Right click on an tool/project icon and open Information, switch to Icon tab.
Where are: Priority, Open from, Prompt for input
items saved in the icon? I don't see them in struct DiskObject.
What does "Prompt for input" do? Open a small window for command line args when "Start from" is Shell or ARexx?
RAWBInfo extras
RAWBInfo extras
- broadblues
Re: RAWBInfo extras
They are actualy hidden tooltypes.
CLI -> Start from Shell
REXX -> Start from Rexx
DONOTPROMPT -> Prompt for input unchecked.
TOOLPRI=n priorty set to n (0 id not present)
Yes. It's essentialy the Workbench->Menu->Execute Command requeser with the command part prefilled in,.What does "Prompt for input" do? Open a small window for command line args when "Start from" is Shell or ARexx?
Re: RAWBInfo extras
Forgot about those hidden ones. Don't have my Tool Type Editor source code any more.
TOOLPRI=5
DONOTPROMPT
TOOLPRI=5
DONOTPROMPT
Re: RAWBInfo extras
There's also DONOTWAIT. I forget what RAWBInfo shows that as, but now having a WBStartUp drawer is not standard it doesn't tend to get shown and we're back to the tooltype anyway.
