Console Prefs Iconification bug
If you iconify SYS:Prefs/Console, change the Workbench font and then uniconify Console prefs; the Console prefs window opens but the icon remains on the Workbench screen. If you again double-click the Console icon that is left on the Workbench screen you get a Grim Reaper. If, instead of double-clicking the icon, you iconify the Console prefs again you will have 2 Console prefs icons on the Workbench screen. Can someone confirm this and add it to an OS4.x bugzilla?
Re: Console Prefs Iconification bug
It doesn't do that (leave the icon after uniconification) in my beta installation, which probably means it has been fixed in the meantime.
I'll check it when I get a chance to reboot into a clean public system, just to make sure, unless Tony beats me to it by confirming it having been fixed.
Yes, that problem was fixed in V53.26, almost exactly a year ago. Currently at version 53.27.
