Is there a way to prevent Linux distros from automatically changing the "amigabootmenu_default" variable? Every time I run a Linux, this variable is changed to '2' and saved in the permanent memory, and I have to reverse it manually to '0' from U-Boot cli.
Is it somehow possible to change the bootmenu labels, and add submenus? At least the Linux-menu would necessarily need submenus as there are several distros available. As a workaround, I have scattered them to the 'massboot' subitems, but the titles are not very informative...
U-Boot questions
Re: U-Boot questions
Are you sure that Linux is changing the NV variable? That sounds almost impossible - Linux would have to have a means to do it, which it does not AFAIK.
Remember to type "saveenv" in the U-Boot command line after using "setenv" to change the setting, otherwise your change will work only for this boot.
@Roland
U-Boot seems to save the last Start option selected in the boot menu.
If you selected "Start AmigaOS" again then it should save that option for future boots.
To keep the AmigaOS option as default select command line and start from the U-Boot Shell using the run command and the variable.
Example
run ubuntu
of course you have to define and save the U-Boot variable first .
Example
run ubuntu
@tonyw
Actually the fw_printenv and fw_saveenv commands can read and write U-Boot variables from linux.
The correct parameters for the sdcard address need to be present in a config file.
I have compiled the commands but I can't work out the correct address so it is not working.
The fw_printenv is the command for reading the variables .again the correct address needs to be set in the config file or it
gives an error and prints what it can. fw_saveenv is actually a link to fw_printenv.
so when called as fw_saveenv the command writes the variable.
tonyw wrote:Are you sure that Linux is changing the NV variable? That sounds almost impossible - Linux would have to have a means to do it, which it does not AFAIK.
Nope, running AmigaOS again from the menu (or from Command Line with 'Boota') does not reverse the variable to '0', at least in my machine! Have tested it many times... I have to change the variable manually.Spectre660 wrote:U-Boot seems to save the last Start option selected in the boot menu.
But the opposite change (to '2') happens every time I run Linux from the boot menu.
Thanks! I have to use that trick in future...To keep the AmigaOS option as default select command line and start from the U-Boot Shell using the run command and the variable.
Example
run ubuntu
Well, in my further testings I noticed that also the second menuitem (Mophos) does change the variable to point to itself (1), so it seems to be an U-Boot feature and not a 'Linux effect', as Spectre already said. The fourth item (Boot options) does not do this, nor the first (AmigaOS). But should they do it? If you set the variable to something else than '0' and save it, and then boot AmigaOS from the menu, does it reverse to '0 ' in your machine?tonyw wrote:Are you sure that Linux is changing the NV variable? That sounds almost impossible - Linux would have to have a means to do it, which it does not AFAIK.
If I would like to set the variable to point some submenuitem in "Boot Options', how should I formulate it? I alreday tried '3:1' and '3;1', but they just opened the submenu listing, like when the variable is set to '3'.
I didn't have that variable (amigabootmenu_default) in my NV list, so I added it and set it to "5". If I type "boota" from the command line, the variable is not changed, but if I choose "Boot AmigaOS" from the menu, the variable is reset to "0". SInce I don't have any other OS installed and AmigaOS certainly does not look for that variable and can't change any variables anyway, it must be U-Boot itself.Roland wrote: Well, in my further testings I noticed that also the second menuitem (Mophos) does change the variable to point to itself (1), so it seems to be an U-Boot feature and not a 'Linux effect', as Spectre already said. The fourth item (Boot options) does not do this, nor the first (AmigaOS). But should they do it? If you set the variable to something else than '0' and save it, and then boot AmigaOS from the menu, does it reverse to '0 ' in your machine?
I suppose somebody thinks that's a good thing...
Hmm... If both you and Spectre get the same result, "Boot AmigaOS" resetting that variable, that would suggest there is something wrong with my system!? The U-Boot version of my X5000 is the same as in all resale machines, though. Is it possible somehow to check that the U-Boot code on the boot SD is valid?tonyw wrote: I didn't have that variable (amigabootmenu_default) in my NV list, so I added it and set it to "5". If I type "boota" from the command line, the variable is not changed, but if I choose "Boot AmigaOS" from the menu, the variable is reset to "0". SInce I don't have any other OS installed and AmigaOS certainly does not look for that variable and can't change any variables anyway, it must be U-Boot itself.
Are the U-Boot parameters documented somewhere ?
I could not find anything on the X5000 wiki and I would like to experiment/optimize my nvgetvar !
