I was working on something and the x5000 locked up. I rebooted it, and I get the normal boing ball animation, but everytime it boots, it states <<<< LINUX RUNNING >>>>, which it's not since it's not installed.
I tried going into the early start menu, but hitting escape doesn't take me into the menu after the animation starts. What now?
x5000 not booting
Re: x5000 not booting
Try with another keyboard for getting into the boot menu.
icbrkr wrote:I was working on something and the x5000 locked up. I rebooted it, and I get the normal boing ball animation, but everytime it boots, it states <<<< LINUX RUNNING >>>>, which it's not since it's not installed.
Guess it can't hurt. It's true, I hadn't tried using this keyboard on the boot menu before.Spectre660 wrote:Try with another keyboard for getting into the boot menu.
Hey check that out, it worked. Thanks
What keyboard should I get that supports both the boot menu and the OS?
