Ok, this is another annoying behaviour i remembered, when i stumbled over it while testing another bug.
Affected programs:
Notepad 53.16 (19.5.2016)
Steps to reproduce:
1) Open Notepad
2) Bring up it's "About" window
Now try to open *any* pull down menu from either workbench or any other program that is running.
The menu will come up (well, the headlines) on clicking the right mouse button (eiher the original Screenbar or with ContextMenues), but no subentries will draw and/or could be chosen.
Notes:
I remember reporting this bug years ago in some other forum and i think i remember i was being told that workbench runs out of pens (blame my memory if it is completly wrong), but even though, should that be still the case today and can't it be fixed?
Other programs affected:
Probably all programs that feature more child windows being open at once, but i could only make it happen with one other.
MUI programs (Odyssey i.e.) doesn't suffer from this behaviour, so i guess it' could also be a ReAction problem?
- MultiEdit - open the "Find & Replace" window AND the About window and the same effect happens, but Notepad is easier to test.
BUG: Notepad's About window will lock out any PD-Menus
People are dying.
How dare you!
– Greta Thunberg
How dare you!
– Greta Thunberg
- broadblues
Re: BUG: Notepad's About window will lock out any PD-Menus
THis is probably because of IDCMP_MENUVERIFY not being dealt with in some way.
Note if you hold the right mouse buttons down the menus will open eventually as there is specific work arround for this in intuition, at as far as I remeber from other discussions.
In notepads case I suspect the reason it occurs is that the main NotePad window has not been disabled by opening the about window, but opening that window stops the main window event loop from being serviced. This should be easy to fix.
MultiEdit is more subtle because the main window is disabled by the about window opening. However the search window multitasks with the main window and isn't disabled. (because I didn;t think of it!) so causes a similar block. The search window doesn't have any menus though, so I might just be able tweek the IDCMP flags to fix that.
This issue occurs in a number of applications, for example AudioEvolution has it when the sample list window is open.
Ahh, you are right...i never thought of keeping the mouse button pressed...takes 2-3 seconds but the menues come up finally, neat trick.broadblues wrote:THis is probably because of IDCMP_MENUVERIFY not being dealt with in some way.
Still not elegant in the first place
PerfectIn notepads case I suspect the reason it occurs is that the main NotePad window has not been disabled by opening the about window, but opening that window stops the main window event loop from being serviced. This should be easy to fix.
That's what i am here for (thinking of that)MultiEdit is more subtle because the main window is disabled by the about window opening. However the search window multitasks with the main window and isn't disabled. (because I didn;t think of it!) so causes a similar block. The search window doesn't have any menus though, so I might just be able tweek the IDCMP flags to fix that.
So, it's a per-app issue?This issue occurs in a number of applications, for example AudioEvolution has it when the sample list window is open.
Too bad, i thought a general fix might be possible
Thanks for the feedback
People are dying.
How dare you!
– Greta Thunberg
How dare you!
– Greta Thunberg
- broadblues
The 'general fix' is the inution timeout which you see when holding down the RMB.
Both these two instances have now been fixed in NotePad 53.17 and MultiEdit 1.9 subject to testing etc....
Thank you for letting me know
People are dying.
How dare you!
– Greta Thunberg
How dare you!
– Greta Thunberg
