Adelielinux
TearsOfMe
Adelielinux
Post by TearsOfMe »
Have found these Linux distro.
https://adelielinux.org/about.html
Seems small and i like to now if it may works with the X1000 ?
Greetings
Thomas
Re: Adelielinux
TearsOfMe wrote:Have found these Linux distro.
Greetings
Thomas
Very interesting! It seems it based on Gentoo PPC32/PPC64. I don't know if it works on a X1000.
TearsOfMe
Re: Adelielinux
Post by TearsOfMe »
I was able to install it.
It works so far but no xserver in the image and i was not able to install one.
mechanic
Re: Adelielinux
Post by mechanic »
@TearsOfMe
Did you use the setup-xorg-base command?
It might take some fiddle-ing around as Adelie probably does not have a PA6T. Check out Alpine Linux website as Adelie (at least) is using their package manager.
TearsOfMe
Re: Adelielinux
Post by TearsOfMe »
I install it by mounting the iso and copying the files, so no install routine used and that maybe makes problems.
I get ssl errors and cannot get apk working :(
mechanic
Re: Adelielinux
Post by mechanic »
Copying files will not work.
Either the ISO needs to boot or you would need to dd an image to your HD. Sorry. :cry:
TearsOfMe
Re: Adelielinux
Post by TearsOfMe »
Boot the iso with qemu on linux and get the same problem.
Seems the dist site has problems with ssl connections.
vox
Re: Adelielinux
Post by vox »
mechanic wrote:Copying files will not work.
Is there a way to boot Linux CD installs via X1000 CFE?
I see on old AEON ubuntu CD basically a batch file is called that run the kernel and initrd.
Should some rooT=/CDROM/... initrd path be setted? Surely looking over different distros needs a different solutions, but
since amigaboot.of was made could similar LILO style boot loader be created for x1000?
