough free handles to register service]
Mar 23 07:47:48 X5000 bluetoothd[4479]: Current Time Service could not be registered
Mar 23 07:47:48 X5000 bluetoothd[4479]: gatt-time-server: Input/output error (5)
Mar 23 07:47:48 X5000 bluetoothd[4479]: Sap driver initialization failed.
Mar 23 07:47:48 X5000 bluetoothd[4479]: sap-server: Operation not permitted (1)
Mar 23 07:47:52 X5000 NetworkManager[4562]: <info> [1553352472.2767] Loaded device plugin: NMBluezManager (/usr/lib/powerpc-linux-gnu/NetworkManager/libnm-device-plugin-bluetooth.so)
Mar 23 07:47:52 X5000 NetworkManager[4562]: <info> [1553352472.6001] bluez: use BlueZ version 5
Mar 23 07:48:17 X5000 bluetoothd[4479]: Endpoint registered: sender=:1.49 path=/MediaEndpoint/A2DPSource
Mar 23 07:48:17 X5000 bluetoothd[4479]: Endpoint registered: sender=:1.49 path=/MediaEndpoint/A2DPSink
Mar 24 08:04:34 X5000 kernel: [ 46.334245] Bluetooth: RFCOMM TTY layer initialized
Mar 24 08:04:34 X5000 kernel: [ 46.334257] Bluetooth: RFCOMM socket layer initialized
Mar 24 08:04:34 X5000 kernel: [ 46.334266] Bluetooth: RFCOMM ver 1.11
Mar 24 08:04:38 X5000 dbus[4506]: [system] Activating service name='org.blueman.Mechanism' (using servicehelper)
Mar 24 08:04:39 X5000 org.blueman.Mechanism[4506]: Failed to connect to Mir: Failed to connect to server socket: No such file or directory
Mar 24 08:04:39 X5000 org.blueman.Mechanism[4506]: Unable to init server: Could not connect: Connection refused
Mar 24 08:04:39 X5000 blueman-mechanism: Starting blueman-mechanism
Mar 24 08:04:39 X5000 dbus[4506]: [system] Successfully activated service 'org.blueman.Mechanism'
Mar 24 08:04:39 X5000 org.blueman.Mechanism[4506]: (blueman-mechanism:6091): Gtk-CRITICAL **: gtk_icon_theme_get_for_screen: assertion 'GDK_IS_SCREEN (screen)' failed
Mar 24 08:04:39 X5000 blueman-mechanism: loading RfKill
Mar 24 08:04:39 X5000 blueman-mechanism: loading Network
Mar 24 08:04:39 X5000 blueman-mechanism: loading Rfcomm
Mar 24 08:04:39 X5000 blueman-mechanism: loading Ppp
Mar 24 08:05:09 X5000 blueman-mechanism: Exiting
I repeat: Bluetooth seems to be working OK. I'm more concerned about the System program problem, which seems to be related. Apport.log has this from yesterday:
ERROR: apport (pid 6661) Sun Mar 24 15:18:22 2019: called for pid 4485, signal 11, core limit 0, dump mode 1
ERROR: apport (pid 6661) Sun Mar 24 15:18:22 2019: executable: /usr/lib/bluetooth/bluetoothd (command line "/usr/lib/bluetooth/bluetoothd")
ERROR: apport (pid 6661) Sun Mar 24 15:18:22 2019: is_closing_session(): no DBUS_SESSION_BUS_ADDRESS in environment
ERROR: apport (pid 6661) Sun Mar 24 15:18:22 2019: wrote report /var/crash/_usr_lib_bluetooth_bluetoothd.0.crash
ERROR: apport (pid 15548) Sun Mar 24 21:39:59 2019: called for pid 4483, signal 11, core limit 0, dump mode 1
ERROR: apport (pid 15548) Sun Mar 24 21:39:59 2019: executable: /usr/lib/bluetooth/bluetoothd (command line "/usr/lib/bluetooth/bluetoothd")
ERROR: apport (pid 15548) Sun Mar 24 21:39:59 2019: is_closing_session(): no DBUS_SESSION_BUS_ADDRESS in environment
ERROR: apport (pid 15548) Sun Mar 24 21:39:59 2019: apport: report /var/crash/_usr_lib_bluetooth_bluetoothd.0.crash already exists and unseen, doing nothing to avoid disk usage DoS
The crash log is 13,906 lines long. I skimmed a few thousand then jumped to the end which has a lot of lines apparently copied out of today's syslog about bluetooth.
