Fedora 27/28 Server PPC64
Image Image
I tried to upgrade my Fedora 26 Server PPC64 to version 28 today with the following commands:
dnf upgrade --refresh
After that I rebooted my AmigaOne.
dnf install dnf-plugin-system-upgrade
dnf system-upgrade download --releasever=27 ‐‐allowerasing
dnf system-upgrade reboot
Output after the reboot:
Starting system upgrade. This will take a while.
Fedora 27 Server PPC64 boots without any problems. Next step upgrading to Fedora 28 Server PPC64:
dnf system-upgrade download --releasever=28
Output:
Fedora 28 - ppc64 - Updates 100% [===================================================] 1.5 MB/s | 4.2 MB 00:02
Fedora 28 - ppc64 [===================================================] 1.5 MB/s | 28 MB 00:34
Last medadata expiration check: ...........
Total download size: 1.5 G
DNF will only download packages, install gpg keys, and check the transaction.
Unfortunately it doesn't boot. :-(
Fedora 27 Server PPC64 boots without any problems but unfortunately Fedora 28 Server PPC64 doesn't boot. It seems there is a systemd problem. You can upgrade to Fedora 27 but I don't recommend you to upgrade to Fedora 28 currently.
Re: Fedora 27/28 Server PPC64
Screenshot of Fedora 27 Server PPC64 with MATE 1.20.1 on an AmigaOne X5000:
I created and uploaded a Fedora 27 image today.
Download: fedora27.img.tar.gz
Download Size: 4.5 GB
MD5 Checksum: 1a818913c4a25932811af9ce9732d615
Are there any installation instructions.
I downloaded the ISO.. DDed it to a blank SSD..
Detached my working Ubuntu installation SSD and attached the Fedora SSD
Booted up like i boot ubuntu.. but failed... my guess is that my Bootargs point to the wrong partiton...
If there are any instructions, please let me know.. otherwise.... its tinkering again ...
Skateman wrote:Are there any installation instructions.
Have you seen any error messages?
i will take a look and report back
Cannot open root device sda1 but working on it while we speak...
FIXED :-)
Fedora up and running but no Xorg.. so commandline only for now..
Skateman wrote:FIXED :-)
Have you tried to start Xorg with ’startx’ after the login yet?
Skateman wrote: Fedora up and running but no Xorg.. so commandline only for now..
Have you tried this recipe:
http://forum.hyperion-entertainment.biz ... 864#p43302
It worked at least for Fedora 26. Have not yet tried Fedora 27 as I'm away from my machine for a while.
It is also wise to create a new user account with full privilges (or modify the defalt one by joining all the 'groups'). Without that, some system tools are not available unless you login as 'root'.
Has anyone tested whether the default mediaplayer of Fedora 27 is working with videos (MP4 etc.)? In 26 I was not able to get it to work, because of missing codecs.
