IGraphics->AllocBitMap : dereferencing pointer to incomplete
AmiDARK
Post by AmiDARK »
Hello,
When I use :
displayCore.mainBitMap = IGraphics->AllocBitMap( screenConfig->Width, screenConfig->Height, screenConfig->Depth, BMF_INTERLEAVED, NULL );
I got this error message :
Display.c:169: error: dereferencing pointer to incomplete type
I define in the displayCore :
struct BitMap * mainBitMap;
in screenConfig, Width, Height and Depth are set as ULONG
I don't understand.
Re: IGraphics->AllocBitMap : dereferencing pointer to incomp
You may have defined them, but the error sugests that the definition has not been included, or possibly there is a typo in the variable declaration, leading to an unknown type
Rigo
Post by Rigo »
Have you "included" <proto/graphics.h> ?
Simon
@AmiDark:
broadblues wrote:You may have defined them, but the error suggests that the definition has not been included, or possibly there is a typo in the variable declaration, leading to an unknown type
What you included above is a declaration, not a definition. It only declares that a "struct BitMap" is to be stored at that location, without defining what a "struct BitMap" is.
The definition goes along the lines of:
struct BitMap
As Rigo says, it is defined by "including" proto/graphics.h, which in turn defines all the structures you will ever need for graphics.
AmiDARK
Post by AmiDARK »
Hello everyone and thank you for your answers.
I got wrong because I included <graphics/gfx.h> that contain this definition of BitMap :
struct BitMap
UWORD BytesPerRow;
UWORD Rows;
UBYTE Flags;
UBYTE Depth;
UWORD pad;
PLANEPTR Planes[8];
I have included <proto/graphics.h> and it solved my issue.
Thank you.
Now I hope my screen/window system will fully work .. Will test it later today.
Regards,
AmiDARK
salass00
Post by salass00 »
In this case it was the definition of the GraphicsIFace structure that was missing that was the problem, hence why IGraphics couldn't be dereferenced to get the AllocBitMap() function.
Including <proto/graphics.h> which in turn includes <interfaces/graphics.h> solved it.
AmiDARK
Post by AmiDARK »
salass00 wrote:In this case it was the definition of the GraphicsIFace structure that was missing that was the problem, hence why IGraphics couldn't be dereferenced to get the AllocBitMap() function.
Will try this.
Thank you.
