Compatibility list
samo79
Compatibility list
Post by samo79 »
I decide to open this thread to show how certain old 68/WOS apps/games react under OS4, for now i did all my test on my SamFlex 800 machine, if not different specified all test has to be considered on this platform:
ACube Sam440ep Flex 800 Mhz (+ Sam440ep Setup 1.2)
1 GB RAM
ATI Radeon 9250 128 MB (64 Bit)
AmigaOS 4.1 Update 3 (Vanilla)
The first game i like to test is Virtual Ball Fighter
Virtual Ball Fighter RTG Demo
- Download the game from:
http://aminet.net/package/game/demo/Vir ... ghters_RTG
- Download OS4 RTGMaster from:
http://os4depot.net/index.php?function= ... os4fix.lha
- Create manually an RTG folder in Libs named as "rtg" and put the files rtgP96.library and rtgAMI.library into it
- Create an assign on your user startup:
assign VBF: <path where is VBFGame >
assign FONTS: VBF:FONTS ADD
Now if you start the game you get a DSI crash (or directly an ISI one if you set an incorrect audio setup):
DSI crash:
Hidden Text - Click to Show :
Crash log for task "VBFGameRTG040_demo"
Generated by GrimReaper 53.2
Crash occured in module kernel at address 0x018419D0
Register dump:
0: 00000003 5534DC00 00000000 00000000 5534DC08 5534DDA0 5534DDA0 561D1780
8: 00000000 66139DE8 A00840AE 66139DF0 84422028 00000000 5534FFFC 5533E004
16: 154DA001 02270000 8000000F 8000000E 8000000D FFFFFFFF 00000000 581A8853
24: 020A97C4 80000008 FFD60001 80000007 FFD50001 80000006 80090002 5FF9A000
0: nan 77 50 0
4: 0 93.8 30.8 0
8: 0 2.78132e-309 93.8 30.8
12: 171 81 0 -0
16: 0 0 0 0
20: 0 0 0 1.61895e-319
24: 0 0 2.65249e-315 -1.28745e+36
28: 0 1.35808e-312 8.8275e-311 -3.40282e+38
Machine State (msr) : 0x0002F030
Condition (cr) : 0x44422044
Instruction Pointer (ip) : 0x018419D0
Xtended Exception (xer) : 0x00000007
Count (ctr) : 0x018419B8
Link (lr) : 0x018417A0
DSI Status (dsisr) : 0x00000000
Data Address (dar) : 0x66139DF0
680x0 emulated registers:
DATA: 5FFB5CCC 00010000 00000001 000001E0 00000280 000001E0 FFD60001 55368004
ADDR: 00000000 581A8853 5534DDA0 5537E554 5534DFFC 5534DF30 5FFB5CCC 5534DD9C
FPU0: 0 0 0 0
FPU4: 0 0 0 0
Symbol info:
Instruction pointer 0x018419D0 belongs to module "kernel" (HUNK/Kickstart)
Stack trace:
native kernel module kernel+0x000419d0
native kernel module kernel+0x00041878
module LIBS:locale.library at 0x6FFF3E50 (section 5 @ 0x1E30)
module LIBS:locale.library at 0x6FFFF140 (section 5 @ 0xD120)
native kernel module kernel+0x0005472c
PPC disassembly:
018419c8: 2f8b0000 cmpwi cr7,r11,0
018419cc: 419e006c beq- cr7,0x1841A38
*018419d0: 800b0000 lwz r0,0(r11)
018419d4: 2f800001 cmpwi cr7,r0,1
018419d8: 2b000001 cmplwi cr6,r0,1
System information:
CPU
Model: AMCC PPC440EP V1.3
CPU speed: 799 MHz
FSB speed: 133 MHz
Extensions:
Machine
Machine name: Sam440EP
Memory: 1048576 KB
Extensions: bus.pci
Expansion buses
PCI/AGP
00:00.0 Vendor 0x1014 Device 0x027F
Range 1: 00000000 - 40000000 (PREF.MEM)
00:0A.0 Vendor 0x12D8 Device 0x8150
00:0C.0 Vendor 0x1002 Device 0x5960
Range 0: A8000000 - B0000000 (PREF.MEM)
Range 1: 00001000 - 00001100 (IO)
Range 2: B0000000 - B0010000 (MEM)
00:0C.1 Vendor 0x1002 Device 0x5940
Range 0: B8000000 - C0000000 (PREF.MEM)
Range 1: C0000000 - C0010000 (MEM)
00:0E.0 Vendor 0x1095 Device 0x3114
Range 0: 00001100 - 00001108 (IO)
Range 1: 00001108 - 00001110 (IO)
Range 2: 00001110 - 00001118 (IO)
Range 3: 00001118 - 00001120 (IO)
Range 4: 00001120 - 00001130 (IO)
01:04.0 Vendor 0x1013 Device 0x6005
Range 0: A0000000 - A0001000 (MEM)
Range 1: A0010000 - A0020000 (MEM)
01:05.0 Vendor 0x1033 Device 0x0035
Range 0: A0020000 - A0021000 (MEM)
01:05.1 Vendor 0x1033 Device 0x0035
Range 0: A0021000 - A0022000 (MEM)
01:05.2 Vendor 0x1033 Device 0x00E0
Range 0: A0022000 - A0022100 (MEM)
Libraries
0x58d5cf68: ISO-8859-15.charset V52.1
0x58d5ce68: italian_ISO-8859-15.language V52.1
0x021bd7f6: exec.library V53.22
0x5ff62174: vilintuisup.library V0.9
0x5ff62048: cgxvideo.library V42.1
0x5ff6b0e0: cybergraphics.library V43.0
0x569e94a8: Generic_Keyboard.driver V52.1
0x569e9568: PCI_SoundCardHornet.driver V52.2
0x569e9628: PCI_sblive.pci V52.1
0x569e9868: PCI_Soundcard.driver V52.2
0x569e96e8: PCI_GamePortHornet.driver V52.2
0x569e97a8: PCI_GamePort.driver V53.1
0x561ed558: Generic_usb.driver V53.3
0x581dc028: Generic_Mouse.driver V52.1
0x57220018: AmigaInput.library V53.1
0x5721e414: lowlevel.library V52.3
0x5721e2a0: rtgmaster.library V40.0 (Legacy)
0x58613e40: rtgP96.library V42.0 (Legacy)
0x586136f0: rtgAMI.library V43.0 (Legacy)
0x561d0f00: powerpc.library V16.41
0x560d4128: Separator.docky V53.2
0x560efa20: slider.gadget V53.12
0x560ef660: arexx.class V53.3
0x560ef3e0: getfont.gadget V53.8
0x561ed798: cs4281.audio V5.5
0x560ef5c0: getfile.gadget V53.10
0x561d1190: requester.class V53.18
0x560ef160: bitmap.image V53.9
0x560ef0c0: space.gadget V53.6
0x572649b0: integer.gadget V53.10
0x562fc658: screenblanker.library V53.3
0x561ed278: clicktab.gadget V53.38
0x581dddf4: device.audio V6.2
0x58cf9958: chooser.gadget V53.18
0x57264910: penmap.image V53.5
0x572647d0: checkbox.gadget V53.9
0x5fc98308: listbrowser.gadget V53.49
0x57220500: string.gadget V53.16
0x57264730: scroller.gadget V53.11
0x58cf9894: filesave.audio V6.3
0x5fc97664: asl.library V53.45
0x581891a8: emulation.library V41.446
0x586b3de0: mathieeedoubbas.library V52.1
0x5874a5d4: usergroup.library V4.30
0x5841a320: bsdsocket.library V4.292
0x5850c43c: textclip.library V52.2
0x5886eb04: xpkmaster.library V5.2
0x58a05a5c: xadmaster.library V13.1
0x588b9d68: usbhidgate.library V52.2
0x5ff98cec: hid.usbfd V53.7
0x58c2ac30: button.gadget V53.14
0x58c2ad70: glyph.image V53.3
0x58c65c90: window.class V53.42
0x58b64158: popupmenu.class V53.2
0x58cd77e8: popupmenu.library V53.5
0x58c2aa50: label.image V53.12
0x58af6e78: layout.gadget V53.19
0x58b64060: bevel.image V53.6
0x58c2a7d0: drawlist.image V53.3
0x58c2a230: png.datatype V53.6
0x58b09674: picture.datatype V53.6
0x5970ec48: timezone.library V53.6
0x58cd8988: application.library V53.12
0x58cf925c: ft2.library V53.1
0x58cc208c: workbench.library V53.37
0x58cf7ed0: Picasso96API.library V2.356
0x58d0ed00: gadtools.library V53.4
0x5fffbcac: commodities.library V53.1
0x58d4b140: datatypes.library V53.4
0x5fda5e54: png.iconmodule V53.1
0x58d270cc: icon.library V53.13
0x5fe15918: version.library V53.7
0x58d5ea40: iffparse.library V53.1
0x5ffb5ccc: locale.library V53.3
0x5ff8b41c: diskfont.library V53.4
0x5fce61a8: petunia.library V53.3
0x5fce6028: diskcache.library V3.30
0x5fcbb654: dos.library V53.76
0x5ff62444: usbprivate.library V53.11
0x5ff3f13c: massstorage.usbfd V53.13
0x5ff3f0a8: bootkeyboard.usbfd V52.3
0x5ff3f028: bootmouse.usbfd V53.1
0x5ff622fc: hub.usbfd V53.8
0x5ff6224c: usbresource.library V53.11
0x5ff8a658: hunk.library V53.4
0x5ff98354: elf.library V53.14
0x5ff924d0: intuition.library V53.32
0x5ff48150: rtg.library V41.4355
0x5ff9b820: ATIRadeon.chip V53.23
0x5ff9b7a4: PCIGraphics.card V53.1
0x5ff9d7a0: keymap.library V53.3
0x5ff88500: layers.library V53.6
0x5ffb4420: graphics.library V53.4
0x5ff8a184: nonvolatile.library V52.1
0x5ff9e318: newlib.library V53.18
0x5ff991ac: utility.library V53.3
0x5ff9d0a8: expansion.library V53.1
0x58756cae: rexxsyslib.library V45.7 (Legacy)
Devices
0x58d5e254: ahi.device V6.6
0x58b66604: ppp-serial.device V52.2
0x582eb018: ppc440ep_eth.device V53.6
0x588b9ad4: diskimage.device V52.75
0x5fda48b8: usbdisk.device V53.13
0x5ff99d10: usbsys.device V53.11
0x5ff8acd0: ehci.usbhcd V53.15
0x5ff8ac30: ohci.usbhcd V53.18
0x5ff8ab90: uhci.usbhcd V53.7
0x5ff8aa24: sii3114ide.device V53.8
0x5fffb628: console.device V53.1
0x5ff9a3f0: ramdrive.device V52.6
0x5ff9d9ec: input.device V53.3
0x5fffb314: keyboard.device V53.5
0x5ff9a2d0: timer.device V53.1
Tasks
ClickToFront (Waiting)
Stack: 0x561f4004 - 0x56203ffc, pointer @ 0x56203a80 (Cookie OK)
State: Process (Waiting)
input.device (Waiting)
Stack: 0x5ff50000 - 0x5ff60000, pointer @ 0x5ff5ff00 (Cookie OK)
State: Task (Waiting)
SFS DosList handler (Waiting)
Stack: 0x5fc4d004 - 0x5fc4effc, pointer @ 0x5fc4ef20 (Cookie OK)
USB stack (Waiting)
Stack: 0x5fec4000 - 0x5fec8000, pointer @ 0x5fec7f20 (Cookie OK)
OHCI Controller Task Unit 0 (Waiting)
Stack: 0x5fe2f000 - 0x5fe37000, pointer @ 0x5fe36f20 (Cookie OK)
Signals: SigRec 0xbc009000, SigWait 0x00000000
EHCI Controller Task Unit 0 (Waiting)
Stack: 0x5fdeb000 - 0x5fdf3000, pointer @ 0x5fdf2f20 (Cookie OK)
Signals: SigRec 0xbe009000, SigWait 0x00000000
OHCI Controller Task Unit 1 (Waiting)
Stack: 0x5fe0b000 - 0x5fe13000, pointer @ 0x5fe12f20 (Cookie OK)
sii3114ide.device - chip 0 port 0 (Waiting)
Stack: 0x5fe9f000 - 0x5fea7000, pointer @ 0x5fea6f20 (Cookie OK)
page_sweep (Waiting)
Stack: 0x5fe47004 - 0x5fe4effc, pointer @ 0x5fe4ee80 (Cookie OK)
sii3114ide.device - chip 0 port 1 (Waiting)
Stack: 0x5fe6f000 - 0x5fe77000, pointer @ 0x5fe76f20 (Cookie OK)
ppc440ep_eth Unit 0 (Waiting)
Stack: 0x582d2004 - 0x582e2ffc, pointer @ 0x582e2f20 (Cookie OK)
Signals: SigRec 0xf6001000, SigWait 0x00000000
hid.usbfd (Waiting)
Stack: 0x5fcdb004 - 0x5fce2ffc, pointer @ 0x5fce2ee0 (Cookie OK)
Signals: SigRec 0xe0000000, SigWait 0x00000100
HID Joystick (Waiting)
Stack: 0x58801004 - 0x58810ffc, pointer @ 0x58810f20 (Cookie OK)
reaper.task (Waiting)
Stack: 0x59294004 - 0x5929bffc, pointer @ 0x5929bea0 (Cookie OK)
DH0 (Waiting)
Stack: 0x5fc47004 - 0x5fc48ffc, pointer @ 0x5fc48eb0 (Cookie OK)
hid.usbfd (Waiting)
Stack: 0x58881004 - 0x58888ffc, pointer @ 0x58888ee0 (Cookie OK)
HID Mouse (Waiting)
Stack: 0x5881d004 - 0x5882cffc, pointer @ 0x5882cf20 (Cookie OK)
DH1 (Waiting)
Stack: 0x5fc5f004 - 0x5fc60ffc, pointer @ 0x5fc60eb0 (Cookie OK)
ICD0 (Waiting)
Stack: 0x58521004 - 0x58530ffc, pointer @ 0x58530f20 (Cookie OK)
ICD1 (Waiting)
Stack: 0x5859c004 - 0x585abffc, pointer @ 0x585abf20 (Cookie OK)
USB0 (Waiting)
Stack: 0x58929004 - 0x58938ffc, pointer @ 0x58938ee0 (Cookie OK)
Signals: SigRec 0x00010100, SigWait 0x00000000
RAM (Waiting)
Stack: 0x592ec004 - 0x592f3ffc, pointer @ 0x592f3c90 (Cookie OK)
DH2 (Waiting)
Stack: 0x5fc59004 - 0x5fc5affc, pointer @ 0x5fc5aeb0 (Cookie OK)
CD0 (Waiting)
Stack: 0x5fc53004 - 0x5fc54ffc, pointer @ 0x5fc54f20 (Cookie OK)
MainUSB0 (Waiting)
Stack: 0x58915004 - 0x58924ffc, pointer @ 0x58924eb0 (Cookie OK)
Signals: SigRec 0x40000100, SigWait 0x00000000
dos_filedir_notify (Waiting)
Stack: 0x5fcab004 - 0x5fcaeffc, pointer @ 0x5fcaeae0 (Cookie OK)
Signals: SigRec 0x10000000, SigWait 0x00000000
MainIPC0 (Waiting)
Stack: 0x58839004 - 0x58848ffc, pointer @ 0x58848eb0 (Cookie OK)
HID Consumer (Waiting)
Stack: 0x587e1004 - 0x587f0ffc, pointer @ 0x587f0f20 (Cookie OK)
hid.usbfd (Waiting)
Stack: 0x58875004 - 0x5887cffc, pointer @ 0x5887cee0 (Cookie OK)
HID Keyboard (Waiting)
Stack: 0x587c5004 - 0x587d4ffc, pointer @ 0x587d4f20 (Cookie OK)
Signals: SigRec 0x90001000, SigWait 0x00000000
hid.usbfd (Waiting)
Stack: 0x5fd31004 - 0x5fd38ffc, pointer @ 0x5fd38ee0 (Cookie OK)
pager (Waiting)
Stack: 0x58e3c004 - 0x58e5bffc, pointer @ 0x58e5bf00 (Cookie OK)
ENV (Waiting)
Stack: 0x58e22004 - 0x58e23ffc, pointer @ 0x58e23e00 (Cookie OK)
IDF0 (Waiting)
Stack: 0x585e9004 - 0x585f8ffc, pointer @ 0x585f8ed0 (Cookie OK)
Signals: SigRec 0xa8000100, SigWait 0x00000000
IDF1 (Waiting)
Stack: 0x5863a004 - 0x58649ffc, pointer @ 0x58649ed0 (Cookie OK)
IDF2 (Waiting)
Stack: 0x58687004 - 0x58696ffc, pointer @ 0x58696ed0 (Cookie OK)
IDF3 (Waiting)
Stack: 0x586d8004 - 0x586e7ffc, pointer @ 0x586e7ed0 (Cookie OK)
MassStorage Device Task (Waiting)
Stack: 0x5fc9b000 - 0x5fca3000, pointer @ 0x5fca2e70 (Cookie OK)
Signals: SigRec 0xf3009000, SigWait 0x00000000
IPC0 (Waiting)
Stack: 0x58855004 - 0x58864ffc, pointer @ 0x58864ee0 (Cookie OK)
URL (Waiting)
Stack: 0x58426004 - 0x584a0ffc, pointer @ 0x5849ca90 (Cookie OK)
CON (Waiting)
Stack: 0x56118004 - 0x56127ffc, pointer @ 0x56127de0 (Cookie OK)
CON (Waiting)
Stack: 0x561a0004 - 0x561afffc, pointer @ 0x561afde0 (Cookie OK)
CON (Waiting)
Stack: 0x56235004 - 0x56244ffc, pointer @ 0x56244de0 (Cookie OK)
CON (Waiting)
Stack: 0x5629a004 - 0x562a9ffc, pointer @ 0x562a9de0 (Cookie OK)
CON (Waiting)
Stack: 0x56323004 - 0x56332ffc, pointer @ 0x56332de0 (Cookie OK)
AUDIO (Waiting)
Stack: 0x583e0004 - 0x583efffc, pointer @ 0x583efec0 (Cookie OK)
