Hello,
I'm testing the new AmigaOS3.1.4 on my A2000, 2MB chip, 4MB fast, 68000
It refuses to format a 8GB partition with FFS. Error validating <my partition name> not enough memory available.
Is is "normal" or not ?
So I use pfs3aio instead...
8GB partition format FFS v46 AmigaOS3.1.4 genuine A2000
Re: 8GB partition format FFS v46 AmigaOS3.1.4 genuine A2000
All versions of FFS have the issue that they need a lot of RAM to build the bitmap. As a rule of thumb you need ca. 1 MB of memory per GB partition size.
What's new with 3.1.4 is that it actually tells you what the reason is instead of just sitting there with an unvalidated volume.
I’m thinking of installing new Workbench on A2000 is it easy
Anoth to install, is there a install disk? Some kind of ADF file’s
Or do I need to wait until it is relseased on Floppy’s?
The AmigaOS3.1.4 is working fine, better than 3.1 for coping big amount of files from workbench.marley wrote:I’m thinking of installing new Workbench on A2000 is it easy
A lot of gadget rendering bugs have been fixed (ScreenMode for example...)
I just notice this problem with FFS, but Thomas has answered on that point (pfs3aio is better
Rather than trying to store the entire bitmap somewhere in memory, why not split it into several chunks, and write/read them in a LRU scheme ?
Return to the subject...
The archive contains 6 main disks
Workbench3_1_4.adf
Extras3_1_4.adf
Fonts.adf
Locale.adf
Storage3_1_4.adf
Install3_1_4.adf
and another disk to transform 3.1 ROM into 3.1.4 in memory (still working the machine is power on)
ModulesA2000_3.1.4.adf
There are also ROM images for WinUAE and for burning a true ROM.
To transfer these adfs, I use an usb disk (formatted in pfs3aio with WinUAE) and tsgui to copy on true floppy disks.
http://aminet.net/package/disk/misc/tsgui
A lot of AmigaOS3.1.4 programs (perhaps all programs) are working with 3.1
The ROM 3.1.4 is not mandatory to use AmigaOS3.1.4
With WinUAE, the package for A2000 68000 is also working well with uaegfx and Picasso96.
I was expecting this update since a long time.
