CPU vulnerabilities
CPU vulnerabilities
FYI:
X1000, CPU: PWRficient PA6T-1682M, kernel 4.20-rc3: grep . /sys/devices/system/cpu/vulnerabilities/*
/sys/devices/system/cpu/vulnerabilities/l1tf:Not affected
/sys/devices/system/cpu/vulnerabilities/meltdown:Vulnerable
/sys/devices/system/cpu/vulnerabilities/spec_store_bypass:Vulnerable
/sys/devices/system/cpu/vulnerabilities/spectre_v1:Mitigation: __user pointer sanitization
/sys/devices/system/cpu/vulnerabilities/spectre_v2:Mitigation: Software count cache flush
X5000/020, CPU: P5020 (e5500), kernel 4.20-rc3: grep . /sys/devices/system/cpu/vulnerabilities/*
/sys/devices/system/cpu/vulnerabilities/meltdown:Not affected
/sys/devices/system/cpu/vulnerabilities/spec_store_bypass:Not affected
Re: CPU vulnerabilities
I reported the PA6T vulnerabilities to the Linux PPC developers today.
Link: https://lists.ozlabs.org/pipermail/linuxppc-dev/2018-November/181780.html
The P5020 CPU doesn’t have any problems with vulnerabilities with the latest Linux kernels! :-)
Have a nice week!
FYI:
X1000, CPU: PWRficient PA6T-1682M, kernel 4.21-alpha3: grep . /sys/devices/system/cpu/vulnerabilities/*
/sys/devices/system/cpu/vulnerabilities/spectre_v2:Vulnerable
CPU information (cpuinfo) with the kernel 5.16 on an AmigaOne X1000:
cat /proc/cpuinfo
processor	: 0
cpu		: PA6T, altivec supported
clock		: 1800.000000MHz
revision	: 1.2 (pvr 0090 0102)
processor	: 1
timebase	: 66666666
platform	: A-EON Amigaone X1000
model		: pasemi,nemo
lscpu
Architecture:                    ppc64
CPU op-mode(s):                  32-bit, 64-bit
Byte Order:                      Big Endian
CPU(s):                          2
On-line CPU(s) list:             0,1
Thread(s) per core:              1
Core(s) per socket:              2
Socket(s):                       1
Model:                           1.2 (pvr 0090 0102)
Model name:                      PA6T, altivec supported
L1d cache:                       128 KiB
L1i cache:                       128 KiB
Vulnerability Itlb multihit:     Not affected
Vulnerability L1tf:              Vulnerable
Vulnerability Mds:               Not affected
Vulnerability Meltdown:          Vulnerable
Vulnerability Spec store bypass: Vulnerable
Vulnerability Spectre v1:        Mitigation; __user pointer sanitization
Vulnerability Spectre v2:        Vulnerable
Vulnerability Srbds:             Not affected
Vulnerability Tsx async abort:   Not affected
Link: The PA6T is still vulnerable
Hypex
Post by Hypex »
No change in three years? :o