CON (Waiting)
Stack: 0x592a0004 - 0x592a7ffc, pointer @ 0x592a7de0 (Cookie OK)
RAW (Waiting)
Stack: 0x59308004 - 0x5930fffc, pointer @ 0x5930fde0 (Cookie OK)
CON (Waiting)
Stack: 0x59314004 - 0x5931bffc, pointer @ 0x5931bde0 (Cookie OK)
dos_nbmd_process (Waiting)
Stack: 0x5ff20004 - 0x5ff21ffc, pointer @ 0x5ff21f20 (Cookie OK)
dos_lock_handler (Waiting)
Stack: 0x5ff1a004 - 0x5ff1bffc, pointer @ 0x5ff1bf00 (Cookie OK)
console.device (Waiting)
Stack: 0x5ff00000 - 0x5ff08000, pointer @ 0x5ff07f70 (Cookie OK)
Signals: SigRec 0xf0000000, SigWait 0x00000000
RexxMaster [] (Waiting)
Stack: 0x58202004 - 0x58211ffc, pointer @ 0x58211f50 (Cookie OK)
Stack: 0x584ee004 - 0x58501ffc, pointer @ 0x58501c30 (Cookie OK)
Stack: 0x5856d004 - 0x58580ffc, pointer @ 0x58580c30 (Cookie OK)
Stack: 0x585c9004 - 0x585dcffc, pointer @ 0x585dcc30 (Cookie OK)
diskimage.device unit 1 (Waiting)
Stack: 0x5861a004 - 0x5862dffc, pointer @ 0x5862dc30 (Cookie OK)
diskimage.device unit 2 (Waiting)
Stack: 0x58667004 - 0x5867affc, pointer @ 0x5867ac30 (Cookie OK)
diskimage.device unit 3 (Waiting)
Stack: 0x586b8004 - 0x586cbffc, pointer @ 0x586cbc30 (Cookie OK)
diskimage.device unit 6 (Waiting)
Stack: 0x586f4004 - 0x58707ffc, pointer @ 0x58707c30 (Cookie OK)
TEXTCLIP (Waiting)
Stack: 0x583fe004 - 0x5840dffc, pointer @ 0x5840deb0 (Cookie OK)
compose.task (Ready)
Stack: 0x57277000 - 0x5727f000, pointer @ 0x5727ef30 (Cookie OK)
Signals: SigRec 0x00000021, SigWait 0x00000020
State: Task (Ready)
Workbench [Workbench] (Waiting)
Stack: 0x581b1004 - 0x581c0ffc, pointer @ 0x581c0ea0 (Cookie OK)
Signals: SigRec 0x80000000, SigWait 0x00008000
ramlib (Waiting)
Stack: 0x58d92004 - 0x58daaffc, pointer @ 0x58daaf20 (Cookie OK)
Stack: 0x564e6004 - 0x564f5ffc, pointer @ 0x564f5f40 (Cookie OK)
ContextMenus Command Dispatcher [ContextMenus Command Dispatcher] (Waiting)
Stack: 0x55f6b004 - 0x55f7affc, pointer @ 0x55f7af40 (Cookie OK)
Stack: 0x564c2004 - 0x564d1ffc, pointer @ 0x564d1db0 (Cookie OK)
Stack: 0x58d38004 - 0x58d47ffc, pointer @ 0x58d47f00 (Cookie OK)
windowfade.task (Ready)
Stack: 0x566c7000 - 0x566cf000, pointer @ 0x566cee50 (Cookie OK)
Signals: SigRec 0x00000020, SigWait 0x00000000
State: Task (Ready)
RinghioServer (Ready)
Stack: 0x56134004 - 0x56153ffc, pointer @ 0x56153370 (Cookie OK)
Signals: SigRec 0xd8001000, SigWait 0x10000100
State: Process (Ready)
AmiDock (Ready)
Stack: 0x5633f004 - 0x5634effc, pointer @ 0x5634e930 (Cookie OK)
Signals: SigRec 0x00000100, SigWait 0x00000100
TCP/IP Control (Ready)
Stack: 0x58320004 - 0x5832fffc, pointer @ 0x5832fdc0 (Cookie OK)
Signals: SigRec 0xf8009080, SigWait 0x40000100
screenblanker.library timing dispatcher (Ready)
Stack: 0x56164004 - 0x56173ffc, pointer @ 0x56173ea0 (Cookie OK)
ppp-serial.device (Waiting)
Stack: 0x58282004 - 0x58291ffc, pointer @ 0x58291ec0 (Cookie OK)
Signals: SigRec 0xdc000000, SigWait 0x00000100
AmigaInput_usb_task (Waiting)
Stack: 0x55187004 - 0x55196ffc, pointer @ 0x55196ec0 (Cookie OK)
AmigaInput Dispatcher (Waiting)
Stack: 0x5519b000 - 0x5519f000, pointer @ 0x5519ef20 (Cookie OK)
« IPrefs » (Waiting)
Stack: 0x58c7d004 - 0x58c8cffc, pointer @ 0x58c8c530 (Cookie OK)
Signals: SigRec 0x0000f000, SigWait 0x20000100
ScreenBlankerEngine (Waiting)
Stack: 0x56251004 - 0x56260ffc, pointer @ 0x56260be0 (Cookie OK)
Signals: SigRec 0xd8001000, SigWait 0x00000100
ContextMenus [] (Waiting)
Stack: 0x561bc004 - 0x561cbffc, pointer @ 0x561cbc50 (Cookie OK)
Signals: SigRec 0xe0001000, SigWait 0x00000100
ASYNCWB (Waiting)
Stack: 0x562ca004 - 0x562d9ffc, pointer @ 0x562d9e70 (Cookie OK)
RAWBInfo (Waiting)
Stack: 0x56265004 - 0x56274ffc, pointer @ 0x56274ec0 (Cookie OK)
DefIcons (Waiting)
Stack: 0x562b6004 - 0x562c5ffc, pointer @ 0x562c5dc0 (Cookie OK)
ConClip (Waiting)
Stack: 0x5824e004 - 0x5825dffc, pointer @ 0x5825deb0 (Cookie OK)
Stack: 0x58358004 - 0x58367ffc, pointer @ 0x58367de0 (Cookie OK)
Signals: SigRec 0xf8003000, SigWait 0x00000100
TCP/IP Superserver [TCP/IP Superserver] (Waiting)
Stack: 0x5833c004 - 0x5834bffc, pointer @ 0x5834ba00 (Cookie OK)
Signals: SigRec 0xd0000080, SigWait 0x00000100
TCP/IP Log (Waiting)
Stack: 0x58374004 - 0x58383ffc, pointer @ 0x58383f00 (Cookie OK)
USB stack Process (Waiting)
Stack: 0x58959004 - 0x58968ffc, pointer @ 0x58968ee0 (Cookie OK)
datatypes.library (Waiting)
Stack: 0x58aaf004 - 0x58abeffc, pointer @ 0x58abef10 (Cookie OK)
DST watcher (Waiting)
Stack: 0x58bcb004 - 0x58bdaffc, pointer @ 0x58bdaf20 (Cookie OK)
Stack: 0x58c2b000 - 0x58c2bfa0, pointer @ 0x58c2bf10 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x5fd9b004 - 0x5fda2ffc, pointer @ 0x5fda2f00 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x5fd83004 - 0x5fd8affc, pointer @ 0x5fd8af00 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x5fd8f004 - 0x5fd96ffc, pointer @ 0x5fd96f00 (Cookie OK)
VBFGameRTG040_demo (Crashed)
Stack: 0x5533e004 - 0x5534dffc, pointer @ 0x5534dc00 (Cookie OK)
Signals: SigRec 0x00000000, SigWait 0x20000000
State: Process (Crashed)
ramlib.support (Waiting)
Stack: 0x58daf004 - 0x58dc7ffc, pointer @ 0x58dc7f00 (Cookie OK)
Signals: SigRec 0x80005000, SigWait 0x00000100
dos_signal_server (Waiting)
Stack: 0x5ff26004 - 0x5ff27ffc, pointer @ 0x5ff27f10 (Cookie OK)
Signals: SigRec 0x0000e000, SigWait 0x00000000
Picasso96 (Waiting)
Stack: 0x58ca1004 - 0x58cb0ffc, pointer @ 0x58cb0da0 (Cookie OK)
dos_appdir_server (Waiting)
Stack: 0x5ff2c004 - 0x5ff2dffc, pointer @ 0x5ff2dd40 (Cookie OK)
idle.task (Ready)
Stack: 0x5ff89000 - 0x5ff8a000, pointer @ 0x5ff89fd0 (Cookie OK)
State: Task (Ready)
ISI crash:
Crash occured in module SetPatch at address 0x58D5E438
Type of crash: ISI (Instruction Storage Interrupt) exception
Register dump:
0: 00000000 55339F20 00000000 58D5E2F0 00000000 00000000 5536A532 00000000
8: 58D5E254 58D5E438 6FB1E32C 562EF740 00000008 00000000 5533BFFC 5532A004
16: 154D5001 02270000 8000000F 8000000E 8000000D FFFFFFFF 00000000 8000000B
24: 8000000A 80000008 58D5E254 00000000 5536A532 00000000 00000000 5533BD00
0: nan 77 50 0
4: 0 545.8 30.8 0
8: 0 4.5036e+15 545.8 30.8
12: 623 81 0 -0
16: 0 0 0 0
Condition (cr) : 0x84422082
Instruction Pointer (ip) : 0x58D5E438
Xtended Exception (xer) : 0x00000008
Count (ctr) : 0x58D5E438
Link (lr) : 0x6FB2BA70
Data Address (dar) : 0x560C0A40
DATA: 00000000 00000000 551BF000 000032AC 00000000 154E108C FFD6FFFF 00000000
ADDR: 5536A532 00000000 00000000 5536A3C4 55339FFC 55339FD0 58D5E254 55339F84
FPU0: 0 0 0 0
FPU4: 0 0 0 0
Symbol info:
Instruction pointer 0x58D5E438 belongs to module "SetPatch" (HUNK/Kickstart)
Stack trace:
module C:SetPatch at 0x58D5E438 (section 0 @ 0xE8)
module DEVS:ahi.device at 0x6FB1E354 (section 5 @ 0x1334)
module DEVS:ahi.device at 0x6FB1E3A4 (section 5 @ 0x1384)
PPC disassembly:
58d5e430: 00000000 .word 0x00000000
58d5e434: 00000000 .word 0x00000000
*58d5e438: 7f454c46 .word 0x7F454C46
58d5e43c: 01020100 .word 0x01020100
58d5e440: 00000000 .word 0x00000000
System information:
CPU
CPU speed: 799 MHz
FSB speed: 133 MHz
Extensions:
Machine
Memory: 1048576 KB
Extensions: bus.pci
Expansion buses
PCI/AGP
Libraries
0x569853e8: Generic_Keyboard.driver V52.1
0x569854a8: PCI_SoundCardHornet.driver V52.2
0x56985568: PCI_sblive.pci V52.1
0x569857a8: PCI_Soundcard.driver V52.2
0x56985628: PCI_GamePortHornet.driver V52.2
0x569856e8: PCI_GamePort.driver V53.1
0x562f9918: Generic_usb.driver V53.3
0x57217018: AmigaInput.library V53.1
0x5818f084: lowlevel.library V52.3
0x55400630: rtgmaster.library V40.0 (Legacy)
0x581d6360: powerpc.library V16.41
0x560c64a8: Separator.docky V53.2
0x56095ac0: slider.gadget V53.12
0x56095980: arexx.class V53.3
0x560958e0: getfont.gadget V53.8
0x562f9798: cs4281.audio V5.5
0x57265eb0: getfile.gadget V53.10
0x560555f0: requester.class V53.18
0x56095340: bitmap.image V53.9
0x560952a0: space.gadget V53.6
0x564b33b4: device.audio V6.2
0x57265c30: integer.gadget V53.10
0x562f94b8: clicktab.gadget V53.38
0x562ebad8: screenblanker.library V53.3
0x58cf9758: chooser.gadget V53.18
0x57265af0: penmap.image V53.5
0x572659b0: checkbox.gadget V53.9
0x5fc98448: listbrowser.gadget V53.49
0x57217500: string.gadget V53.16
0x57265730: scroller.gadget V53.11
0x58cf9694: filesave.audio V6.3
0x58d2c6b4: asl.library V53.45
0x5850c3bc: textclip.library V52.2
0x5fcd7bc4: xpkmaster.library V5.2
0x588cdd68: usbhidgate.library V52.2
0x58bde7ac: hid.usbfd V53.7
0x58b09474: picture.datatype V53.6
Devices
0x588cdad4: diskimage.device V52.75
Tasks
Stack: 0x561ea004 - 0x561f9ffc, pointer @ 0x561f9a80 (Cookie OK)
USB stack (Waiting)
hid.usbfd (Ready)
Stack: 0x58855004 - 0x5885cffc, pointer @ 0x5885cee0 (Cookie OK)
Signals: SigRec 0xe0000000, SigWait 0x20000100
HID Mouse (Waiting)
Stack: 0x58811004 - 0x58820ffc, pointer @ 0x58820f20 (Cookie OK)
hid.usbfd (Waiting)
Stack: 0x587f5004 - 0x58804ffc, pointer @ 0x58804f20 (Cookie OK)
Stack: 0x58e60004 - 0x58e67ffc, pointer @ 0x58e67ea0 (Cookie OK)
DH0 (Waiting)
ICD0 (Waiting)
ICD1 (Waiting)
USB0 (Waiting)
RAM (Waiting)
DH1 (Waiting)
DH2 (Waiting)
CD0 (Waiting)
MainUSB0 (Waiting)
MainIPC0 (Waiting)
Stack: 0x5882d004 - 0x5883cffc, pointer @ 0x5883ceb0 (Cookie OK)
Stack: 0x587c1004 - 0x587d0ffc, pointer @ 0x587d0f20 (Cookie OK)
hid.usbfd (Waiting)
Stack: 0x5886d004 - 0x58874ffc, pointer @ 0x58874ee0 (Cookie OK)
hid.usbfd (Waiting)
Stack: 0x58861004 - 0x58868ffc, pointer @ 0x58868ee0 (Cookie OK)
pager (Waiting)
Stack: 0x5532a004 - 0x55339ffc, pointer @ 0x55339f20 (Cookie OK)
Signals: SigRec 0x00000100, SigWait 0x08000000
IDF0 (Waiting)
IDF1 (Waiting)
IDF2 (Waiting)
IDF3 (Waiting)
ENV (Waiting)
IPC0 (Waiting)
Stack: 0x58841004 - 0x58850ffc, pointer @ 0x58850ee0 (Cookie OK)
URL (Waiting)
CON (Waiting)
Stack: 0x56111004 - 0x56120ffc, pointer @ 0x56120de0 (Cookie OK)
CON (Waiting)
Stack: 0x561a2004 - 0x561b1ffc, pointer @ 0x561b1de0 (Cookie OK)
CON (Waiting)
Stack: 0x5621f004 - 0x5622effc, pointer @ 0x5622ede0 (Cookie OK)
CON (Waiting)
Stack: 0x56291004 - 0x562a0ffc, pointer @ 0x562a0de0 (Cookie OK)
CON (Waiting)
Stack: 0x56322004 - 0x56331ffc, pointer @ 0x56331de0 (Cookie OK)
AUDIO (Waiting)
CON (Waiting)
RAW (Waiting)
CON (Waiting)
TEXTCLIP (Waiting)
State: Task (Ready)
Stack: 0x5823a004 - 0x58249ffc, pointer @ 0x58249ea0 (Cookie OK)
ramlib (Waiting)
Stack: 0x564e5004 - 0x564f4ffc, pointer @ 0x564f4f40 (Cookie OK)
Stack: 0x5590a004 - 0x55919ffc, pointer @ 0x55919f40 (Cookie OK)
Stack: 0x564c1004 - 0x564d0ffc, pointer @ 0x564d0db0 (Cookie OK)
Stack: 0x5fc77004 - 0x5fc86ffc, pointer @ 0x5fc86f00 (Cookie OK)
Stack: 0x54f4d000 - 0x54f55000, pointer @ 0x54f54e50 (Cookie OK)
State: Task (Ready)
Stack: 0x56129004 - 0x56148ffc, pointer @ 0x56148370 (Cookie OK)
AmiDock (Ready)
Stack: 0x5633e004 - 0x5634dffc, pointer @ 0x5634d930 (Cookie OK)
screenblanker.library timing dispatcher (Waiting)
Stack: 0x5614d004 - 0x5615cffc, pointer @ 0x5615cea0 (Cookie OK)
TCP/IP Control (Waiting)
Signals: SigRec 0xf8009080, SigWait 0x00000100
Stack: 0x5516c004 - 0x5517bffc, pointer @ 0x5517bec0 (Cookie OK)
Stack: 0x551bb000 - 0x551bf000, pointer @ 0x551bef20 (Cookie OK)
Stack: 0x5623b004 - 0x5624affc, pointer @ 0x5624abe0 (Cookie OK)
Stack: 0x561be004 - 0x561cdffc, pointer @ 0x561cdc50 (Cookie OK)
ASYNCWB (Waiting)
Stack: 0x562c1004 - 0x562d0ffc, pointer @ 0x562d0e70 (Cookie OK)
RAWBInfo (Waiting)
Stack: 0x56264004 - 0x56273ffc, pointer @ 0x56273ec0 (Cookie OK)
DefIcons (Waiting)
Stack: 0x562ad004 - 0x562bcffc, pointer @ 0x562bcdc0 (Cookie OK)
ConClip (Waiting)
hub.usbfd (Waiting)
hub.usbfd (Waiting)
hub.usbfd (Waiting)
Picasso96 (Waiting)
idle.task (Ready)
State: Task (Ready)
Verdict: Doesn't work
samo79
Re: Compatibility list
Post by samo79 »
Realms Of Power
Official site: http://www.Silicon-Wizards.com/rop.php
This game works ok but it give a DSI error at startup, you can ignore it but then closing the game it freeze the machine
DSI crash:
Crash log for task "RealmsofPower"
Crash occured in module at address 0x6F81A2C0
Register dump:
0: 00000005 556CEE7E 554B4348 000DF008 00003FB7 565BFA78 54329000 5440802E
8: 5572D000 6F81A274 000DF008 0000000B 00000000 00000000 0185044C 000155B4
16: 58DD8000 561FEB40 556DC9E8 0185003C 00000000 556E254E 000000DA 000000FD
24: 00000004 00000003 000000C0 00000037 544CA000 554B4ED8 556CEED2 5FFB4420
