and running into the following situation...
during ramlib execution of the device "DevInit" and eventually passing through "InitUnit()"
I can use the expansion.library "IPCI" Interface and get a valid pcidev=IPCI->FindDeviceTags(...) result...
However when using the IPCI interface from within the Unit specific Task created... I keep getting a NULL pcidev from exact search parameters (including an index of which unit it is).
This is what runs during DevInit...
if((Base = IExec->OpenLibrary("expansion.library",0L)))
Self->IExpansion = (APTR)IExec->GetInterface(Base,"main",1L,NULL);
Self->IPCI = (APTR)IExec->GetInterface(Base,"pci",1L,NULL);
for(hwcnt=0UL;hwcnt<DEVICE_UNIT_COUNT;hwcnt++)
pcidev=Self->IPCI->FindDeviceTags(
FDT_Class, 0x000C0330,
FDT_ClassMask, 0x00FFFFFF,
FDT_Index, hwcnt,
TAG_DONE, TAG_DONE
if(pcidev)
InitUnit(Self,pcidev,hwcnt);
IExec->DropInterface((APTR)pcidev);
if(Unit->IPCI)
Unit->uCard=Unit->IPCI->FindDeviceTags(
FDT_Index, Unit->unitn,
TAG_DONE, TAG_DONE
KDEBUG("XHCI /UnitTask/ unit->uCard[%lx,%lx]\n",unitn,Unit->uCard);
VOID InitUnit(struct DEVICE_CLASS *Base, struct PCIDevice *card, uint32 unitn)
struct DEVICE_UNIT_CLASS *unit=NULL;
if(card)
unit=Base->IExec->AllocVecTags(DEVICE_UNIT_SIZE,AVT_Type,MEMF_SHARED,AVT_ClearWithValue,0L,TAG_DONE,TAG_DONE);
if(unit)
Base->IExec->InitSemaphore((APTR)unit);
unit->unitn=unitn;
Base->IExec->ObtainSemaphore((APTR)unit);
unit->InterruptService.is_Node.ln_Name=(APTR)xHCIdevInterruptName;
unit->InterruptService.is_Data=unit;
unit->InterruptService.is_Code=(APTR)&HwInterruptService;
Base->IExec->NewList(&unit->uQueue);
HwCardReset(card);
unit->uTask=Base->IExec->CreateTaskTags("XHCI Controller Task", UNIT_TASK_PRIORITY, &ExecUnitTask, UNIT_STACK_SIZE,
AT_Param1, (uint32)Base->IExec, AT_Param2, (uint32)unit, AT_Param3, (uint32)Base, CT_LockStack, TRUE, TAG_DONE );
if(unit->uTask)
Base->IExec->AddIntServer(card->MapInterrupt(),&unit->InterruptService);
Base->Library.lib_OpenCnt++;
Base->IExec->ReleaseSemaphore((APTR)unit);
return;
'I am also still to work on expanding the HwInterruptService() function to handle controller specific Interrupts ( I'm also specifically allocating it this way since I will be possibly handling multiple XHCI controllers and they all apparently talk with the OS the same way (just different locations for pre-defined register blocks.
or that is at least what the XHCI specification documentation appears to read like so far.
(I still think I have missed something after reading all the documentation through 3-4 times too)
