OK, ready to get Linux on X5K - easiest version
amigasociety
Post by amigasociety »
OK, have a new 1TB drive ready to install in my X5K. Figured it is time to attempt a linux install.
Looking for recommendations for the easiest most user friendly version for X5K that is fairly easy to install without jumping through major hurdles.
One that has step-by-step on download, install, and setting up the early boot button to be clicked so it boots Linux instead if Amiga OS.
So what would that version be and a quicklink for me to download and do the deed.
Thank you.
TJ
*BTW, my X5K has a Radeon HD 7750 as installed by Amiga On The Lake. So need to make sure whatever version you recommend can use this card. Also I sound... any issues with particular sound cards I should know about.
AmigaOne X5000
Amiga A1222 Tabor
amigasociety
Re: OK, ready to get Linux on X5K - easiest version
I been recommended this link....
http://forum.hyperion-entertainment.biz ... =58&t=3577
Will check it out.
TJ
AmigaOne X5000
Amiga A1222 Tabor
The thread below is more clear regarding the actual installation of Linux on your HD, where the first link is more about running a Live linux from usb drive on your X5K.
http://forum.hyperion-entertainment.biz ... =58&t=3776