0: nan 210 0 0
4: 0 0 0 0
8: 0 1.67772e+07 1e+61 1e-59
12: 623 81 0 2.94889e-16
16: 0 0 0 0
20: 0.316206 253 0 1.61895e-319
24: 1e+61 1e-59 0.5 4.5036e+15
28: nan 65536 1.67772e+07 0
FPSCR (Floating Point Status and Control Register): 0x82024001
Condition (cr) : 0x44000000
Instruction Pointer (ip) : 0x6F81A2C0
Xtended Exception (xer) : 0x20000005
Count (ctr) : 0x01855938
Link (lr) : 0x6F81A274
Data Address (dar) : 0x5440802E
DATA: 0000007F 00000080 000000DA 000000FD 00000004 00000003 000000C0 00000037
ADDR: 565BFA78 54329000 544CA000 554B4ED8 554B4348 556CEED2 5FFB4420 556CEE7A
FPU0: 210 0 0 0
FPU4: 0 0 0 0
Symbol info:
Instruction pointer 0x6F81A2C0 belongs to module "" (HUNK/Kickstart)
Stack trace:
68k Stack trace:
556e254c (68k IP) - "RealmsofPower" Hunk 0001 Offset 00011544 (SegList: 1606e401)
556dc9e8 - "RealmsofPower" Hunk 0001 Offset 0000b9e0 (SegList: 1606e401)
021bd7f6 - "Kickstart/kernel" Hunk 0001 Offset 0015d7f2
554b4ed8 - "RealmsofPower" Hunk 0002 Offset 00000b90 (SegList: 1606e401)
021b0000 - "Kickstart/kernel" Hunk 0001 Offset 0014fffc
556dedc8 - "RealmsofPower" Hunk 0001 Offset 0000ddc0 (SegList: 1606e401)
556dedbe - "RealmsofPower" Hunk 0001 Offset 0000ddb6 (SegList: 1606e401)
556f7258 - "RealmsofPower" Hunk 0001 Offset 00026250 (SegList: 1606e401)
581b9004 - "RealmsofPower" Hunk 0000 Offset fffffffc (SegList: 1606e401)
556ee380 - "RealmsofPower" Hunk 0001 Offset 0001d378 (SegList: 1606e401)
68k disassembly:
556e2544: 4efa7cbe jmp 0x556ea204(pc)
556e2548: 4efa7cbe jmp 0x556ea208(pc)
*556e254c: 4efa7cc2 jmp 0x556ea210(pc)
556e2550: 4efa7cc6 jmp 0x556ea218(pc)
556e2554: 4efa7cca jmp 0x556ea220(pc)
System information:
CPU
CPU speed: 799 MHz
FSB speed: 133 MHz
Extensions:
Machine
Memory: 1048576 KB
Extensions: bus.pci
Expansion buses
PCI/AGP
Libraries
0x56aa8d72: ttengine.library V6.2 (Legacy)
0x5680a7b0: mathieeedoubtrans.library V52.2
0x561fe5a0: mathieeesingbas.library V52.1
0x56abcdf0: fuelgauge.gadget V53.8
0x5590b3a8: Separator.docky V53.2
0x5617c980: slider.gadget V53.12
0x5617c840: getfont.gadget V53.8
0x5617c700: arexx.class V53.3
0x5617c660: getfile.gadget V53.10
0x561fe498: cs4281.audio V5.5
0x56045020: requester.class V53.18
0x5617c200: space.gadget V53.6
0x5617c0c0: bitmap.image V53.9
0x5617c020: integer.gadget V53.10
0x561fe638: clicktab.gadget V53.38
0x564a14a4: device.audio V6.2
0x56309cd8: screenblanker.library V53.3
0x58cf9658: chooser.gadget V53.18
0x58cf9794: filesave.audio V6.3
0x5fc736b4: asl.library V53.45
0x5fcdab04: xpkmaster.library V5.2
0x58af2d68: usbhidgate.library V52.2
0x58b07e30: window.class V53.42
0x58cfed00: gadtools.library V53.4
0x58d170cc: icon.library V53.13
Devices
0x564a1364: clipboard.device V53.2
0x58b0e604: ppp-serial.device V52.2
0x58af2ad4: diskimage.device V52.75
Tasks
Stack: 0x561dd004 - 0x561ecffc, pointer @ 0x561eca80 (Cookie OK)
USB stack (Waiting)
hid.usbfd (Ready)
Stack: 0x5888d004 - 0x58894ffc, pointer @ 0x58894ee0 (Cookie OK)
DH0 (Waiting)
hid.usbfd (Waiting)
HID Mouse (Waiting)
ICD0 (Waiting)
ICD1 (Waiting)
USB0 (Waiting)
RAM (Waiting)
DH1 (Waiting)
DH2 (Waiting)
CD0 (Waiting)
MainUSB0 (Waiting)
MainIPC0 (Waiting)
hid.usbfd (Waiting)
Stack: 0x587e5004 - 0x587f4ffc, pointer @ 0x587f4f20 (Cookie OK)
hid.usbfd (Waiting)
pager (Waiting)
IDF0 (Waiting)
IDF2 (Waiting)
IDF1 (Waiting)
IDF3 (Waiting)
ENV (Waiting)
IPC0 (Waiting)
URL (Waiting)
CON (Waiting)
Stack: 0x5610f004 - 0x5611effc, pointer @ 0x5611ede0 (Cookie OK)
CON (Waiting)
Stack: 0x5619d004 - 0x561acffc, pointer @ 0x561acde0 (Cookie OK)
CON (Waiting)
Stack: 0x56222004 - 0x56231ffc, pointer @ 0x56231de0 (Cookie OK)
CON (Waiting)
Stack: 0x5627f004 - 0x5628effc, pointer @ 0x5628ede0 (Cookie OK)
CON (Waiting)
Stack: 0x56310004 - 0x5631fffc, pointer @ 0x5631fde0 (Cookie OK)
AUDIO (Waiting)
CON (Waiting)
RAW (Waiting)
CON (Waiting)
TEXTCLIP (Waiting)
State: Task (Ready)
ramlib (Waiting)
Stack: 0x5696a004 - 0x56979ffc, pointer @ 0x56979f40 (Cookie OK)
Stack: 0x564af004 - 0x564beffc, pointer @ 0x564bedb0 (Cookie OK)
Signals: SigRec 0x40000000, SigWait 0x00000000
Stack: 0x564cb004 - 0x564daffc, pointer @ 0x564daf40 (Cookie OK)
Stack: 0x53966000 - 0x5396e000, pointer @ 0x5396de50 (Cookie OK)
State: Task (Ready)
Stack: 0x5612b004 - 0x5614affc, pointer @ 0x5614a370 (Cookie OK)
AmiDock (Ready)
Stack: 0x5632c004 - 0x5633bffc, pointer @ 0x5633b930 (Cookie OK)
Stack: 0x560d2004 - 0x560e1ffc, pointer @ 0x560e1ea0 (Cookie OK)
Stack: 0x561b9004 - 0x561c8ffc, pointer @ 0x561c8c50 (Cookie OK)
Signals: SigRec 0xe0001000, SigWait 0x04000000
ASYNCWB (Waiting)
Stack: 0x562af004 - 0x562beffc, pointer @ 0x562bee70 (Cookie OK)
Stack: 0x56236004 - 0x56245ffc, pointer @ 0x56245be0 (Cookie OK)
RAWBInfo (Waiting)
Stack: 0x56252004 - 0x56261ffc, pointer @ 0x56261ec0 (Cookie OK)
DefIcons (Waiting)
Stack: 0x5629b004 - 0x562aaffc, pointer @ 0x562aadc0 (Cookie OK)
ConClip (Waiting)
hub.usbfd (Waiting)
hub.usbfd (Waiting)
hub.usbfd (Waiting)
RealmsofPower (Crashed)
Stack: 0x556bf004 - 0x556ceffc, pointer @ 0x556cee7e (Cookie OK)
Signals: SigRec 0x00000010, SigWait 0xe0000100
Picasso96 (Waiting)
idle.task (Ready)
State: Task (Ready)
PuzzleBOBS
Download link: http://aminet.net/package/game/demo/PuzzleBOBS
This game doesn't work, it crash badly at startup
Crash log for task "PuzzleBOBS:PuzzleBOBS.exe"
Register dump:
0: 019285AC 55320E70 00000000 00000000 55320E80 00000001 00000000 02010000
8: 00000000 02270000 A00840AE 800007D1 82444044 00000000 00000000 00000000
16: 154C8C01 02270000 8000000F 8000000E 018419B8 5FF9A000 560AAC40 8000000B
24: 8000000A 00000002 800007D1 00000000 7FFFF82A 02270000 0200EFF8 55320E80
0: nan 2.122e-314 -2.41908e-312 2.03712e-312
4: 1.06275e-313 4.05597e+116 1.64657e+231 -2.18566e-312
8: -2.48274e-312 -2.14322e-312 -2.16444e-312 -2.3342e-312
12: 0 -2.27054e-312 0 -0
16: 0 0 0 0
FPSCR (Floating Point Status and Control Register): 0x82020000
Condition (cr) : 0x42448048
Xtended Exception (xer) : 0x20000002
Link (lr) : 0x018F6340
Data Address (dar) : 0x800007D1
DATA: 15614E88 00000002 800007D1 560AAC40 00000001 00000000 553287AF 0000000B
ADDR: 553287AF 5534AA4E 553110DC 15614E88 158426E0 5534312E 5FCBB654 55320F30
FPU0: 0 0 0 0
FPU4: 0 0 0 0
Symbol info:
Stack trace:
native kernel module dos.library.kmod+0x0003354c
PPC disassembly:
System information:
CPU
CPU speed: 799 MHz
FSB speed: 133 MHz
Extensions:
Machine
Memory: 1048576 KB
Extensions: bus.pci
Expansion buses
PCI/AGP
Libraries
0x56964efe: mathtrans.library V52.1 (Legacy)
0x56964f80: mathffp.library V52.1 (Legacy)
0x56108f30: fuelgauge.gadget V53.8
0x558db128: Separator.docky V53.2
0x5606c980: slider.gadget V53.12
0x5606c840: getfont.gadget V53.8
0x5606c700: arexx.class V53.3
0x5606c660: getfile.gadget V53.10
0x5623e498: cs4281.audio V5.5
0x5623e578: clicktab.gadget V53.38
0x561ca5f0: requester.class V53.18
0x5606c020: bitmap.image V53.9
0x57264f50: integer.gadget V53.10
0x57264e10: space.gadget V53.6
0x5606c200: penmap.image V53.5
0x572649b0: checkbox.gadget V53.9
0x563093d8: screenblanker.library V53.3
0x5886ebc4: xpkmaster.library V5.2
0x5fcdfd68: usbhidgate.library V52.2
0x58b09274: picture.datatype V53.6
0x5fd8de54: png.iconmodule V53.1
Devices
0x5fcdfad4: diskimage.device V52.75
0x5fd8c8b8: usbdisk.device V53.13
Tasks
Stack: 0x561d0004 - 0x561dfffc, pointer @ 0x561dfa80 (Cookie OK)
USB stack (Waiting)
hid.usbfd (Ready)
Signals: SigRec 0xe0000000, SigWait 0x80000100
HID Joystick (Ready)
Stack: 0x5881d004 - 0x5882cffc, pointer @ 0x5882cef0 (Cookie OK)
hid.usbfd (Waiting)
HID Mouse (Waiting)
DH0 (Waiting)
USB0 (Waiting)
ICD0 (Waiting)
ICD1 (Waiting)
RAM (Waiting)
DH1 (Waiting)
DH2 (Waiting)
CD0 (Waiting)
MainUSB0 (Waiting)
MainIPC0 (Waiting)
hid.usbfd (Waiting)
hid.usbfd (Waiting)
pager (Waiting)
IDF2 (Waiting)
IDF3 (Waiting)
IDF0 (Waiting)
IDF1 (Waiting)
ENV (Waiting)
IPC0 (Waiting)
URL (Waiting)
CON (Waiting)
Stack: 0x55376004 - 0x55385ffc, pointer @ 0x55385de0 (Cookie OK)
CON (Waiting)
Stack: 0x5612b004 - 0x5613affc, pointer @ 0x5613ade0 (Cookie OK)
CON (Waiting)
Stack: 0x56190004 - 0x5619fffc, pointer @ 0x5619fde0 (Cookie OK)
CON (Waiting)
Stack: 0x5620d004 - 0x5621cffc, pointer @ 0x5621cde0 (Cookie OK)
CON (Waiting)
CON (Waiting)
AUDIO (Waiting)
CON (Waiting)
RAW (Waiting)
CON (Waiting)
TEXTCLIP (Waiting)
State: Task (Ready)
Signals: SigRec 0x80000000, SigWait 0x00008100
ramlib (Waiting)
Stack: 0x56994004 - 0x569a3ffc, pointer @ 0x569a3f40 (Cookie OK)
Stack: 0x569b4000 - 0x569bc000, pointer @ 0x569bbe50 (Cookie OK)
State: Task (Ready)
Stack: 0x5613f004 - 0x5615effc, pointer @ 0x5615e370 (Cookie OK)
AmiDock (Ready)
Stack: 0x560e2004 - 0x560f1ffc, pointer @ 0x560f1ea0 (Cookie OK)
c:iconx [] (Waiting)
Stack: 0x5538a004 - 0x55399ffc, pointer @ 0x55399b20 (Cookie OK)
Stack: 0x561ac004 - 0x561bbffc, pointer @ 0x561bbc50 (Cookie OK)
Signals: SigRec 0xe0001000, SigWait 0x0c000000
Stack: 0x56221004 - 0x56230ffc, pointer @ 0x56230be0 (Cookie OK)
ASYNCWB (Waiting)
Stack: 0x562c8004 - 0x562d7ffc, pointer @ 0x562d7e70 (Cookie OK)
RAWBInfo (Waiting)
Stack: 0x5625a004 - 0x56269ffc, pointer @ 0x56269ec0 (Cookie OK)
DefIcons (Waiting)
Stack: 0x562b4004 - 0x562c3ffc, pointer @ 0x562c3dc0 (Cookie OK)
ConClip (Waiting)
hub.usbfd (Waiting)
hub.usbfd (Waiting)
Stack: 0x5fd93004 - 0x5fd9affc, pointer @ 0x5fd9af00 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x5fd9f004 - 0x5fda6ffc, pointer @ 0x5fda6f00 (Cookie OK)
Background CLI [PuzzleBOBS:PuzzleBOBS.exe] (Crashed)
Stack: 0x55311004 - 0x55320ffc, pointer @ 0x55320e70 (Cookie OK)
Picasso96 (Waiting)
idle.task (Ready)
State: Task (Ready)
samo79
Post by samo79 »
Payback (WarpOS version)
Download link: http://aminet.net/package/game/demo/PaybackDemo
The 68k exe seems ok (in software rendered) but the WarpOS exe have various problems (altrough seems faster here)
- It crash quickly (ISI crash)
- Audio doesn't seems to work (on 68k exe it's ok)
ISI crash:
Crash log for task "PaybackDemoWOS.exe"
Crash occured in module PaybackDemoWOS.exe at address 0x55767000
Register dump:
0: 55791650 555B0858 571E8028 546ED230 0000B904 000154B8 00000606 00000506
8: 00060000 00000001 FFFFB904 00000001 39443059 59443059 0000007F 567231B8
16: 00000000 00000000 00000001 00010000 5673E930 00039000 00000010 000391C8
24: 000001C8 00020000 000154B8 0000B904 00000004 000001C8 00020000 00000506
0: nan -0.748547 3090 34
4: 1.5708 4.5036e+15 0 0.25
8: 1.70377 1 2.22045e-16 3.06924e+16
12: 5 nan 0 -0
16: 0 0 0 0
28: 4.5036e+15 256 0.00109083 4.5036e+15
Condition (cr) : 0x39443059
Instruction Pointer (ip) : 0x55767000
Xtended Exception (xer) : 0x80000003
Count (ctr) : 0x00000000
Link (lr) : 0x55791650
Data Address (dar) : 0x7FD8DBD8
DATA: 00000001 FFFFFFFF 555B0F58 55FAC4F0 00000001 FFD50001 FFD60001 56A4C8D4
ADDR: 555B0F58 56049AA0 571E8028 56A4C8D4 571E8028 555B0FE8 56049AA0 555B0EAC
FPU0: 0 0 0 0
FPU4: 0 0 0 0
Symbol info:
Instruction pointer 0x55767000 belongs to module "PaybackDemoWOS.exe" (HUNK/Kickstart)
Stack trace:
module PaybackDemoWOS.exe at 0x55767000 (section 1 @ 0xA0FF8)
module PaybackDemoWOS.exe at 0x55791650 (section 1 @ 0xCB648)
module LIBS:powerpc.library at 0x6FC9BCF0 (section 5 @ 0x4CD0)
module LIBS:powerpc.library at 0x6FC9AF3C (section 5 @ 0x3F1C)
PPC disassembly:
55766ff8: 7c0802a6 mflr r0
55766ffc: 7d800026 mfcr r12
*55767000: 48083461 bl 0x557EA460
55767004: 91a1ff94 stw r13,-108(r1)
55767008: 91c1ff98 stw r14,-104(r1)
System information:
CPU
CPU speed: 799 MHz
FSB speed: 133 MHz
Extensions:
Machine
Memory: 1048576 KB
Extensions: bus.pci
Expansion buses
PCI/AGP
Libraries
0x554c0318: Generic_Keyboard.driver V52.1
0x554c0258: PCI_SoundCardHornet.driver V52.2
0x554c0198: PCI_sblive.pci V52.1
0x554c00d8: PCI_Soundcard.driver V52.2
0x554c0018: PCI_GamePortHornet.driver V52.2
0x55f62f28: PCI_GamePort.driver V53.1
0x55f62ce8: Generic_usb.driver V53.3
0x55f62c28: Generic_Mouse.driver V52.1
0x566bd768: AmigaInput.library V53.1
0x5586d084: lowlevel.library V52.3
0x55fac960: Warp3DPPC.library V4.3
0x55face40: Warp3D.library V53.7
0x5612bf68: W3D_Avenger.library V53.1
0x562d1458: W3D_Napalm.library V53.1
0x560c9198: W3D_R200.library V53.9
0x560c9118: W3D_Permedia2.library V52.36
0x56a36848: W3D_Picasso96.library V53.4
