Unarc and default file types
daveyw
Post by daveyw »
If you open an archive with Unarc, and double click on a compressed file, Unarc will extract the file to T: and launch Multiview to open it... provided there is a datatype for it.
Would it be possible to launch the default application through Deficons instead? It would be more flexible and useable than Multiview.
Re: Unarc and default file types
daveyw wrote:Hi,
That could lead to unintended results. If Deficons recognized the file as a diskimage it would get mounted. If Deficons recognized the file as an archive it would open a new copy of UnArc. If Deficons recognized the file as an installer file it would open the installer. Maybe that's what you want but personally I would like a prefs option to have it work the way it does now if it were changed to use DefIcons.
Not to mention what would happen if a file is recognized as an executable script, and it happens to contain "Delete SYS: all quiet force" or something ...
Scriptjester
Post by Scriptjester »
But it would be nice that the opened multiview take care of its tooltypes (I think I made a bugzilla for this a long time ago).
daveyw wrote:Hi,
There isn't really any such thing as lauching through deficons. DefIcons just provides a default icon for any given file. So what you really mean is open the file with OpenWorkbenchObject() or WBRun it's command line equivalent. That's not going to be a sensible thing to do on a temporary file extracted from and archive, many files are likely to need other support files from withn the archive, perhaps depend on new version of libraries withon that archive etc. Bad stuff wil happen for sure....
daveyw
Post by daveyw »
I really just want to view zipped media without having to extract the entire archive.
Great for pictures, I tend to view them with Multiview anyway, but most modern video codecs have no datatype.
Amigo1
Post by Amigo1 »
daveyw wrote:I really just want to view zipped media without having to extract the entire archive.
As a possible workaround you could maybe mark the "chekcmark gadget" and extract just the file you need. :-)
It should be just 3 more mouse clicks (Or one keyboard shortcut, to open the destination drawer and 2 mouse clicks to open the file..)
