Hi all,
I don't know how to burn a CD/DVD for example an iso.
I tried AmiDVD I can't find my iso in the window "select a file.
I tried to erase a CD using "format ..." ,can't see my cd driver.
I tried using another appli the driver is not detected.
I'm a new X5000 user, and a new Amiga user too.
Thanks in advance.
Burn CD/DVD on a new X5000
outrun1978
Re: Burn CD/DVD on a new X5000
The Onboard Sata driver on the motherboard does not let you burn cds/dvds whilst we are awaiting an update. i have my cd drive linked up via a sil3512 sata controller and you should find you are able to burn a cd/dvd that way.
Thanks a lot for your answer.
My X5000 is a new computer (baught in feb. 2018).
It's a complete system (CD/DVD drive, HDD ...)
There is glue on the boards.
I suppose it's for the guarantee.
If I remove it I lose the garantee.
But it's not so important because I will not bring the computer back to the tech support (in UK - cost of transport).
I'll buy this cart.
I'll buy this cart.
I also had to detach some glue... i have changed my videocard, and added more ram.
I think the glue the components for transport.
They may have done this to help keep the cards from coming loose while in transit.AlanR wrote: There is glue on the boards.
Try contacting the vendor for clarification.
I think the glue is for the transport.
I asked them the question.
I did not have the answer regarding the guarantee.
Which video card You Have?
I have a Sapphire Radeon HD 7850. Works well, although it was a real pain to set up. I didn't buy my X5000 as a complete unit, I bought the motherboard and built it myself.AlanR wrote:I think the glue is for the transport.
is it running with both AmigaOne OS and linux?
Both. I don't use Linux very much, but it's working. Also, I get sound from the card under Linux.AlanR wrote:is it running with both AmigaOne OS and linux?
I have the Radeon R7 250 which is not supported very well on Linux. No PPC AMD drivers available.
The AmigaOS support is good!