0x56049aa0: powerpc.library V16.41
0x560c9e98: Separator.docky V53.2
0x5627f618: cs4281.audio V5.5
0x561fa5c0: arexx.class V53.3
0x56048020: requester.class V53.18
0x561fa480: bitmap.image V53.9
0x561fa3e0: slider.gadget V53.12
0x561fa2a0: getfont.gadget V53.8
0x57265c30: getfile.gadget V53.10
0x564a40e4: device.audio V6.2
0x57265e10: space.gadget V53.6
0x57265cd0: integer.gadget V53.10
0x562d18d8: screenblanker.library V53.3
0x5627f038: clicktab.gadget V53.38
0x57265910: penmap.image V53.5
0x572657d0: checkbox.gadget V53.9
0x581ac6b4: asl.library V53.45
Devices
0x58b864f4: audio.device V53.2
Tasks
ahi.device Unit Process (Waiting)
Stack: 0x55f7d004 - 0x55f8cffc, pointer @ 0x55f8cf20 (Cookie OK)
Signals: SigRec 0xf000c000, SigWait 0x00000000
audio.device (Waiting)
Stack: 0x545f6004 - 0x54605ffc, pointer @ 0x54605e80 (Cookie OK)
Signals: SigRec 0x80003000, SigWait 0x00000100
Stack: 0x561d6004 - 0x561e5ffc, pointer @ 0x561e5a80 (Cookie OK)
USB stack (Waiting)
hid.usbfd (Ready)
Stack: 0x58881004 - 0x58888ffc, pointer @ 0x58888e60 (Cookie OK)
HID Mouse (Waiting)
hid.usbfd (Waiting)
DH0 (Waiting)
ICD0 (Waiting)
ICD1 (Waiting)
USB0 (Waiting)
RAM (Waiting)
DH1 (Waiting)
DH2 (Waiting)
CD0 (Waiting)
hid.usbfd (Waiting)
Stack: 0x587c9004 - 0x587d8ffc, pointer @ 0x587d8f20 (Cookie OK)
MainUSB0 (Waiting)
MainIPC0 (Waiting)
hid.usbfd (Waiting)
pager (Waiting)
ENV (Ready)
Stack: 0x58e22004 - 0x58e23ffc, pointer @ 0x58e23da0 (Cookie OK)
Signals: SigRec 0x80000000, SigWait 0x80000100
IDF2 (Ready)
Signals: SigRec 0xa8000100, SigWait 0x20000000
IDF1 (Ready)
IDF0 (Ready)
IDF3 (Ready)
IPC0 (Waiting)
URL (Waiting)
CON (Waiting)
Stack: 0x5636a004 - 0x56379ffc, pointer @ 0x56379de0 (Cookie OK)
CON (Waiting)
Stack: 0x560e7004 - 0x560f6ffc, pointer @ 0x560f6de0 (Cookie OK)
CON (Waiting)
CON (Waiting)
Stack: 0x5621b004 - 0x5622affc, pointer @ 0x5622ade0 (Cookie OK)
CON (Waiting)
Stack: 0x56288004 - 0x56297ffc, pointer @ 0x56297de0 (Cookie OK)
CON (Waiting)
Stack: 0x56311004 - 0x56320ffc, pointer @ 0x56320de0 (Cookie OK)
AUDIO (Waiting)
CON (Waiting)
RAW (Waiting)
CON (Waiting)
TEXTCLIP (Waiting)
State: Task (Ready)
Workbench [Workbench] (Ready)
Signals: SigRec 0x80000000, SigWait 0x80008000
ramlib (Waiting)
Stack: 0x564cc004 - 0x564dbffc, pointer @ 0x564dbf40 (Cookie OK)
Stack: 0x55f9b004 - 0x55faaffc, pointer @ 0x55faaf40 (Cookie OK)
Stack: 0x564b0004 - 0x564bfffc, pointer @ 0x564bfdb0 (Cookie OK)
Stack: 0x56103004 - 0x56122ffc, pointer @ 0x56122370 (Cookie OK)
AmiDock (Ready)
Stack: 0x5632d004 - 0x5633cffc, pointer @ 0x5633c930 (Cookie OK)
Stack: 0x53a58000 - 0x53a60000, pointer @ 0x53a5ffd0 (Cookie OK)
Signals: SigRec 0x00000000, SigWait 0x00000020
State: Task (Ready)
Stack: 0x56189004 - 0x56198ffc, pointer @ 0x56198ea0 (Cookie OK)
Stack: 0x54677004 - 0x54686ffc, pointer @ 0x54686ec0 (Cookie OK)
Stack: 0x565df000 - 0x565e3000, pointer @ 0x565e2f20 (Cookie OK)
iconx [] (Waiting)
Stack: 0x5637e004 - 0x5638dffc, pointer @ 0x5638db20 (Cookie OK)
Stack: 0x561b1004 - 0x561c0ffc, pointer @ 0x561c0c50 (Cookie OK)
ASYNCWB (Waiting)
Stack: 0x562b8004 - 0x562c7ffc, pointer @ 0x562c7e70 (Cookie OK)
Stack: 0x56237004 - 0x56246ffc, pointer @ 0x56246be0 (Cookie OK)
RAWBInfo (Waiting)
Stack: 0x56257004 - 0x56266ffc, pointer @ 0x56266ec0 (Cookie OK)
DefIcons (Waiting)
Stack: 0x562a4004 - 0x562b3ffc, pointer @ 0x562b3dc0 (Cookie OK)
ConClip (Waiting)
hub.usbfd (Waiting)
hub.usbfd (Waiting)
hub.usbfd (Waiting)
Background CLI [PaybackDemoWOS.exe] (Crashed)
Stack: 0x555a1004 - 0x555b0ffc, pointer @ 0x555b0858 (Cookie OK)
Signals: SigRec 0x00000100, SigWait 0x80000100
Picasso96 (Waiting)
idle.task (Ready)
State: Task (Ready)
Enforce 0.2
Download link: http://aminet.net/game/demo/Enforce_demo02.lha
This is an old (year 2000) but cool 3D engine, it start under AmigaOS 4.1 Update 2 and 3 but freeze the machine after a few seconds
But there are a few differents between Update 2 and Update 3 behaviour
On update 2 (old Warp3D.library) the game window will be splitted in four parts, while using latest Warp3D.library 53.7 the game will be opened correctly at fullscreen, but then after a few seconds it freeze as before, keyboard are not responding so you need to switch-off your Amiga
samo79
Post by samo79 »
FxPaint 1.0 Demo (WarpOS)
Download link: http://aminet.net/package/biz/demo/fxPAINT10Demo
The entire install procedure goes very well and this program more or less works fine, but some problems still and maybe some workaround are needed to use it fully
This DSI crash happen if you try to resize the window contained an image opened in program
Crash log for task "fxPAINT"
Crash occured in module kernel at address 0x01850440
Type of crash: program exception
Register dump:
0: 9BADBAD2 524ABED8 25050750 5605BBA0 021BE1B0 5FFBC000 5605BBA0 5605BBE0
8: FFFFFFFE 5605C010 80084109 00000000 00000005 524ABE90 FFFFFFFE 00000001
16: 5FFA8000 5605BBA4 00000000 0185003C 52057050 00000000 5605BBC0 00000000
24: FFFFFFFF 00000002 00000424 80000007 5FFAC000 0000001C 02076B80 02000000
0: nan 559 180 4.5036e+15
4: 0 0.5 nan 0
8: 65536 1.67772e+07 1e+61 1e-59
12: nan 65536 0 -0
16: 0 0 0 0
24: 0 0 0 -1.20437e+36
28: 0 1.35808e-312 8.8275e-311 -0.0146484
FPSCR (Floating Point Status and Control Register): 0x82002000
Condition (cr) : 0x82000000
Instruction Pointer (ip) : 0x01850440
Xtended Exception (xer) : 0x20000004
Count (ctr) : 0x01856E88
Link (lr) : 0x01850244
DSI Status (dsisr) : 0x02000000
Data Address (dar) : 0x524B05A8
DATA: 00000001 0000028A 00000000 00000000 FFFFFFFF 00000002 00000000 00000000
ADDR: 00000008 523B1844 56056E18 556F3728 54AC6008 524ABF28 50FF0300 524ABED8
FPU0: 0 0.71261 0 0
FPU4: 0 0 0 0
Symbol info:
Instruction pointer 0x01850440 belongs to module "kernel" (HUNK/Kickstart)
Stack trace:
native kernel module kernel+0x00050440
68k Stack trace:
Address of 68k IP 0xfffffffe not found
02270000 - "Kickstart/newlib.library.kmod" Hunk 0001 Offset 0000069c
0181c608 - "Kickstart/kernel" Hunk 0000 Offset 0001c604
0185472c - "Kickstart/kernel" Hunk 0000 Offset 00054728
522b488c - "fxPAINT" Hunk 0000 Offset 00014884 (SegList: 148a8001)
522a0004 - "fxPAINT" Hunk 0000 Offset fffffffc (SegList: 148a8001)
54acab1c - "fxPAINT" Hunk 0003 Offset 0000cb14 (SegList: 148a8001)
52333292 - "fxPAINT" Hunk 0000 Offset 0009328a (SegList: 148a8001)
52331b92 - "fxPAINT" Hunk 0000 Offset 00091b8a (SegList: 148a8001)
02014d9e - "Kickstart/dos.library.kmod" Hunk 0002 Offset 00005f5a
522a01e2 - "fxPAINT" Hunk 0000 Offset 000001da (SegList: 148a8001)
68k disassembly:
fffffff6: XXXXXXXX illegal address
fffffffa: XXXXXXXX illegal address
fffffffe: XXXXXXXX illegal address
00000002: XXXXXXXX illegal address
00000006: XXXXXXXX illegal address
System information:
CPU
CPU speed: 799 MHz
FSB speed: 133 MHz
Extensions:
Machine
Memory: 1048576 KB
Extensions: bus.pci
Expansion buses
PCI/AGP
Libraries
0x58d5af68: ISO-8859-15.charset V52.1
0x58d5ae68: italian_ISO-8859-15.language V52.1
0x5ff67174: vilintuisup.library V0.9
0x5ff67048: cgxvideo.library V42.1
0x5ff6f0e0: cybergraphics.library V43.0
0x524968d4: amigaguide.library V53.2
0x5132694e: newicon.library V45.0 (Legacy)
0x524b01dc: fxWARP.library V2.0 (Legacy)
0x5605c4d0: powerpc.library V16.41
0x56578c74: amigaguide.datatype V53.2
0x5580a400: Popmenu.mui V20.88
0x5580a358: xenbar.image V20.200
0x5580a220: Lamp.mcc V20.21
0x5580a0e0: Gauge.mui V20.236
0x572185f0: Dtpic.mui V20.201
0x55653df0: Popasl.mui V20.210
0x55653cb0: BetterString.mcc V11.17
0x55653ad0: Listtree.mcc V20.105
0x5663390c: codesets.library V6.12
0x55658d2c: muimaster.library V20.2328
0x557fa7a4: asyncio.library V50.3
0x560b2c98: nsbmp.library V1.3
0x560b2118: nsgif.library V1.1
0x560b2418: hubbub.library V1.2
0x55653990: fuelgauge.gadget V53.8
0x55653850: getscreenmode.gadget V53.7
0x56240b78: radiobutton.gadget V53.9
0x560b2918: pthreads.library V53.7
0x560b2618: parserutils.library V1.4
0x560b2698: iconv.library V1.1
0x560b2e98: Separator.docky V53.2
0x562406d8: cs4281.audio V5.5
0x5613a520: arexx.class V53.3
0x5605b020: requester.class V53.18
0x5613a480: bitmap.image V53.9
0x564af3b4: device.audio V6.2
0x5613a0c0: slider.gadget V53.12
0x5613a020: getfont.gadget V53.8
0x562e39d8: screenblanker.library V53.3
0x57218e10: getfile.gadget V53.10
0x57218b90: space.gadget V53.6
0x57218af0: integer.gadget V53.10
0x582f5f48: clicktab.gadget V53.38
0x58d14958: chooser.gadget V53.18
0x57218910: penmap.image V53.5
0x572187d0: checkbox.gadget V53.9
0x5fcce448: listbrowser.gadget V53.49
0x57275500: string.gadget V53.16
0x57218730: scroller.gadget V53.11
0x58d14794: filesave.audio V6.3
0x5fccd664: asl.library V53.45
0x581901a8: emulation.library V41.446
0x58685de0: mathieeedoubbas.library V52.1
0x587555d4: usergroup.library V4.30
0x5841f320: bsdsocket.library V4.292
0x585c23bc: textclip.library V52.2
0x5fce2bc4: xpkmaster.library V5.2
0x588fea5c: xadmaster.library V13.1
0x58a0fd68: usbhidgate.library V52.2
0x5ff9dcec: hid.usbfd V53.7
0x58bf1c30: button.gadget V53.14
0x58bf1d70: glyph.image V53.3
0x58b8ee30: window.class V53.42
0x58cda158: popupmenu.class V53.2
0x58d167e8: popupmenu.library V53.5
0x58bf1a50: label.image V53.12
0x58b2ee78: layout.gadget V53.19
0x58cda060: bevel.image V53.6
0x58bf17d0: drawlist.image V53.3
0x58bf1230: png.datatype V53.6
0x58b00674: picture.datatype V53.6
0x59718c48: timezone.library V53.6
0x58cc7988: application.library V53.12
0x58d1425c: ft2.library V53.1
0x58c7608c: workbench.library V53.37
0x58d0aed0: Picasso96API.library V2.356
0x58cb9d00: gadtools.library V53.4
0x5ffa8cac: commodities.library V53.1
0x58d4d140: datatypes.library V53.4
0x5fd31e54: png.iconmodule V53.1
0x58d1b0cc: icon.library V53.13
0x5fdf7918: version.library V53.7
0x58d68a40: iffparse.library V53.1
0x5ffb9ccc: locale.library V53.3
0x5ff6841c: diskfont.library V53.4
0x5fccc1a8: petunia.library V53.3
0x5fccc028: diskcache.library V3.30
0x5fcbf654: dos.library V53.76
0x5ff67444: usbprivate.library V53.11
0x5fe4813c: massstorage.usbfd V53.13
0x5fe480a8: bootkeyboard.usbfd V52.3
0x5fe48028: bootmouse.usbfd V53.1
0x5ff672fc: hub.usbfd V53.8
0x5ff6724c: usbresource.library V53.11
0x5ff8f658: hunk.library V53.4
0x5ff9d354: elf.library V53.14
0x5ff4c150: rtg.library V41.4355
0x5ff98820: ATIRadeon.chip V53.23
0x5ff987a4: PCIGraphics.card V53.1
0x5ffaa7a0: keymap.library V53.3
0x5ff8d500: layers.library V53.6
0x5ffb8420: graphics.library V53.4
0x5ff8f184: nonvolatile.library V52.1
0x5ffab318: newlib.library V53.18
0x5ff9e1ac: utility.library V53.3
0x5ffaa0a8: expansion.library V53.1
0x58757cae: rexxsyslib.library V45.7 (Legacy)
Devices
0x5649c284: clipboard.device V53.2
0x58d68254: ahi.device V6.6
0x58b69604: ppp-serial.device V52.2
0x582f2018: ppc440ep_eth.device V53.6
0x58a0fad4: diskimage.device V52.75
0x5fdfa8b8: usbdisk.device V53.13
0x5ff9ed10: usbsys.device V53.11
0x5ff8fcd0: ehci.usbhcd V53.15
0x5ff8fc30: ohci.usbhcd V53.18
0x5ff8fb90: uhci.usbhcd V53.7
0x5ff8fa24: sii3114ide.device V53.8
0x5ffa8628: console.device V53.1
0x5ff9f3f0: ramdrive.device V52.6
0x5ffaa9ec: input.device V53.3
0x5ffa8314: keyboard.device V53.5
0x5ff9f2d0: timer.device V53.1
Tasks
Stack: 0x5ff54000 - 0x5ff64000, pointer @ 0x5ff63f00 (Cookie OK)
Stack: 0x5fc55004 - 0x5fc56ffc, pointer @ 0x5fc56f20 (Cookie OK)
USB stack (Waiting)
Stack: 0x5fecc000 - 0x5fed0000, pointer @ 0x5fecff20 (Cookie OK)
Stack: 0x5fe13000 - 0x5fe1b000, pointer @ 0x5fe1af20 (Cookie OK)
Stack: 0x5fe37000 - 0x5fe3f000, pointer @ 0x5fe3ef20 (Cookie OK)
Stack: 0x5fdef000 - 0x5fdf7000, pointer @ 0x5fdf6f20 (Cookie OK)
Stack: 0x5fe4f004 - 0x5fe56ffc, pointer @ 0x5fe56e80 (Cookie OK)
Stack: 0x5fe77000 - 0x5fe7f000, pointer @ 0x5fe7ef20 (Cookie OK)
Stack: 0x5fea7000 - 0x5feaf000, pointer @ 0x5feaef20 (Cookie OK)
Stack: 0x582d7004 - 0x582e7ffc, pointer @ 0x582e7f20 (Cookie OK)
HID Mouse (Ready)
Stack: 0x58802004 - 0x58811ffc, pointer @ 0x58811f20 (Cookie OK)
Signals: SigRec 0x80001000, SigWait 0x80000000
hid.usbfd (Waiting)
Stack: 0x58882004 - 0x58889ffc, pointer @ 0x58889ee0 (Cookie OK)
hid.usbfd (Waiting)
Stack: 0x5888e004 - 0x58895ffc, pointer @ 0x58895ee0 (Cookie OK)
Stack: 0x58822004 - 0x58831ffc, pointer @ 0x58831f20 (Cookie OK)
Stack: 0x5929c004 - 0x592a3ffc, pointer @ 0x592a3ea0 (Cookie OK)
