Repository
caseycullen
Repository
Post by caseycullen »
I've created a software repo and uploaded a few games to it. Please test it and let me know if it works for you.
First you need to download and add the public key:
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv 548D45C5
Then, add the server to your sources.list:
sudo add-apt-repository "deb http://ppcutopia.ddns.net/repos/apt/debian fienix main"
And update:
sudo apt-get update
The visibility in Synaptic issue has been fixed.
If you get an error saying "This must be accepted explicitly before updates for this repository":
sudo apt-get --allow-releaseinfo-change update
Please let me know if you have any issues!
---Casey
Re: Repository
Hi Casey,
Great work! For which distributions can I use your repository?
caseycullen
Re: Repository
I've successfully tested on MATE PowerPC Remix and Ubuntu 16.04.
xeno74 wrote:Hi Casey,
Re: Repository
Great work. I downloaded Openarena and it runs fine. Is there a list of software available?
caseycullen
Re: Repository
Hi ace,
I think you should be able to see the list in Synaptic if you sort by Origin. For now though, the available games are (comma-delimited):
dnt, gigalomania, jvgs, openarena, xonotic
Also, ioquake3 and a Quake III install helper package are available if you have the Quake III Arena game data
ioquake3, quake3-install-pkg
I have more games built that I will package and make available when I have time.
Christian,
Could you let the X1000 and Sam users know about the repo in case any of them would be interested to try it out? I think it should work for them as well.
Thanks!
---Casey
acefnq wrote:Great work. I downloaded Openarena and it runs fine. Is there a list of software available?
Re: Repository
Thanks. very much appreciate your work and sharing.
Re: Repository
Hi Casey,
I successfully installed some games from your new repository with ubuntu MATE 16.04.3 LTS PowerPC on my AmigaOne X1000 today. It works without any problems! Well done! :-)
Screenshot of ubuntu MATE 16.04.3 LTS PowerPC with QUAKE III ARENA on my AmigaOne X1000:
Re: Repository
Hi Casey,
I have successfully installed some games from your new repository with ubuntu MATE 16.04.3 LTS PowerPC on my AmigaOne X5000. It works also on my X5000.
Screenshot of ubuntu MATE 16.04.3 LTS PowerPC with Xonotic on my AmigaOne X5000:
caseycullen
Re: Repository
I just added BRL-CAD to the ppcutopia repo. BRL-CAD is a powerful CAD system but it has a pretty steep learning-curve. There's tons of good documentation and tutorials if you're interested in learning it.
apt-get install brlcad
Below is an image of BRL-CAD running on my X5000, showing the design and render of a Soviet Mil Mi-28 attack helicopter.
Re: Repository
That just looks great!! I am looking forward to the moment my Videocard will be supported in linux as well. (R7 250)
For now its just a bummer having to choose... AmigaOS support or Linux Support... but not both :-(
Anyway! Keep up the good work!
