How to manually start the startup-sequence?
Corporal Up The Nuts
Post by Corporal Up The Nuts »
Hello
I've been trouble shooting my machine and I wonder how one can start the startup-sequence
after booting without it via the early startup menu?
I know of typing "loadwb" in shell to start workbench but startup-seqeunce can be activated by shell as well right?
If my memory serves me it was by going to AmigaOS\S and then typing either "Shell-Startup" or "Startup-sequence"
but I get a error message saying that the files are not executables, so do I need to change the protection settings?
Cheers
trixie
Re: How to manually start the startup-sequence?
Post by trixie »
execute s:startup-sequence
The Rear Window blog
LyleHaze
Post by LyleHaze »
If you want to skip the "Execute" part, try:
protect s:startup-sequence +s
That will mark it as a script.
Thank you trixie and Lyle
Both did the trick
