MagicWB colours in 3.1.4
sibbi
Post by sibbi »
Noticed after installation that the MagicWB colour setting in the Workbench prefs is not maintained if iPrefs needs to reset the WB screen.
For example, if you go into the WB Prefs, set the checkmark, save and go into WBPattern the colours are there.
If you then set a pattern and a WB screen reset is needed, changes are that the colours have reverted to the standard 8 colour palette.
It also doesn't hold if you change the palette to a different preset (say Chocolate for example), i.e. it doesn't hold the later 4 colours to the MagicWB colours
Mark Sealey
Re: MagicWB colours in 3.1.4
Post by Mark Sealey »
Im using magic workbench....had no issues here...16 colours tho
Mark Sealey
Guess you have sorted this problem as theres no reply :(