DH0 (Waiting)
Stack: 0x5fc4f004 - 0x5fc50ffc, pointer @ 0x5fc50eb0 (Cookie OK)
ICD0 (Waiting)
Stack: 0x5851e004 - 0x5852dffc, pointer @ 0x5852df20 (Cookie OK)
ICD1 (Waiting)
Stack: 0x58599004 - 0x585a8ffc, pointer @ 0x585a8f20 (Cookie OK)
USB0 (Waiting)
Stack: 0x58932004 - 0x58941ffc, pointer @ 0x58941ee0 (Cookie OK)
RAM (Waiting)
Stack: 0x592f4004 - 0x592fbffc, pointer @ 0x592fbc90 (Cookie OK)
DH1 (Waiting)
Stack: 0x5fc67004 - 0x5fc68ffc, pointer @ 0x5fc68eb0 (Cookie OK)
DH2 (Waiting)
Stack: 0x5fc61004 - 0x5fc62ffc, pointer @ 0x5fc62eb0 (Cookie OK)
CD0 (Waiting)
Stack: 0x5fc5b004 - 0x5fc5cffc, pointer @ 0x5fc5cf20 (Cookie OK)
Stack: 0x5fcaf004 - 0x5fcb2ffc, pointer @ 0x5fcb2ae0 (Cookie OK)
MainUSB0 (Waiting)
Stack: 0x5891e004 - 0x5892dffc, pointer @ 0x5892deb0 (Cookie OK)
hid.usbfd (Waiting)
Stack: 0x58876004 - 0x5887dffc, pointer @ 0x5887dee0 (Cookie OK)
Stack: 0x587c6004 - 0x587d5ffc, pointer @ 0x587d5f20 (Cookie OK)
MainIPC0 (Waiting)
Stack: 0x5883e004 - 0x5884dffc, pointer @ 0x5884deb0 (Cookie OK)
Stack: 0x587e2004 - 0x587f1ffc, pointer @ 0x587f1f20 (Cookie OK)
hid.usbfd (Waiting)
Stack: 0x5fd39004 - 0x5fd40ffc, pointer @ 0x5fd40ee0 (Cookie OK)
pager (Waiting)
Stack: 0x58e44004 - 0x58e63ffc, pointer @ 0x58e63f00 (Cookie OK)
IDF3 (Waiting)
Stack: 0x586d9004 - 0x586e8ffc, pointer @ 0x586e8ed0 (Cookie OK)
IDF2 (Waiting)
Stack: 0x5868c004 - 0x5869bffc, pointer @ 0x5869bed0 (Cookie OK)
IDF0 (Waiting)
Stack: 0x585ee004 - 0x585fdffc, pointer @ 0x585fded0 (Cookie OK)
IDF1 (Waiting)
Stack: 0x5863b004 - 0x5864affc, pointer @ 0x5864aed0 (Cookie OK)
ENV (Waiting)
Stack: 0x58e2a004 - 0x58e2bffc, pointer @ 0x58e2be00 (Cookie OK)
IPC0 (Waiting)
Stack: 0x5885a004 - 0x58869ffc, pointer @ 0x58869ee0 (Cookie OK)
Stack: 0x5fc9f000 - 0x5fca7000, pointer @ 0x5fca6e70 (Cookie OK)
URL (Waiting)
Stack: 0x58427004 - 0x584a1ffc, pointer @ 0x5849da90 (Cookie OK)
CON (Waiting)
Stack: 0x54bc9004 - 0x54bd8ffc, pointer @ 0x54bd8de0 (Cookie OK)
CON (Waiting)
Stack: 0x560f5004 - 0x56104ffc, pointer @ 0x56104de0 (Cookie OK)
CON (Waiting)
Stack: 0x5618e004 - 0x5619dffc, pointer @ 0x5619dde0 (Cookie OK)
CON (Waiting)
Stack: 0x56213004 - 0x56222ffc, pointer @ 0x56222de0 (Cookie OK)
CON (Waiting)
Stack: 0x56285004 - 0x56294ffc, pointer @ 0x56294de0 (Cookie OK)
CON (Waiting)
Stack: 0x56312004 - 0x56321ffc, pointer @ 0x56321de0 (Cookie OK)
AUDIO (Waiting)
Stack: 0x583e1004 - 0x583f0ffc, pointer @ 0x583f0ec0 (Cookie OK)
CON (Waiting)
Stack: 0x592a8004 - 0x592afffc, pointer @ 0x592afde0 (Cookie OK)
RAW (Waiting)
Stack: 0x59310004 - 0x59317ffc, pointer @ 0x59317de0 (Cookie OK)
CON (Waiting)
Stack: 0x5931c004 - 0x59323ffc, pointer @ 0x59323de0 (Cookie OK)
Stack: 0x5ff28004 - 0x5ff29ffc, pointer @ 0x5ff29f20 (Cookie OK)
Stack: 0x5ff22004 - 0x5ff23ffc, pointer @ 0x5ff23f00 (Cookie OK)
Stack: 0x5ff08000 - 0x5ff10000, pointer @ 0x5ff0ff70 (Cookie OK)
Stack: 0x581ff004 - 0x5820effc, pointer @ 0x5820ef50 (Cookie OK)
Stack: 0x584ef004 - 0x58502ffc, pointer @ 0x58502c30 (Cookie OK)
Stack: 0x5856a004 - 0x5857dffc, pointer @ 0x5857dc30 (Cookie OK)
Stack: 0x585ce004 - 0x585e1ffc, pointer @ 0x585e1c30 (Cookie OK)
Stack: 0x5861b004 - 0x5862effc, pointer @ 0x5862ec30 (Cookie OK)
Stack: 0x58668004 - 0x5867bffc, pointer @ 0x5867bc30 (Cookie OK)
Stack: 0x586b9004 - 0x586ccffc, pointer @ 0x586ccc30 (Cookie OK)
Stack: 0x586f5004 - 0x58708ffc, pointer @ 0x58708c30 (Cookie OK)
TEXTCLIP (Waiting)
Stack: 0x58403004 - 0x58412ffc, pointer @ 0x58412eb0 (Cookie OK)
Stack: 0x57278000 - 0x57280000, pointer @ 0x5727ff30 (Cookie OK)
State: Task (Ready)
Stack: 0x58237004 - 0x58246ffc, pointer @ 0x58246ea0 (Cookie OK)
ramlib (Waiting)
Stack: 0x58d9a004 - 0x58db2ffc, pointer @ 0x58db2f20 (Cookie OK)
Stack: 0x564d5004 - 0x564e4ffc, pointer @ 0x564e4f40 (Cookie OK)
Stack: 0x55841004 - 0x55850ffc, pointer @ 0x55850f40 (Cookie OK)
BetterString.mcc clipboard server (Waiting)
Stack: 0x55818004 - 0x55827ffc, pointer @ 0x55827ee0 (Cookie OK)
MUI imagespace screen notify (Waiting)
Stack: 0x5666e004 - 0x5667dffc, pointer @ 0x5667dd70 (Cookie OK)
Stack: 0x564b5004 - 0x564c4ffc, pointer @ 0x564c4db0 (Cookie OK)
Stack: 0x58d3c004 - 0x58d4bffc, pointer @ 0x58d4bf00 (Cookie OK)
Stack: 0x54b5f000 - 0x54b67000, pointer @ 0x54b66e50 (Cookie OK)
State: Task (Ready)
AmiDock (Ready)
Stack: 0x5632e004 - 0x5633dffc, pointer @ 0x5633d930 (Cookie OK)
Stack: 0x56111004 - 0x56130ffc, pointer @ 0x56130370 (Cookie OK)
Stack: 0x58321004 - 0x58330ffc, pointer @ 0x58330dc0 (Cookie OK)
Stack: 0x56141004 - 0x56150ffc, pointer @ 0x56150ea0 (Cookie OK)
Stack: 0x58287004 - 0x58296ffc, pointer @ 0x58296ec0 (Cookie OK)
Background CLI [PPC/fxpaintwos] (Waiting)
Stack: 0x551f3004 - 0x55292ffc, pointer @ 0x55292a60 (Cookie OK)
Stack: 0x5833d004 - 0x5834cffc, pointer @ 0x5834ca00 (Cookie OK)
Stack: 0x561aa004 - 0x561b9ffc, pointer @ 0x561b9c50 (Cookie OK)
Stack: 0x58359004 - 0x58368ffc, pointer @ 0x58368de0 (Cookie OK)
OWB [OWB] (Waiting)
Stack: 0x545c3004 - 0x546b7ffc, pointer @ 0x546b7c80 (Cookie OK)
Signals: SigRec 0x0f20d000, SigWait 0x00000100
[OWB] IconDatabase (Waiting)
Stack: 0x544ca004 - 0x545beffc, pointer @ 0x545beeb0 (Cookie OK)
Signals: SigRec 0x00000010, SigWait 0x00000100
Stack: 0x5622f004 - 0x5623effc, pointer @ 0x5623ebe0 (Cookie OK)
Stack: 0x58c82004 - 0x58c91ffc, pointer @ 0x58c91530 (Cookie OK)
ASYNCWB (Waiting)
Stack: 0x562c5004 - 0x562d4ffc, pointer @ 0x562d4e70 (Cookie OK)
RAWBInfo (Waiting)
Stack: 0x56269004 - 0x56278ffc, pointer @ 0x56278ec0 (Cookie OK)
DefIcons (Waiting)
Stack: 0x562a1004 - 0x562b0ffc, pointer @ 0x562b0dc0 (Cookie OK)
ConClip (Waiting)
Stack: 0x5824b004 - 0x5825affc, pointer @ 0x5825aeb0 (Cookie OK)
Stack: 0x58375004 - 0x58384ffc, pointer @ 0x58384f00 (Cookie OK)
Stack: 0x58962004 - 0x58971ffc, pointer @ 0x58971ee0 (Cookie OK)
Stack: 0x58ab0004 - 0x58abfffc, pointer @ 0x58abff10 (Cookie OK)
Stack: 0x58bd1004 - 0x58be0ffc, pointer @ 0x58be0f20 (Cookie OK)
Stack: 0x58bf2000 - 0x58bf2fa0, pointer @ 0x58bf2f10 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x5fd97004 - 0x5fd9effc, pointer @ 0x5fd9ef00 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x5fd8b004 - 0x5fd92ffc, pointer @ 0x5fd92f00 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x5fda3004 - 0x5fdaaffc, pointer @ 0x5fdaaf00 (Cookie OK)
fxPAINT (Crashed)
Stack: 0x5249c084 - 0x524abfc4, pointer @ 0x524abed8 (Cookie OK)
Signals: SigRec 0x00000020, SigWait 0x10000100
Stack: 0x58db7004 - 0x58dcfffc, pointer @ 0x58dcff00 (Cookie OK)
Stack: 0x5ff2e004 - 0x5ff2fffc, pointer @ 0x5ff2ff10 (Cookie OK)
Picasso96 (Waiting)
Stack: 0x58ca6004 - 0x58cb5ffc, pointer @ 0x58cb5da0 (Cookie OK)
Stack: 0x5ff34004 - 0x5ff35ffc, pointer @ 0x5ff35d40 (Cookie OK)
idle.task (Ready)
Stack: 0x5ff8e000 - 0x5ff8f000, pointer @ 0x5ff8efd0 (Cookie OK)
State: Task (Ready)
The "rotate image" functionality cause a very bad ISI crash :roll:
Crash log for task "PPC/fxpaintwos"
Crash occured in module fxpaintwos at address 0x55646C30
Register dump:
0: 00000028 55643A80 568BF686 00000010 00010000 00000000 FFFFFC20 5570F9D8
8: 5570F9D4 55643ABC 00000050 5564AB90 00000002 5570FA70 55640000 56A86BA0
16: 02270000 55645D00 55643FD0 01813410 02270000 0000000E 00000001 00000000
24: 565701D0 5570F9D0 000000FF 000000FF 56873D60 00000001 000000FF 5531DBC0
0: nan 1 0 1
4: nan 0.63662 1.5708 -1.13599e-11
8: 8.45898e+107 3.99193e+252 0.5 40.5
12: 0 1.14136e+243 0 -0
16: 0 0 0 0
Condition (cr) : 0x28444848
Instruction Pointer (ip) : 0x55646C30
Xtended Exception (xer) : 0x00000002
Count (ctr) : 0x01811F10
Link (lr) : 0x5564ABA0
Data Address (dar) : 0x7FD8B5A8
DATA: 15A2590C 00010001 0000FFFF 0000000E 00000003 00000001 56A7C081 569B2004
ADDR: 55643F68 5656FA8F 56874281 5656FA74 568BF686 56AC0B50 581D7930 55643F64
FPU0: 0 0 0 0
FPU4: 0 0 0 0
Symbol info:
Instruction pointer 0x55646C30 belongs to module "fxpaintwos" (HUNK/Kickstart)
Stack trace:
module PPC/fxpaintwos at 0x55646C30 (section 1 @ 0xC28)
native kernel module kernel+0x00022924
native kernel module kernel+0x00022ad4
PPC disassembly:
55646c28: 7c0803a6 mtlr r0
55646c2c: 4e800020 blr
*55646c30: 7c0802a6 mflr r0
55646c34: 90010008 stw r0,8(r1)
55646c38: 9421ffe0 stwu r1,-32(r1)
System information:
CPU
CPU speed: 799 MHz
FSB speed: 133 MHz
Extensions:
Machine
Memory: 1048576 KB
Extensions: bus.pci
Expansion buses
PCI/AGP
Libraries
0x55f891f4: amigaguide.datatype V53.2
0x568720d4: amigaguide.library V53.2
0x5610a99e: newicon.library V45.0 (Legacy)
0x582e1bdc: fxWARP.library V2.0 (Legacy)
0x581d7930: powerpc.library V16.41
0x56abf228: Separator.docky V53.2
0x561098e0: slider.gadget V53.12
0x57255f50: arexx.class V53.3
0x561c3798: cs4281.audio V5.5
0x561093e0: getfont.gadget V53.8
0x562095f0: requester.class V53.18
0x561092a0: bitmap.image V53.9
0x56109160: getfile.gadget V53.10
0x56109020: space.gadget V53.6
0x562dae58: screenblanker.library V53.3
0x581ded04: device.audio V6.2
0x57255c30: integer.gadget V53.10
0x561c31b8: clicktab.gadget V53.38
0x572559b0: penmap.image V53.5
0x572557d0: checkbox.gadget V53.9
0x57218500: string.gadget V53.16
0x57255730: scroller.gadget V53.11
0x58d34834: asl.library V53.45
0x5817a1a8: emulation.library V41.446
0x586a3de0: mathieeedoubbas.library V52.1
0x5841b320: bsdsocket.library V4.292
0x5850d43c: textclip.library V52.2
0x5886dbc4: xpkmaster.library V5.2
Devices
0x582dc018: ppc440ep_eth.device V53.6
Tasks
Stack: 0x561db004 - 0x561eaffc, pointer @ 0x561eaa80 (Cookie OK)
USB stack (Waiting)
Stack: 0x582c3004 - 0x582d3ffc, pointer @ 0x582d3f20 (Cookie OK)
hid.usbfd (Waiting)
Stack: 0x587fd004 - 0x5880cffc, pointer @ 0x5880cf20 (Cookie OK)
DH0 (Waiting)
hid.usbfd (Waiting)
HID Mouse (Waiting)
ICD0 (Waiting)
Stack: 0x58522004 - 0x58531ffc, pointer @ 0x58531f20 (Cookie OK)
ICD1 (Waiting)
Stack: 0x5859d004 - 0x585acffc, pointer @ 0x585acf20 (Cookie OK)
USB0 (Waiting)
RAM (Waiting)
DH1 (Waiting)
DH2 (Waiting)
CD0 (Waiting)
MainUSB0 (Waiting)
MainIPC0 (Waiting)
hid.usbfd (Waiting)
hid.usbfd (Waiting)
pager (Waiting)
ENV (Ready)
IDF3 (Ready)
Stack: 0x586c8004 - 0x586d7ffc, pointer @ 0x586d7ed0 (Cookie OK)
IDF0 (Ready)
Stack: 0x585ea004 - 0x585f9ffc, pointer @ 0x585f9ed0 (Cookie OK)
IDF2 (Ready)
Stack: 0x58688004 - 0x58697ffc, pointer @ 0x58697ed0 (Cookie OK)
IDF1 (Ready)
IPC0 (Waiting)
URL (Waiting)
CON (Waiting)
Stack: 0x565ff004 - 0x5660effc, pointer @ 0x5660ede0 (Cookie OK)
CON (Waiting)
CON (Waiting)
CON (Waiting)
Stack: 0x56223004 - 0x56232ffc, pointer @ 0x56232de0 (Cookie OK)
CON (Waiting)
Stack: 0x56280004 - 0x5628fffc, pointer @ 0x5628fde0 (Cookie OK)
CON (Waiting)
AUDIO (Waiting)
CON (Waiting)
RAW (Waiting)
CON (Waiting)
Stack: 0x58203004 - 0x58212ffc, pointer @ 0x58212f50 (Cookie OK)
Stack: 0x5856e004 - 0x58581ffc, pointer @ 0x58581c30 (Cookie OK)
Stack: 0x585ca004 - 0x585ddffc, pointer @ 0x585ddc30 (Cookie OK)
Stack: 0x586a8004 - 0x586bbffc, pointer @ 0x586bbc30 (Cookie OK)
TEXTCLIP (Waiting)
Stack: 0x583ff004 - 0x5840effc, pointer @ 0x5840eeb0 (Cookie OK)
Stack: 0x57268000 - 0x57270000, pointer @ 0x5726ff30 (Cookie OK)
State: Task (Ready)
Stack: 0x5823b004 - 0x5824affc, pointer @ 0x5824aea0 (Cookie OK)
ramlib (Waiting)
Stack: 0x5696e004 - 0x5697dffc, pointer @ 0x5697df40 (Cookie OK)
AmiDock (Ready)
Stack: 0x5612d004 - 0x5614cffc, pointer @ 0x5614c370 (Cookie OK)
Stack: 0x54885000 - 0x5488d000, pointer @ 0x5488cfd0 (Cookie OK)
State: Task (Ready)
Stack: 0x58283004 - 0x58292ffc, pointer @ 0x58292ec0 (Cookie OK)
Stack: 0x560e4004 - 0x560f3ffc, pointer @ 0x560f3ea0 (Cookie OK)
fxPAINT (Waiting)
Stack: 0x58188084 - 0x58197fc4, pointer @ 0x58197ca0 (Cookie OK)
Signals: SigRec 0x08000000, SigWait 0x80000100
Stack: 0x5623f004 - 0x5624effc, pointer @ 0x5624ebe0 (Cookie OK)
ASYNCWB (Waiting)
Stack: 0x562b0004 - 0x562bfffc, pointer @ 0x562bfe70 (Cookie OK)
RAWBInfo (Waiting)
DefIcons (Waiting)
Stack: 0x5629c004 - 0x562abffc, pointer @ 0x562abdc0 (Cookie OK)
ConClip (Waiting)
Stack: 0x5824f004 - 0x5825effc, pointer @ 0x5825eeb0 (Cookie OK)
hub.usbfd (Waiting)
hub.usbfd (Waiting)
hub.usbfd (Waiting)
Background CLI [PPC/fxpaintwos] (Crashed)
Stack: 0x555a4004 - 0x55643ffc, pointer @ 0x55643a80 (Cookie OK)
Picasso96 (Waiting)
idle.task (Ready)
State: Task (Ready)
More to come eventually ...
