Kernel 4.20
Kernel 4.20
Maybe this will be a problem later: ff69279a44e9ba876466b7d3ab84d6dbd31cac92
FSL/NXP P5020: USB problems with the latest Git kernels:
While it would be nice to fix this ordering dependency at some point, the
change was reverted on PPC by commit ff69279a44e9ba876466 ("powerpc: disable
support for relative ksymtab references").
-Scott
Re: Kernel 4.20/5.0
git clone --depth=1 git://git.kernel.org/pub/scm/linux/kernel/git/next/linux-next.git a
Re: Kernel 4.20/5.0
The first alpha of kernel 4.20 (5.0) is available for the X1000 and X5000.
Download: vmlinux-4.20-alpha1-AmigaOne_X1000_X5000.tar.gz
Re: Kernel 4.20/5.0
And here it is, 4.20 running on the AmigaOne X5000! Keep em coming :-)
Re: Kernel 4.20/5.0
Skateman wrote:And here it is, 4.20 running on the AmigaOne X5000! Keep em coming :-)
Re: Kernel 4.20/5.0
4.20 installed and running fine. Thanks.
Re: Kernel 4.20/5.0
acefnq wrote:4.20 installed and running fine. Thanks.
Many thanks for testing! :-)
I compiled the alpha2 today.
Download: vmlinux-4.20-alpha2-AmigaOne_X1000_X5000.tar.gz
Re: Kernel 4.20/5.0
Alpha2 is up and running on the X5000.
Re: Kernel 4.20/5.0
Beaten by Skateman again!-:) Alpha2 up and running fine. Thanks
Re: Kernel 4.20/5.0
Skateman wrote:Alpha2 is up and running on the X5000.
Thank you for testing the alpha2! :-)
