AmiUpdate?
daveyw
AmiUpdate?
Post by daveyw »
My apologies if this is OT - AmiUpdate is distributed with OS 4.1 so I'm guessing this OK to post here - but is anyone else having problems with AmiUpdate?
It doesn't seem to be working for me anymore. The log reads a number of failures.
AmiUpdate 2.43 (29.12.2016) Part of the AmiUpdate suite
Log opened on 12-5-2018 at 12:43:26
12:43:26 Program started
12:43:26 Started system scan
12:43:26   Found host machine as: X5020
12:43:26   Synchronising with server: 'www.amiupdate.net'...
12:43:26     Requesting HTTP header file from server...
12:43:26     Trying to connect to: www.amiupdate.net on port: 80
12:44:41       Failed
12:44:41      Failed to establish connection to: www.amiupdate.net error: Connection to the server failed
12:44:41       Failed to receive HTTP header file...
12:44:41       HTTPFetch error: Transferring the file was not possible due to a previous error
12:44:41   Synchronising with server: 'update.amigaos.net'...
12:44:41     Requesting HTTP header file from server...
12:44:42     Trying to connect to: www2.hyperion-entertainment.com on port: 80
12:44:42       Connected
12:44:42       Received HTTP header file...
12:44:42       Basic Authorisation required for this update
12:44:42       User and Pass found in sitelist
12:44:42       Authorizing...
12:44:43       Connected
12:44:43       Received HTTP header file...
12:44:43         Failed to get filesize from header, Content-Length: tag missing
12:44:43     Starting file download (unknown size )
12:44:43     Trying to connect to: www2.hyperion-entertainment.com on port: 80
12:44:43       Connected
12:44:44     Synchronisation successful
12:44:45 Scan completed
12:44:45 Waiting for user input...
Re: AmiUpdate?
Even though it might seem so, there is actually (probably) only one failure:
12:44:41       Failed
The following messages are just consequences of not being able to connect to the amiupdate.net server in the first place (although the log messages could be clearer).
Later on, the word "Failed" occurs once more ("Failed to get filesize from header, Content-Length: tag missing"), but this is not really a problem, it just means the file is downloaded without knowing its size in advance. Again, this could have been worded to make it clearer that it is not preventing anything from being done.
So, the remaining question would be: Why couldn't you connect to "www.amiupdate.net" on port 80? It might be a temporary problem on the server, at your ISP, or in the DNS system, or anywhere in between. Try again later, and if still unsuccessful, try opening the same address in your browser and see if that behaves any differently. Finally, try contacting Rigo directly if still unsuccessful
Edit: I tried with the browser myself and got no reply on "www.amiupdate.net" (nor simply "amiupdate.net"). Also see this thread on Amigans: http://www.amigans.net/modules/xforum/v ... 8&forum=30
Edit 2: I just tried on my PC with FireFox, and it worked - made a redir to "amiupdate.codebench.co.uk". I thought: WTF? Then I tried again with Odyssey on the X1k, and it worked there too. So either it is really intermittent, or something was just fixed.
Try again with AmiUpdate. Or maybe it will work to edit the server prefs to go directly to "amiupdate.codebench.co.uk"?
daveyw
Re: AmiUpdate?
Post by daveyw »
Thanks, I've added amiupdate.codebench.co.uk as a server.
The Version check appears to be hardcoded, so there's quite a long wait for that to timeout before it starts checking for updates.
mritter0
Re: AmiUpdate?
Post by mritter0 »
Eroom
Re: AmiUpdate?
Post by Eroom »
daveyw wrote:Thanks, I've added amiupdate.codebench.co.uk as a server.
If you run Updates in Prefs on the first tab untick 'Perform Self-Update check when started manually' this stopped that for me.
Re: AmiUpdate?
Eroom wrote:If you run Updates in Prefs on the first tab untick 'Perform Self-Update check when started manually' this stopped that for me.
Rigo posted in the thread on Amigans.net with more info about this, and that he will solve the problem with the next version of AmiUpdate.
Follow the link given by mritter0 above.
Amigo1
Re: AmiUpdate?
Post by Amigo1 »
the address for the SDK server appears to be
amiupdate.codebench.co.uk/SdkServer
Uppercase letters matter.
