http://wiki.amigaos.net/wiki/AmigaOS_Ma ... rence#COPY
Example 2: in the explanation there is mention of 'Bakkup', this should read 'Backup'
Example 3: the command given here reads 1> COPY Work:Test TO " ", with a space between the quotation marks, whereas the documentation clearly (and explicitly) states that this should be avoided.
http://wiki.amigaos.net/wiki/AmigaOS_Ma ... COUNTLINES
The explanation given is a bit curious...
The proper explanation is found however under:
http://wiki.amigaos.net/wiki/AmigaOS_Ma ... erence#CPU
Encountered these while reading up a bit.
OldFart
Some errors encountered
X5000, stored.
Dead MicroA1
RaspBerry Pi 2B, 3B, 4B/4Gb, 4B/8Gb, 5B
OrangePi 5+ 8Gb
ACER Aspire Windows 10
Dead MicroA1
OrangePi 5+ 8Gb
Re: Some errors encountered
@OldFart
Fixed, thanks for reporting.
The Rear Window blog