samo79
Post by samo79 »
EDIT: Handy 1.45 is completely fixed!
Handy 0.95 (1.44) is another 68k proggy that refuse to work on OS 4.1 even if it is was marked as OS4 compatible
http://amigan.1emu.net/releases/Handy095.lha
Hidden Text - Click to Show :
Crash log for task "Handy"
Generated by GrimReaper 53.2
Crash occured in module SetPatch at address 0x6FFC82F8
Register dump:
0: 00000000 523E3DC0 00000000 020A97C4 58D5D711 58D5D6FC 00000000 00000000
8: 00000000 00000000 021BD7F6 021BD7F6 28422028 00000000 523E5FFC 523CB004
16: 1422C001 02270000 8000000F 021BD7F6 8000000D FFFFFFFF 00000000 00000000
24: 021BD7F6 58D5C2D0 53166651 80000007 FFD50001 00000000 02270000 020A97C4
0: nan 100 735 0
4: 34 66.8 51.8 18
8: 615 2.78132e-309 35.8 255
12: 1 753 0 -5.05923e-321
16: 0 0 0 0
20: 0 0 0 1.61895e-319
24: 4.94066e-324 0 1.08646e-311 -2.86923e-35
28: 0 1.35808e-312 8.8275e-311 -2.0241e-78
Machine State (msr) : 0x0002F030
Condition (cr) : 0x28422024
Instruction Pointer (ip) : 0x6FFC82F8
Xtended Exception (xer) : 0x00000005
Count (ctr) : 0x01816208
Link (lr) : 0x6FFC82EC
DSI Status (dsisr) : 0x00800000
Data Address (dar) : 0x00000018
680x0 emulated registers:
DATA: 00000000 00000000 00000001 00000000 FFFFFFFF 50001000 FFD60001 508B0004
ADDR: 53166651 00000000 51EF4D32 53BD30E4 51EF4126 523E3E84 021BD7F6 523E3E38
FPU0: 0 0 0 0
FPU4: 0 0 0 0
Symbol info:
Instruction pointer 0x6FFC82F8 belongs to module "SetPatch" (HUNK/Kickstart)
Stack trace:
module C:SetPatch at 0x6FFC82F8 (section 5 @ 0x52D8)
native kernel module kernel+0x0001caac
native kernel module kernel+0x0005472c
native kernel module kernel+0x009bd7f6
PPC disassembly:
6ffc82f0: 38000000 li r0,0
6ffc82f4: 831f0010 lwz r24,16(r31)
*6ffc82f8: 901d0018 stw r0,24(r29)
6ffc82fc: 901d0014 stw r0,20(r29)
6ffc8300: 419e03ac beq- cr7,0x6FFC86AC
System information:
CPU
Model: AMCC PPC440EP V1.3
CPU speed: 799 MHz
FSB speed: 133 MHz
Extensions:
Machine
Machine name: Sam440EP
Memory: 1048576 KB
Extensions: bus.pci
Expansion buses
PCI/AGP
00:00.0 Vendor 0x1014 Device 0x027F
Range 1: 00000000 - 40000000 (PREF.MEM)
00:0A.0 Vendor 0x12D8 Device 0x8150
00:0C.0 Vendor 0x1002 Device 0x5960
Range 0: A8000000 - B0000000 (PREF.MEM)
Range 1: 00001000 - 00001100 (IO)
Range 2: B0000000 - B0010000 (MEM)
00:0C.1 Vendor 0x1002 Device 0x5940
Range 0: B8000000 - C0000000 (PREF.MEM)
Range 1: C0000000 - C0010000 (MEM)
00:0E.0 Vendor 0x1095 Device 0x3114
Range 0: 00001100 - 00001108 (IO)
Range 1: 00001108 - 00001110 (IO)
Range 2: 00001110 - 00001118 (IO)
Range 3: 00001118 - 00001120 (IO)
Range 4: 00001120 - 00001130 (IO)
01:04.0 Vendor 0x1013 Device 0x6005
Range 0: A0000000 - A0001000 (MEM)
Range 1: A0010000 - A0020000 (MEM)
01:05.0 Vendor 0x1033 Device 0x0035
Range 0: A0020000 - A0021000 (MEM)
01:05.1 Vendor 0x1033 Device 0x0035
Range 0: A0021000 - A0022000 (MEM)
01:05.2 Vendor 0x1033 Device 0x00E0
Range 0: A0022000 - A0022100 (MEM)
Libraries
0x58d5cf68: ISO-8859-15.charset V52.1
0x58d5cee8: italian_ISO-8859-15.language V52.1
0x021bd7f6: exec.library V53.22
0x5ff62174: vilintuisup.library V0.9
0x5ff62048: cgxvideo.library V42.1
0x5ff6b0e0: cybergraphics.library V43.0
0x53945470: mathieeedoubtrans.library V52.2
0x53499028: Generic_Keyboard.driver V52.1
0x5585e568: PCI_SoundCardHornet.driver V52.2
0x53bbbf18: PCI_sblive.pci V52.1
0x53bbbe58: PCI_Soundcard.driver V52.2
0x53bbbd98: PCI_GamePortHornet.driver V52.2
0x53bbbcd8: PCI_GamePort.driver V53.1
0x53bbba98: Generic_usb.driver V53.3
0x53bbb9d8: Generic_Mouse.driver V52.1
0x539444f8: AmigaInput.library V53.1
0x523ae414: lowlevel.library V52.3
0x567ee480: Lamp.mcc V20.21
0x567ee660: Dtpic.mui V20.201
0x567ee7a0: Listtree.mcc V20.105
0x56a573e4: asyncio.library V50.3
0x52c64a30: Popmenu.mui V20.88
0x52665a18: nsbmp.library V1.3
0x52665918: nsgif.library V1.1
0x52665698: hubbub.library V1.2
0x52665218: parserutils.library V1.4
0x52665498: iconv.library V1.1
0x5894a328: bz2.library V53.2
0x52c64990: Pixmap.mui V20.13
0x52c64850: Colorring.mui V20.87
0x52c647b0: Scale.mui V20.204
0x52c64670: Backgroundadjust.mui V20.403
0x52c64490: Penadjust.mui V20.201
0x53bbb62c: muilocale.library V20.344
0x52c642b0: Poppen.mui V20.277
0x52c64170: Popasl.mui V20.210
0x52c64030: Numericbutton.mui V20.213
0x5550b95e: Crawling.mcc V16.8 (Legacy)
0x567eee78: xenbar.image V20.200
0x567eed40: Floattext.mui V20.206
0x567eec00: Imagedisplay.mui V20.211
0x567eea20: Pendisplay.mui V20.202
0x569b057c: xpkSQSH.library V1.10 (Legacy)
0x565aa6cc: xpkSMPL.library V1.0 (Legacy)
0x53bbcc6c: xpkSHRI.library V2.2 (Legacy)
0x5647c69c: xpkRLEN.library V1.3 (Legacy)
0x565aa54c: xpkRAKE.library V1.7 (Legacy)
0x5647c21c: xpkNUKE.library V1.7 (Legacy)
0x565aa3cc: xpkNONE.library V1.4 (Legacy)
0x567ee21c: xpkMASH.library V1.98 (Legacy)
0x565aa328: xpkLZMA.library V52.2
0x54e03fa2: xpkIMPL.library V1.0 (Legacy)
0x5647cdbc: xpkIDEA.library V1.3 (Legacy)
0x5647ce1c: xpkHUFF.library V0.64 (Legacy)
0x565aa1cc: xpkHFMN.library V1.36 (Legacy)
0x565aa14c: xpkFRLE.library V1.0 (Legacy)
0x5647c57c: xpkFEAL.library V1.5 (Legacy)
0x5647c63c: xpkFAST.library V1.10 (Legacy)
0x5647c4bc: xpkENCO.library V1.3 (Legacy)
0x5647c87c: xpkDUKE.library V1.6 (Legacy)
0x5605132c: xpkDLTA.library V0.1 (Legacy)
0x5690758c: xpkCBR0.library V1.0 (Legacy)
0x53bbb4bc: xpkBZP2.library V1.7
0x54e035f0: Gauge.mui V20.236
0x54e03410: TextEditor.mcc V15.36
0x54e03370: NBalance.mcc V15.10
0x54e032d0: NListtree.mcc V18.36
0x54e03230: NFloattext.mcc V19.65
0x54e030f0: NListview.mcc V19.84
0x5560cf40: NList.mcc V20.129
0x5560cea0: BetterString.mcc V11.20
0x5560cd60: TheButton.mcc V26.7
0x5560ccc0: TheBarVirt.mcc V26.7
0x5560cc20: TheBar.mcc V26.7
0x5477ab48: amissl_v097g.library V3.7
0x5560ca58: amisslmaster.library V3.7
0x569af90c: codesets.library V6.12
0x5698f99c: muimaster.library V20.2328
0x5560c5e0: ilbm.datatype V53.1
0x5560c540: ascii.datatype V53.1
0x5560c400: text.datatype V53.5
0x5583a374: amigaguide.datatype V53.2
0x567ac0d4: amigaguide.library V53.2
0x569b1bb8: dopus.library V22.40
0x5877cc30: expat.library V53.3
0x55fafa18: pthreads.library V53.7
0x5560c040: tapedeck.gadget V53.3
0x55fb2df0: gradientslider.gadget V53.5
0x55fb2cd8: resource.library V44.103 (Legacy)
0x55fb2c14: colorwheel.gadget V53.5
0x5585eb80: datebrowser.gadget V53.6
0x55fb2a30: fuelgauge.gadget V53.8
0x55fb28f0: getscreenmode.gadget V53.7
0x55fb27b0: palette.gadget V53.6
0x561c9938: radiobutton.gadget V53.9
0x561c9878: speedbar.gadget V53.10
0x556dc5b0: texteditor.gadget V53.18
0x57247258: Separator.docky V53.2
0x561c5468: screenblanker.library V53.3
0x56234840: arexx.class V53.3
0x562347a0: slider.gadget V53.12
0x56234660: getfont.gadget V53.8
0x56234520: getfile.gadget V53.10
0x561c96f8: clicktab.gadget V53.38
0x56234340: checkbox.gadget V53.9
0x5604a760: requester.class V53.18
0x56234160: space.gadget V53.6
0x58cf9958: chooser.gadget V53.18
0x56234020: penmap.image V53.5
0x5724af50: bitmap.image V53.9
0x5724aeb0: integer.gadget V53.10
0x5890af08: listbrowser.gadget V53.49
0x571fb9e0: string.gadget V53.16
0x5724ad70: scroller.gadget V53.11
0x58918568: cs4281.audio V5.5
0x589093a4: device.audio V6.2
0x5fc769b4: asl.library V53.45
0x5815e1a8: emulation.library V41.446
0x586c7de0: mathieeedoubbas.library V52.1
0x5874d5d4: usergroup.library V4.30
0x5850f73c: textclip.library V52.2
0x58872b04: xpkmaster.library V5.2
0x588fda5c: xadmaster.library V13.1
0x58a17d68: usbhidgate.library V52.2
0x5ff98cec: hid.usbfd V53.7
0x58c2ac30: button.gadget V53.14
0x58c2ad70: glyph.image V53.3
0x58c65c90: window.class V53.42
0x58a25158: popupmenu.class V53.2
0x58cd77e8: popupmenu.library V53.5
0x58c2aa50: label.image V53.12
0x58acee78: layout.gadget V53.19
0x58a25060: bevel.image V53.6
0x58c2a7d0: drawlist.image V53.3
0x58c2a230: png.datatype V53.6
0x58b6a674: picture.datatype V53.6
0x5970ec48: timezone.library V53.6
0x58cd8988: application.library V53.12
0x58cf925c: ft2.library V53.1
0x58cc208c: workbench.library V53.37
0x58cf7ed0: Picasso96API.library V2.356
0x5fffbcac: commodities.library V53.1
0x58d4b140: datatypes.library V53.4
0x5fda5e54: png.iconmodule V53.1
0x5fe15918: version.library V53.7
0x58d5ea40: iffparse.library V53.1
0x5ffb5ccc: locale.library V53.3
0x5ff8b41c: diskfont.library V53.4
0x5fce61a8: petunia.library V53.3
0x5fce6028: diskcache.library V3.30
0x5fcbb654: dos.library V53.76
0x5ff62444: usbprivate.library V53.11
0x5ff3f13c: massstorage.usbfd V53.13
0x5ff3f0a8: bootkeyboard.usbfd V52.3
0x5ff3f028: bootmouse.usbfd V53.1
0x5ff622fc: hub.usbfd V53.8
0x5ff6224c: usbresource.library V53.11
0x5ff8a658: hunk.library V53.4
0x5ff98354: elf.library V53.14
0x5ff924d0: intuition.library V53.32
0x5ff48150: rtg.library V41.4355
0x5ff9b820: ATIRadeon.chip V53.23
0x5ff9b7a4: PCIGraphics.card V53.1
0x5ff9d7a0: keymap.library V53.3
0x5ff88500: layers.library V53.6
0x5ffb4420: graphics.library V53.4
0x5ff8a184: nonvolatile.library V52.1
0x5ff9e318: newlib.library V53.18
0x5ff991ac: utility.library V53.3
0x5ff9d0a8: expansion.library V53.1
0x58750cae: rexxsyslib.library V45.7 (Legacy)
Devices
0x569b0ce4: clipboard.device V53.2
0x58d5e254: ahi.device V6.6
0x583e3604: ppp-serial.device V52.2
0x582e0018: ppc440ep_eth.device V53.6
0x58a17ad4: diskimage.device V52.75
0x5fda48b8: usbdisk.device V53.13
0x5ff99d10: usbsys.device V53.11
0x5ff8acd0: ehci.usbhcd V53.15
0x5ff8ac30: ohci.usbhcd V53.18
0x5ff8ab90: uhci.usbhcd V53.7
0x5ff8aa24: sii3114ide.device V53.8
0x5fffb628: console.device V53.1
0x5ff9a3f0: ramdrive.device V52.6
0x5ff9d9ec: input.device V53.3
0x5fffb314: keyboard.device V53.5
0x5ff9a2d0: timer.device V53.1
Tasks
Hollywood sound server (Waiting)
Stack: 0x54a52004 - 0x54a61ffc, pointer @ 0x54a61f20 (Cookie OK)
State: Process (Waiting)
Hollywood streaming task (Waiting)
Stack: 0x54bd8004 - 0x54be7ffc, pointer @ 0x54be7660 (Cookie OK)
Signals: SigRec 0xe0000000, SigWait 0x00000000
ClickToFront (Waiting)
Stack: 0x56127004 - 0x56136ffc, pointer @ 0x56136a80 (Cookie OK)
input.device (Waiting)
Stack: 0x5ff50000 - 0x5ff60000, pointer @ 0x5ff5ff00 (Cookie OK)
State: Task (Waiting)
SFS DosList handler (Waiting)
Stack: 0x5fc4d004 - 0x5fc4effc, pointer @ 0x5fc4ef20 (Cookie OK)
USB stack (Waiting)
Stack: 0x5fec4000 - 0x5fec8000, pointer @ 0x5fec7f20 (Cookie OK)
OHCI Controller Task Unit 0 (Waiting)
Stack: 0x5fe2f000 - 0x5fe37000, pointer @ 0x5fe36f20 (Cookie OK)
