Is it worth adding a swap partition?
daveyw
Post by daveyw »
My A1XE has only 1 GB RAM, so I added a 1GB Swap partition. I'm not sure it ever worked or got used.
My X5000 has 2 GB RAM. Is it worth adding a swap partition, or with 2 GB being the max is this pointless?
K-L
Re: Is it worth adding a swap partition?
Post by K-L »
With 2GB, it's useless.
daveyw wrote:My A1XE has only 1 GB RAM, so I added a 1GB Swap partition. I'm not sure it ever worked or got used.
2 GB RAM (may it be physical or "virtual" through a swap partition) is still the maximum AmigaOS4 can use.
I think it is because of the 32bit technic AmigaOS4 uses.
"More" is only possible/usable thorugh memory tricking (i think it's called "bank switching" or something like that) and it needs to be compiled into every single program...
People are dying.
How dare you!
– Greta Thunberg
daveyw
Post by daveyw »
Raziel wrote: "More" is only possible/usable thorugh memory tricking (i think it's called "bank switching" or something like that) and it needs to be compiled into every single program...
Ah, bank switching. I remember that from my old Atari 130XE.
Yes, someone on some other forum mentioned that this trick goes back to the early computer days.
If it helps using more than 2 GB of RAM...
People are dying.
How dare you!
– Greta Thunberg
trixie
Post by trixie »
Exactly. Despite the technique being simple and ancient, it's better than having the extra memory completely unusable. Programs working with large data (such as a sound- or video editor) may use it as a handy storage, rather than swapping out to disk. I can certainly imagine such scenarios.
The Rear Window blog
I *think* it being already out in the wild, but i'm not sure if it is supported yet?
SDK support, OS support?
There's already some rudimentary information on the wiki
People are dying.
How dare you!
– Greta Thunberg
