CD/DVD burning
CD/DVD burning
When i try to "backup" my system to CD or DVD, there is an error from AmiDVD which says: Error opening 'L:slb_v2' : object not found. I have looked everywhere, even on my Boot-USB but to no avail. Any ideas anyone?
Re: CD/DVD burning
I'm not sure if the X5000 even needs a SLB but if it does you can get a copy of the installed SLB with MediaToolbox.
- start SYS:System/MediaToolbox
- select your Harddrive
- click Edit RDB
- there is a box labeled "AmigaOne bootcode (SLB)" and in it is a "save to file" button
- click Edit RDB
Re: CD/DVD burning
Danke mein FreundZeroG wrote:I'm not sure if the X5000 even needs a SLB but if it does you can get a copy of the installed SLB with MediaToolbox.
- click Edit RDB
I shall take a peek
Re: CD/DVD burning
The X5k does not use SLB.ZeroG wrote:I'm not sure if the X5000 even needs a SLB but if it does you can get a copy of the installed SLB with MediaToolbox.
Re: CD/DVD burning
The "save to file" button next to "AmigaOne bootcode (SLB)" is disabled because (as SMF stated) there is no SLB (slb_v2) for the X5000. I think the "Install" button should have been disabled too; you don't want to press that button on an X5000.Steff wrote:Danke mein Freund- there is a box labeled "AmigaOne bootcode (SLB)" and in it is a "save to file" button
I shall take a peek
Re: CD/DVD burning
Ok. I have tried all work arounds here but nothing is working. The CD/DVD rom is not recognised in the system as a blank medium. Secondly, the error output is:
SCSI command 00 00 00 00 00 00 failed, err=-3
etc, and that is all that happens.
Any ideas anyone?
Any ideas anyone?
Re: CD/DVD burning
If i might take a guess i'd say AmiDVD wasn' updated to work with the new hardware X5000.
I remember this SCSI command error bug from when i switched to the X1000 and i think i remember there was an update to the program to get rid of it.
So, you might be out of luck, or you could try "FryingPan" ( a little tedious to set up nowadays)
Re: CD/DVD burning
Which version of AmiDVD is it? IIRC, only the one in the Enhancer Pack supports the X5000.
Re: CD/DVD burning
Hello Niels.nbache wrote:Which version of AmiDVD is it? IIRC, only the one in the Enhancer Pack supports the X5000.
Some more error messages when starting the AmiDVD:
SCSI command 46 00 00 00 00 00 00 10 00 00 failed
sense: 70 00 05 00 00 00 00 0a 00 00 00 00 20 00 00 00 00 00
SCSI command 5a 00 2a 00 00 00 00 00 64 00 failed
And the version you asked for is: RAWBinfo 53.19 (9.3.2014)
Copyright (C) 2000-2012 Hyperion Entertainment CVBA
Most frustrating !!
Re: CD/DVD burning
@Steff
That, however, is the version of RAWBInfo (the component that displays program information in Workbench), not of AmiDVD. You need to click on the Version button in the Workbench Information window to retrieve the version. Or open Shell, go to the AmiDVD directory, and type "version AmiDVD".
The Rear Window blog
