Appdir
dstastny
Appdir
Post by dstastny »
I have been testing out the newer gcc 5.4 and wrote a couple scripts to switch between compilers but am having issues with appdir. On the adtools site it says to clear appdir with
delete APPDIR:#?
I find this does not work as the actual values are stored in env: and envarc: so unless I delete those entries clearing appdir does not work. Is this proper approach to just clear out or am I missing something.
Doug
salass00
Re: Appdir
Post by salass00 »
No, constantly clearing APPDIR: is overkill when the real problem is that APPDIR: is an entry in the command path in the first place (an experiment that didn't quite work out).
The right solution is to find the "Path ADD" command in S:startup-sequence and remove APPDIR: from there and the problem should be solved permanently.
dstastny
Re: Appdir
Post by dstastny »
@salass00
Works for me!
Doug