Signals: SigRec 0xbc009000, SigWait 0x00000000
OHCI Controller Task Unit 1 (Waiting)
Stack: 0x5fe0b000 - 0x5fe13000, pointer @ 0x5fe12f20 (Cookie OK)
EHCI Controller Task Unit 0 (Waiting)
Stack: 0x5fdeb000 - 0x5fdf3000, pointer @ 0x5fdf2f20 (Cookie OK)
Signals: SigRec 0xbe009000, SigWait 0x00000000
sii3114ide.device - chip 0 port 1 (Waiting)
Stack: 0x5fe6f000 - 0x5fe77000, pointer @ 0x5fe76f20 (Cookie OK)
page_sweep (Waiting)
Stack: 0x5fe47004 - 0x5fe4effc, pointer @ 0x5fe4ee80 (Cookie OK)
sii3114ide.device - chip 0 port 0 (Waiting)
Stack: 0x5fe9f000 - 0x5fea7000, pointer @ 0x5fea6f20 (Cookie OK)
ppc440ep_eth Unit 0 (Waiting)
Stack: 0x582c6004 - 0x582d6ffc, pointer @ 0x582d6f20 (Cookie OK)
Signals: SigRec 0xf6001000, SigWait 0x00000000
hid.usbfd (Ready)
Stack: 0x58885004 - 0x5888cffc, pointer @ 0x5888cee0 (Cookie OK)
HID Mouse (Waiting)
Stack: 0x58805004 - 0x58814ffc, pointer @ 0x58814f20 (Cookie OK)
hid.usbfd (Waiting)
Stack: 0x5fcdb004 - 0x5fce2ffc, pointer @ 0x5fce2ee0 (Cookie OK)
Signals: SigRec 0xe0000000, SigWait 0x00000100
HID Joystick (Waiting)
Stack: 0x58821004 - 0x58830ffc, pointer @ 0x58830f20 (Cookie OK)
reaper.task (Waiting)
DH0 (Waiting)
Stack: 0x5fc47004 - 0x5fc48ffc, pointer @ 0x5fc48eb0 (Cookie OK)
DH1 (Waiting)
Stack: 0x5fc5f004 - 0x5fc60ffc, pointer @ 0x5fc60eb0 (Cookie OK)
ICD0 (Waiting)
Stack: 0x58526004 - 0x58535ffc, pointer @ 0x58535f20 (Cookie OK)
ICD1 (Waiting)
Stack: 0x585a1004 - 0x585b0ffc, pointer @ 0x585b0f20 (Cookie OK)
USB0 (Waiting)
Stack: 0x5893a004 - 0x58949ffc, pointer @ 0x58949ee0 (Cookie OK)
Signals: SigRec 0x00010100, SigWait 0x00000000
RAM (Waiting)
Stack: 0x592ec004 - 0x592f3ffc, pointer @ 0x592f3c90 (Cookie OK)
DH2 (Waiting)
Stack: 0x5fc59004 - 0x5fc5affc, pointer @ 0x5fc5aeb0 (Cookie OK)
CD0 (Waiting)
Stack: 0x5fc53004 - 0x5fc54ffc, pointer @ 0x5fc54f20 (Cookie OK)
dos_filedir_notify (Waiting)
Stack: 0x5fcab004 - 0x5fcaeffc, pointer @ 0x5fcaeae0 (Cookie OK)
Signals: SigRec 0x10000000, SigWait 0x00000000
hid.usbfd (Waiting)
Stack: 0x58879004 - 0x58880ffc, pointer @ 0x58880ee0 (Cookie OK)
HID Keyboard (Waiting)
Stack: 0x587c5004 - 0x587d4ffc, pointer @ 0x587d4f20 (Cookie OK)
Signals: SigRec 0x90001000, SigWait 0x00000000
MainUSB0 (Waiting)
Stack: 0x58926004 - 0x58935ffc, pointer @ 0x58935eb0 (Cookie OK)
Signals: SigRec 0x40000100, SigWait 0x00000000
MainIPC0 (Waiting)
Stack: 0x5883d004 - 0x5884cffc, pointer @ 0x5884ceb0 (Cookie OK)
HID Consumer (Waiting)
Stack: 0x587e1004 - 0x587f0ffc, pointer @ 0x587f0f20 (Cookie OK)
hid.usbfd (Waiting)
Stack: 0x5fd31004 - 0x5fd38ffc, pointer @ 0x5fd38ee0 (Cookie OK)
pager (Waiting)
Stack: 0x58e3c004 - 0x58e5bffc, pointer @ 0x58e5bf00 (Cookie OK)
IDF1 (Waiting)
Stack: 0x5863f004 - 0x5864effc, pointer @ 0x5864eed0 (Cookie OK)
Signals: SigRec 0xa8000100, SigWait 0x00000000
IDF2 (Waiting)
Stack: 0x5867b004 - 0x5868affc, pointer @ 0x5868aed0 (Cookie OK)
IDF3 (Waiting)
Stack: 0x586cc004 - 0x586dbffc, pointer @ 0x586dbed0 (Cookie OK)
IDF0 (Waiting)
ENV (Waiting)
Stack: 0x58e22004 - 0x58e23ffc, pointer @ 0x58e23e00 (Cookie OK)
MassStorage Device Task (Waiting)
Stack: 0x5fc9b000 - 0x5fca3000, pointer @ 0x5fca2e70 (Cookie OK)
Signals: SigRec 0xf3009000, SigWait 0x00000000
IPC0 (Waiting)
Stack: 0x58859004 - 0x58868ffc, pointer @ 0x58868ee0 (Cookie OK)
CON (Waiting)
Stack: 0x555e4004 - 0x555f3ffc, pointer @ 0x555f3de0 (Cookie OK)
URL (Waiting)
Stack: 0x5842b004 - 0x584a5ffc, pointer @ 0x584a1a90 (Cookie OK)
Signals: SigRec 0x80000000, SigWait 0x20000000
console.device (Waiting)
Stack: 0x5ff00000 - 0x5ff08000, pointer @ 0x5ff07f70 (Cookie OK)
Signals: SigRec 0xf0000000, SigWait 0x00000000
CON (Waiting)
Stack: 0x56059004 - 0x56068ffc, pointer @ 0x56068de0 (Cookie OK)
CON (Waiting)
Stack: 0x560de004 - 0x560edffc, pointer @ 0x560edde0 (Cookie OK)
CON (Waiting)
Stack: 0x5614b004 - 0x5615affc, pointer @ 0x5615ade0 (Cookie OK)
CON (Waiting)
Stack: 0x561d5004 - 0x561e4ffc, pointer @ 0x561e4de0 (Cookie OK)
CON (Waiting)
Stack: 0x5625a004 - 0x56269ffc, pointer @ 0x56269de0 (Cookie OK)
AUDIO (Waiting)
Stack: 0x583d0004 - 0x583dfffc, pointer @ 0x583dfec0 (Cookie OK)
CON (Waiting)
Stack: 0x592a0004 - 0x592a7ffc, pointer @ 0x592a7de0 (Cookie OK)
RAW (Waiting)
Stack: 0x59308004 - 0x5930fffc, pointer @ 0x5930fde0 (Cookie OK)
CON (Waiting)
Stack: 0x59314004 - 0x5931bffc, pointer @ 0x5931bde0 (Cookie OK)
dos_nbmd_process (Waiting)
Stack: 0x5ff20004 - 0x5ff21ffc, pointer @ 0x5ff21f20 (Cookie OK)
dos_lock_handler (Waiting)
Stack: 0x5ff1a004 - 0x5ff1bffc, pointer @ 0x5ff1bf00 (Cookie OK)
RexxMaster [] (Waiting)
Stack: 0x581de004 - 0x581edffc, pointer @ 0x581edf50 (Cookie OK)
Stack: 0x584f3004 - 0x58506ffc, pointer @ 0x58506c30 (Cookie OK)
Stack: 0x58572004 - 0x58585ffc, pointer @ 0x58585c30 (Cookie OK)
diskimage.device unit 1 (Waiting)
Stack: 0x5861f004 - 0x58632ffc, pointer @ 0x58632c30 (Cookie OK)
diskimage.device unit 2 (Waiting)
Stack: 0x5865b004 - 0x5866effc, pointer @ 0x5866ec30 (Cookie OK)
diskimage.device unit 3 (Waiting)
diskimage.device unit 6 (Waiting)
Stack: 0x586f8004 - 0x5870bffc, pointer @ 0x5870bc30 (Cookie OK)
TEXTCLIP (Waiting)
compose.task (Ready)
Stack: 0x5724b000 - 0x57253000, pointer @ 0x57252f30 (Cookie OK)
Signals: SigRec 0x00000021, SigWait 0x00000020
State: Task (Ready)
Workbench [Workbench] (Waiting)
Stack: 0x58181004 - 0x58190ffc, pointer @ 0x58190ea0 (Cookie OK)
Signals: SigRec 0x80000000, SigWait 0x40008000
ramlib (Waiting)
Stack: 0x58d92004 - 0x58daaffc, pointer @ 0x58daaf20 (Cookie OK)
Stack: 0x56461004 - 0x56470ffc, pointer @ 0x56470f40 (Cookie OK)
ContextMenus Command Dispatcher [ContextMenus Command Dispatcher] (Waiting)
Stack: 0x5584c004 - 0x5585bffc, pointer @ 0x5585bf40 (Cookie OK)
TextEditor.mcc clipboard server (Waiting)
Stack: 0x549c2004 - 0x549c3ffc, pointer @ 0x549c3f00 (Cookie OK)
NListtree.mcc clipboard server (Waiting)
Stack: 0x549bc004 - 0x549bdffc, pointer @ 0x549bdf00 (Cookie OK)
NList.mcc clipboard server (Waiting)
Stack: 0x549b6004 - 0x549b7ffc, pointer @ 0x549b7f00 (Cookie OK)
Stack: 0x563f7004 - 0x563f8ffc, pointer @ 0x563f8ed0 (Cookie OK)
Stack: 0x53933004 - 0x53942ffc, pointer @ 0x53942d70 (Cookie OK)
texteditor.gadget Clipboard Server (Waiting)
Stack: 0x55628004 - 0x55640ffc, pointer @ 0x55640f00 (Cookie OK)
Stack: 0x56435004 - 0x56444ffc, pointer @ 0x56444db0 (Cookie OK)
Stack: 0x58d20004 - 0x58d2fffc, pointer @ 0x58d2ff00 (Cookie OK)
OWB [OWB] (Ready)
Stack: 0x52558004 - 0x5264cffc, pointer @ 0x5264c3c0 (Cookie OK)
Signals: SigRec 0x00000010, SigWait 0x00004190
State: Process (Ready)
windowfade.task (Ready)
Stack: 0x535a5000 - 0x535ad000, pointer @ 0x535ace50 (Cookie OK)
Signals: SigRec 0x00000010, SigWait 0x00000000
State: Task (Ready)
RinghioServer (Ready)
Stack: 0x56075004 - 0x56094ffc, pointer @ 0x56094370 (Cookie OK)
Signals: SigRec 0xd8001000, SigWait 0x10000100
AmiDock (Ready)
Stack: 0x5627a004 - 0x56289ffc, pointer @ 0x56289930 (Cookie OK)
Signals: SigRec 0x00000100, SigWait 0x00000100
Stack: 0x58310004 - 0x5831fffc, pointer @ 0x5831fdc0 (Cookie OK)
ppp-serial.device (Waiting)
Stack: 0x58286004 - 0x58295ffc, pointer @ 0x58295ec0 (Cookie OK)
Signals: SigRec 0xdc000000, SigWait 0x00000100
Stack: 0x56021004 - 0x56030ffc, pointer @ 0x56030ea0 (Cookie OK)
Hollywood wait task (Waiting)
Stack: 0x5680f004 - 0x5681effc, pointer @ 0x5681ef10 (Cookie OK)
flipclock (Waiting)
Stack: 0x54af3000 - 0x54b33020, pointer @ 0x54b32680 (Cookie OK)
Signals: SigRec 0x7c801000, SigWait 0x00000100
TCP/IP Superserver [TCP/IP Superserver] (Waiting)
Stack: 0x5833c004 - 0x5834bffc, pointer @ 0x5834ba00 (Cookie OK)
Signals: SigRec 0xd0000080, SigWait 0x00000100
AmigaInput_usb_task (Waiting)
Stack: 0x523b7004 - 0x523c6ffc, pointer @ 0x523c6ec0 (Cookie OK)
AmigaInput Dispatcher (Waiting)
Stack: 0x50c9e000 - 0x50ca2000, pointer @ 0x50ca1f20 (Cookie OK)
Stack: 0x52737004 - 0x5282bffc, pointer @ 0x5282beb0 (Cookie OK)
ContextMenus [] (Waiting)
Stack: 0x560fa004 - 0x56109ffc, pointer @ 0x56109c50 (Cookie OK)
Stack: 0x58358004 - 0x58367ffc, pointer @ 0x58367de0 (Cookie OK)
Signals: SigRec 0xf8003000, SigWait 0x00000100
Stack: 0x58c2b000 - 0x58c2bfa0, pointer @ 0x58c2bf10 (Cookie OK)
ScreenBlankerEngine (Waiting)
Stack: 0x56177004 - 0x56186ffc, pointer @ 0x56186be0 (Cookie OK)
Signals: SigRec 0xd8001000, SigWait 0x00000000
« IPrefs » (Waiting)
Stack: 0x58c7d004 - 0x58c8cffc, pointer @ 0x58c8c530 (Cookie OK)
Signals: SigRec 0x0000f000, SigWait 0x20000100
hub.usbfd (Waiting)
Stack: 0x5fd9b004 - 0x5fda2ffc, pointer @ 0x5fda2f00 (Cookie OK)
datatypes.library (Waiting)
Stack: 0x58aaf004 - 0x58abeffc, pointer @ 0x58abef10 (Cookie OK)
Hollywood requester task (Waiting)
Stack: 0x554d8004 - 0x554e7ffc, pointer @ 0x554e7f30 (Cookie OK)
ASYNCWB (Waiting)
Stack: 0x56205004 - 0x56214ffc, pointer @ 0x56214e70 (Cookie OK)
RAWBInfo (Waiting)
Stack: 0x561ac004 - 0x561bbffc, pointer @ 0x561bbec0 (Cookie OK)
DefIcons (Waiting)
Stack: 0x561f1004 - 0x56200ffc, pointer @ 0x56200dc0 (Cookie OK)
ConClip (Waiting)
Stack: 0x58252004 - 0x58261ffc, pointer @ 0x58261eb0 (Cookie OK)
TCP/IP Log (Waiting)
Stack: 0x58374004 - 0x58383ffc, pointer @ 0x58383f00 (Cookie OK)
USB stack Process (Waiting)
Stack: 0x5896a004 - 0x58979ffc, pointer @ 0x58979ee0 (Cookie OK)
DST watcher (Waiting)
Stack: 0x58bcb004 - 0x58bdaffc, pointer @ 0x58bdaf20 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x5fd83004 - 0x5fd8affc, pointer @ 0x5fd8af00 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x5fd8f004 - 0x5fd96ffc, pointer @ 0x5fd96f00 (Cookie OK)
Handy (Crashed)
Stack: 0x523cb004 - 0x523e3ffc, pointer @ 0x523e3dc0 (Cookie OK)
Signals: SigRec 0x00000020, SigWait 0x00000000
State: Process (Crashed)
ramlib.support (Waiting)
Stack: 0x58daf004 - 0x58dc7ffc, pointer @ 0x58dc7f00 (Cookie OK)
Signals: SigRec 0x80005000, SigWait 0x00000100
dos_signal_server (Waiting)
Stack: 0x5ff26004 - 0x5ff27ffc, pointer @ 0x5ff27f10 (Cookie OK)
Signals: SigRec 0x0000e000, SigWait 0x00000000
Picasso96 (Waiting)
Stack: 0x58ca1004 - 0x58cb0ffc, pointer @ 0x58cb0da0 (Cookie OK)
dos_appdir_server (Waiting)
Stack: 0x5ff2c004 - 0x5ff2dffc, pointer @ 0x5ff2dd40 (Cookie OK)
idle.task (Ready)
Stack: 0x5ff89000 - 0x5ff8a000, pointer @ 0x5ff89fd0 (Cookie OK)
State: Task (Ready)
This if you start Handy but not selecting any game, but it crash even selecting one ... however the program will be open in a secondarian screen but then nothing happen ...
