Bug: Underscore not displayed correctly in paths (ASL?)
Ok, so i have seen this numerous times and wondered why is that and why does it looks o strange.
Is it a bug, or a design choice?
Here is the picture:
As you can see in the "Path:" field, the underscore is drawn beneath the "H" of "HDD".
It's just a minor graphical glitch, but it annoys me like hell.
My questions:
1) Why is that?
2) Can something be done about it?
3) Which part of the OS is causing this?
Thanks a bunch
nb: I used @trixie's great ADRipper, but i've seen it in other OS components aswell, just can't find any right now
Rigo
Re: Bug: Underscore not displayed correctly in paths (ASL?)
Post by Rigo »
The answer is to get the author of the application to add "GA_Underscore, ~0" to the string gadget tags. It's not an OS issue.
Simon
Ok, thanks a lot
trixie
Post by trixie »
@Raziel
Fixed, thanks for the report.
The Rear Window blog
