Shortcuts issue in color window (italian translation)
This forum is for discussion of the AmigaOS 4.x localization. This includes translation errors as well as proposals for improved translations, and other topics related to localization.
samo79
Post by samo79 »
Color window have two buttons, "accept" and "cancel" .. but in italian translation they both share the same shortcuts
_Accetta
_Annulla
That need to be fixed
Tested with AmigaOS 4.1 Final Edition (Update 1)
Rigo
Re: Shortcuts issue in color window (italian translation)
Post by Rigo »
I fail to see why you are posting this here, you should be contacting the author directly.
Simon
Isn't it the system's colorwheel.gadget that Samo is talking about? I believe he is right, I'll raise a BZ about it.
BZ # 9917 raised.
samo79
Post by samo79 »
Rigo wrote:I fail to see why you are posting this here, you should be contacting the author directly.
Isn't this the localization forum section ?
Where should i post issues related to the localizations ??
@tonyw
Thank you
BTW can you raise another BZ for this ? --> http://forum.hyperion-entertainment.biz ... =29&t=3612
This is the correct section of the forum, the problem was that it's not completely obvious from your post that the requester window was the OS one as most of the image is of a thrird party app, and the getcolor.gadget is not the most widly used, for instant recongintion.
Be more explicit in your bug descriptions for best results :-)
samo79
Post by samo79 »
Ah .. yep Andy