The crashes seems related to SetPatch that it may not work under AmigaOS 4.1 altrough AFAIK it worked well under AmigaOS 4.0
samo79
Post by samo79 »
AminetRadio 4.1 doesn't work anymore with AmigaOS 4.1 Update 3, it was more or less ok under Update 2 (altrough there were some skippable crashes from time to time expecially at startup and other small DSIs during the use)
http://amigazeux.net/anr/
Now it always crash at startup and doesn't start at all (after DSI we have an ISI one!), this time problem seems related to latest and native guigfx.library (OS4)
Crash log for task "AmiNetRadio"
Crash occured in module guigfx.library at address 0x6F765E6C
Register dump:
0: 01A9B3BC 557F3FB0 00000000 00000000 02050FC1 80001001 00000000 00000080
8: 557F39F8 5FED0000 80808080 00000000 24422044 00000000 56529FFC 56518004
16: 15A2F401 02270000 8000000F 8000000E 8000000D FFFFFFFF 00000000 8000000B
24: 80000000 020A97C4 5FED0000 5FED0000 01A9B0A8 558C0000 00000001 5FED0000
0: nan 0 0 0
4: 0 5.8 71.8 0
8: 0 4.5036e+15 4.5036e+15 0
12: 1 72 0 -5.05923e-321
16: 1.32625e-315 0 0 0
24: 4.94066e-324 0 1.08752e-311 -1.20307e+36
28: 0 1.35808e-312 8.8275e-311 -0.234375
Condition (cr) : 0x28422042
Instruction Pointer (ip) : 0x6F765E6C
Xtended Exception (xer) : 0x00000006
Link (lr) : 0x6F765E54
DSI Status (dsisr) : 0x00000000
Data Address (dar) : 0x00000058
DATA: 55B0D770 00000003 0000001D 00000000 FFFFFFFF FFD50001 55779000 FFFFFFFF
ADDR: 557F44C4 568EEC0D 557F42C0 00000000 55801B44 557F419C 021BD7F6 557F3D40
FPU0: 0 0 0 0
FPU4: 0 0 0 0
Symbol info:
Instruction pointer 0x6F765E6C belongs to module "guigfx.library" (PowerPC)
Symbol: GGFX_Init + 0x300 in section 1 offset 0x00001E4C
Stack trace:
GGFX_Init()+0x300 (section 1 @ 0x1e4c)
PPC disassembly:
6f765e64: 3d205fed lis r9,24557
6f765e68: 90c10010 stw r6,16(r1)
*6f765e6c: 81830058 lwz r12,88(r3)
6f765e70: 9069f23c stw r3,-3524(r9)
6f765e74: 7d8903a6 mtctr r12
System information:
CPU
CPU speed: 799 MHz
FSB speed: 133 MHz
Extensions:
Machine
Memory: 1048576 KB
Extensions: bus.pci
Expansion buses
PCI/AGP
Libraries
0x5890f68c: guigfx.library V20.0
0x55b0d770: render.library V30.0 (Legacy)
0x55b2d624: asyncio.library V50.3
0x5891d670: mathieeesingbas.library V52.1
0x55d90530: Dtpic.mui V20.201
0x5692699c: muimaster.library V20.2328
0x55d778a8: Separator.docky V53.2
0x56755a20: arexx.class V53.3
0x565c3020: requester.class V53.18
0x56755980: bitmap.image V53.9
0x56755840: slider.gadget V53.12
0x56755700: getfont.gadget V53.8
0x567555c0: getfile.gadget V53.10
0x56755200: space.gadget V53.6
0x56755480: integer.gadget V53.10
0x567473f8: clicktab.gadget V53.38
0x567490e8: screenblanker.library V53.3
0x567552a0: penmap.image V53.5
0x57258f50: checkbox.gadget V53.9
0x5fc981c8: listbrowser.gadget V53.49
0x5721b290: string.gadget V53.16
0x57258eb0: scroller.gadget V53.11
0x5891d568: cs4281.audio V5.5
0x5890e3a4: device.audio V6.2
0x58cf9694: filesave.audio V6.3
0x5819ecb4: asl.library V53.45
0x587109a0: jpeg.datatype V53.5
0x5817e1a8: emulation.library V41.446
0x586c8de0: mathieeedoubbas.library V52.1
0x5874e5d4: usergroup.library V4.30
0x5840f320: bsdsocket.library V4.292
0x5855b83c: textclip.library V52.2
0x58856b04: xpkmaster.library V5.2
0x58902a5c: xadmaster.library V13.1
0x589ac868: usbhidgate.library V52.2
0x58b88e30: window.class V53.42
0x58ce4158: popupmenu.class V53.2
0x58acae78: layout.gadget V53.19
0x58ce4060: bevel.image V53.6
0x58b8a674: picture.datatype V53.6
0x58751cae: rexxsyslib.library V45.7 (Legacy)
Devices
0x589acd54: diskimage.device V52.75
Tasks
Stack: 0x566e5004 - 0x566f4ffc, pointer @ 0x566f4a80 (Cookie OK)
USB stack (Waiting)
hid.usbfd (Ready)
Stack: 0x5887e004 - 0x58885ffc, pointer @ 0x58885ee0 (Cookie OK)
hid.usbfd (Waiting)
Stack: 0x5888a004 - 0x58891ffc, pointer @ 0x58891ee0 (Cookie OK)
HID Mouse (Waiting)
Stack: 0x5885e004 - 0x5886dffc, pointer @ 0x5886df20 (Cookie OK)
Stack: 0x5883e004 - 0x5884dffc, pointer @ 0x5884df20 (Cookie OK)
DH0 (Waiting)
Stack: 0x59294004 - 0x5929bffc, pointer @ 0x5929bea0 (Cookie OK)
ICD0 (Waiting)
Stack: 0x58512004 - 0x58521ffc, pointer @ 0x58521f20 (Cookie OK)
ICD1 (Waiting)
Stack: 0x585a2004 - 0x585b1ffc, pointer @ 0x585b1f20 (Cookie OK)
USB0 (Waiting)
Stack: 0x58936004 - 0x58945ffc, pointer @ 0x58945ee0 (Cookie OK)
RAM (Waiting)
DH1 (Waiting)
DH2 (Waiting)
CD0 (Waiting)
MainUSB0 (Waiting)
Stack: 0x58922004 - 0x58931ffc, pointer @ 0x58931eb0 (Cookie OK)
MainIPC0 (Waiting)
Stack: 0x587ca004 - 0x587d9ffc, pointer @ 0x587d9eb0 (Cookie OK)
hid.usbfd (Waiting)
Stack: 0x58872004 - 0x58879ffc, pointer @ 0x58879ee0 (Cookie OK)
hid.usbfd (Waiting)
pager (Waiting)
ENV (Ready)
IDF3 (Ready)
Stack: 0x586cd004 - 0x586dcffc, pointer @ 0x586dced0 (Cookie OK)
IDF2 (Ready)
Stack: 0x5867c004 - 0x5868bffc, pointer @ 0x5868bed0 (Cookie OK)
IDF1 (Ready)
Stack: 0x5862f004 - 0x5863effc, pointer @ 0x5863eed0 (Cookie OK)
IDF0 (Ready)
Stack: 0x585ef004 - 0x585feffc, pointer @ 0x585feed0 (Cookie OK)
MassStorage Device Task (Ready)
Signals: SigRec 0xf3009000, SigWait 0x10000000
State: Task (Ready)
IPC0 (Waiting)
Stack: 0x587e6004 - 0x587f5ffc, pointer @ 0x587f5ee0 (Cookie OK)
URL (Waiting)
Stack: 0x5841b004 - 0x58495ffc, pointer @ 0x58491a90 (Cookie OK)
CON (Waiting)
Stack: 0x55769004 - 0x55778ffc, pointer @ 0x55778de0 (Cookie OK)
CON (Waiting)
Stack: 0x57181004 - 0x57190ffc, pointer @ 0x57190de0 (Cookie OK)
CON (Waiting)
Stack: 0x56504004 - 0x56513ffc, pointer @ 0x56513de0 (Cookie OK)
CON (Waiting)
Stack: 0x55cfa004 - 0x55d09ffc, pointer @ 0x55d09de0 (Cookie OK)
CON (Waiting)
Stack: 0x565f3004 - 0x56602ffc, pointer @ 0x56602de0 (Cookie OK)
CON (Waiting)
Stack: 0x5667d004 - 0x5668cffc, pointer @ 0x5668cde0 (Cookie OK)
CON (Waiting)
Stack: 0x56711004 - 0x56720ffc, pointer @ 0x56720de0 (Cookie OK)
CON (Waiting)
Stack: 0x56776004 - 0x56785ffc, pointer @ 0x56785de0 (Cookie OK)
CON (Waiting)
Stack: 0x567fc004 - 0x5680bffc, pointer @ 0x5680bde0 (Cookie OK)
AUDIO (Waiting)
CON (Waiting)
RAW (Waiting)
CON (Waiting)
Stack: 0x581ee004 - 0x581fdffc, pointer @ 0x581fdf50 (Cookie OK)
Stack: 0x584e3004 - 0x584f6ffc, pointer @ 0x584f6c30 (Cookie OK)
Stack: 0x58573004 - 0x58586ffc, pointer @ 0x58586c30 (Cookie OK)
Stack: 0x585cf004 - 0x585e2ffc, pointer @ 0x585e2c30 (Cookie OK)
Stack: 0x5860f004 - 0x58622ffc, pointer @ 0x58622c30 (Cookie OK)
Stack: 0x5865c004 - 0x5866fffc, pointer @ 0x5866fc30 (Cookie OK)
Stack: 0x586a9004 - 0x586bcffc, pointer @ 0x586bcc30 (Cookie OK)
Stack: 0x586f9004 - 0x5870cffc, pointer @ 0x5870cc30 (Cookie OK)
TEXTCLIP (Waiting)
Stack: 0x583f3004 - 0x58402ffc, pointer @ 0x58402eb0 (Cookie OK)
Stack: 0x5726b000 - 0x57273000, pointer @ 0x57272f30 (Cookie OK)
State: Task (Ready)
Stack: 0x5823e004 - 0x5824dffc, pointer @ 0x5824dea0 (Cookie OK)
Stack: 0x56a25004 - 0x56a34ffc, pointer @ 0x56a34f40 (Cookie OK)
ramlib (Waiting)
Stack: 0x55cc6004 - 0x55cd5ffc, pointer @ 0x55cd5f40 (Cookie OK)
Stack: 0x55c6e004 - 0x55c7dffc, pointer @ 0x55c7dd70 (Cookie OK)
Stack: 0x569f9004 - 0x56a08ffc, pointer @ 0x56a08db0 (Cookie OK)
Stack: 0x5660f004 - 0x5662effc, pointer @ 0x5662e370 (Cookie OK)
AmiDock (Ready)
Stack: 0x56818004 - 0x56827ffc, pointer @ 0x56827930 (Cookie OK)
Stack: 0x55653000 - 0x5565b000, pointer @ 0x5565afd0 (Cookie OK)
State: Task (Ready)
TCP/IP Control (Ready)
Signals: SigRec 0xf8009080, SigWait 0x40000100
screenblanker.library timing dispatcher (Waiting)
Stack: 0x56699004 - 0x566a8ffc, pointer @ 0x566a8ea0 (Cookie OK)
Stack: 0x58276004 - 0x58285ffc, pointer @ 0x58285ec0 (Cookie OK)
Stack: 0x56731004 - 0x56740ffc, pointer @ 0x56740be0 (Cookie OK)
Signals: SigRec 0xd8001000, SigWait 0x00000100
AmiSystemRestore (Waiting)
Stack: 0x55d3a004 - 0x55d49ffc, pointer @ 0x55d49920 (Cookie OK)
Signals: SigRec 0xfc000000, SigWait 0x00000100
Stack: 0x566ad004 - 0x566bcffc, pointer @ 0x566bcc50 (Cookie OK)
Signals: SigRec 0xe0001000, SigWait 0x00000100
ASYNCWB (Waiting)
Stack: 0x567a6004 - 0x567b5ffc, pointer @ 0x567b5e70 (Cookie OK)
Background CLI [HD:Utilità/AmiSystemRestore/AmiSystemRestore] (Waiting)
Stack: 0x55afb004 - 0x55b0affc, pointer @ 0x55b0a8b0 (Cookie OK)
RAWBInfo (Waiting)
Stack: 0x5675a004 - 0x56769ffc, pointer @ 0x56769ec0 (Cookie OK)
DefIcons (Waiting)
Stack: 0x56792004 - 0x567a1ffc, pointer @ 0x567a1dc0 (Cookie OK)
Stack: 0x58c6d004 - 0x58c7cffc, pointer @ 0x58c7c530 (Cookie OK)
ConClip (Waiting)
Stack: 0x5832c004 - 0x5833bffc, pointer @ 0x5833ba00 (Cookie OK)
Stack: 0x58966004 - 0x58975ffc, pointer @ 0x58975ee0 (Cookie OK)
Stack: 0x58aab004 - 0x58abaffc, pointer @ 0x58abaf10 (Cookie OK)
hub.usbfd (Waiting)
hub.usbfd (Waiting)
hub.usbfd (Waiting)
AmiNetRadio (Crashed)
Stack: 0x56518004 - 0x56527ffc, pointer @ 0x557f3fb0 (Cookie OK)
Picasso96 (Waiting)
dos_appdir_server (Ready)
Stack: 0x5ff2c004 - 0x5ff2dffc, pointer @ 0x5ff2dcc0 (Cookie OK)
idle.task (Ready)
State: Task (Ready)
Before try eventually plz check the various deps required, you need also the classes "busy.mcc" and the "hotkeystring.mcc"
All deps required from the readme are:
MUI 3.8+
render.library v30+
guigfx.library v19+
mpega.library v2+
NList.mcc
busy.mcc
hotkeystring.mcc
samo79
Re: Compatibility list
Post by samo79 »
WipeOut 2097
Link for WipeOut 2097 Demo
http://aminet.net/package/game/demo/WipeOut_2097_Demo
There are serious problem with this game when i run it on my Sam Flex 800 with Radeon 9250 (it start ok in general but it freeze always after a while during the playing or just showing the demo) and sometimes you may have some random DSI/ISI crash
However this game runs pretty stable if i play it on my AmigaOne G3 800 (Radeon 9200 SE), no freeze at all and no crash
About settings i disable on both machines all the options that may create problems (according to the WipeOut guide described on the WarpOS emu 16.41 archive)
http://os4depot.net/index.php?function= ... posemu.lha
In short the problems are:
- Freeze during game (on Sam Flex 800 only)
- AlphaBlending bug in Warp3D so you have a big issue with some texture that are not rendered at all, you will see black box instead (this bug is present on both machine and it is surely a Radeon driver issue)
- No CD audio working, detail below:
This problem lies within cdplayer.library... It uses the SCSI command "PLAY AUDIO TRACK INDEX" for playing audio tracks, which isn't supported anymore by most ATAPI drives. I made a patch for cdplayer.library to use "READ TOC" and "PLAY AUDIO MSF" instead, but I'm waiting for permission from Patrick Hess (the original author) before releasing the altered library.
http://www.amigaworld.net/modules/newbb ... r=0#618139
salass00
Post by salass00 »
samo79 wrote: - No CD audio working, detail below:
http://www.a500.org/downloads/libraries ... _7z.readme
http://www.amigans.net/modules/xforum/v ... mpost66588
samo79
Post by samo79 »
@salass00
Awesome !
I will try it soon, stay tuned and thanks a lot :D
samo79
Post by samo79 »
@salass00
Tryed but sadly music still not work in game :|
I checked "CD Audio" from the preferences of WipeOut before starting the game so the title of the track are showed in game, but i can hear only sound effects but not the music from the CD (i have the WipeOut CD inserted in my DVD device of course)
I try to start that audio track directly with MultiView and they are working fine even without using your new cdplayer.library ...
If you have any test for me plz tell me, i will glad to help you in betatest this ;)
