If i recall correctly, i found a thread once that the screen should go black after a couple of seconds... This never happens.
I have an Sapphire radeon r9 280x. And nothing else connected at the time. Can the usb be faulty?
setenv "massboot = usb reset ; boota"
saveenv
U-Boot 2014.04 (Oct 17 2016 - 08:22:22)
CPU0: P5020, Version: 2.0, (0x82200020)
Core: e5500, Version: 1.2, (0x80240012)
Clock Configuration:
CPU0:1995 MHz, CPU1:1995 MHz,
CCB:798 MHz,
DDR:665 MHz (1330 MT/s data rate) (Asynchronous), LBC:49.875 MHz
FMAN1: 498.750 MHz
QMAN: 399 MHz
PME: 399 MHz
L1: D-cache 32 KiB enabled
I-cache 32 KiB enabled
Reset Configuration Word (RCW):
00000000: 0c540000 00000000 1e1e0000 00000000
00000010: 44808c00 ff002000 68000000 45000000
00000020: 00000000 00000000 00000000 0003000f
00000030: a0000000 00000000 00000000 00000000
Board: CYRUS
36-bit Addressing
I2C: ready
SPI: ready
DRAM: Initializing....using SPD
Detected UDIMM KHX1600C10D3/4G
Not enough bank(chip-select) for CS0+CS1 on controller 0, interleaving disabled!
Not enough bank(chip-select) for CS0+CS1 on controller 1, interleaving disabled!
6 GiB left unmapped
8 GiB (DDR3, 64-bit, CL=9, ECC off)
DDR Controller Interleaving Mode: cache line
Local Bus Controller Registers
BR0 0xE0001001 OR0 0xFFF00010
BR1 0xE1001001 OR1 0xFFF00010
BR2 0x00000000 OR2 0x00000000
BR3 0x00000000 OR3 0x00000000
BR4 0x00000000 OR4 0x00000000
BR5 0x00000000 OR5 0x00000000
BR6 0x00000000 OR6 0x00000000
BR7 0x00000000 OR7 0x00000000
LBCR 0x40000000 LCRR 0x80010004
L2: 512 KiB enabled
Corenet Platform Cache: 2 MiB enabled
SERDES: bank 2 disabled
MMC: FSL_SDHC: 0
EEPROM: NXID v0
PCIe1: Root Complex, x4 gen2, regs @ 0xfe200000
01:00.0 - 1002:682b - Display controller
01:00.1 - 1002:aab0 - Multimedia device
PCIe1: Bus 00 - 01
PCIe2: Root Complex, x4 gen2, regs @ 0xfe201000
03:00.0 - 111d:8092 - Bridge device
04:01.0 - 111d:8092 - Bridge device
05:00.0 - 12d8:e111 - Bridge device
06:04.0 - 13f6:0111 - Multimedia device
06:05.0 - 10ec:8139 - Network controller
04:02.0 - 111d:8092 - Bridge device
04:03.0 - 111d:8092 - Bridge device
04:08.0 - 111d:8092 - Bridge device
04:10.0 - 111d:8092 - Bridge device
PCIe2: Bus 02 - 0a
PCIe3: disabled
PCIe4: disabled
Looking for VGA
PINS: 0xfc000808
videoboot: Booting PCI video card bus 1, function 0, device 0
Begin BIOS POST
End BIOS POST
Setting VESA Mode
Found required VESA mode
About to set mode 279
About to get mode
Got mode 49431 (0xc117)
OK
XSize = 1024 YSize = 768 Base =0xe0000000
mmio_base = 0x80000000
bgx = 0xad55ad55 fgx = 0x0
In: serial
Out: serial
Err: serial
SN: 116330051
UID: 4429431001910052907ca080a0800000
Errata: ▒▒▒▒▒▒
Build date: 2015/06/17 14:10:03
CRC: 1a8d9a69
SCSI: scanning bus for devices...
Found 0 device(s).
Net: Initializing Fman
MMC read: dev # 0, block # 1130, count 128 ...
Fman1: Uploading microcode version 106.1.0
Tuning PHY @ 3
Tuning PHY @ 7
FM1@DTSEC4 [PRIME], FM1@DTSEC5
MMC read: dev # 0, block # 1280, count 512 ... 512 blocks read: OK
MMC read: dev # 0, block # 65536, count 131072 ... 131072 blocks read: OK
USB0: USB EHCI 1.00
scanning bus 0 for devices... 4 USB Device(s) found
USB1: USB EHCI 1.00
scanning bus 1 for devices... 3 USB Device(s) found
SATA0 (3 Gbps)
SATA1 (3 Gbps)
Found 0 device(s).
## Starting application at 0x00200000 ...
Loading finished [########################################] 100 %
About to call loader entry at 0x7BD02020
[EHCI] *usbbase=FE210100
[EHCI] *usbbase=FE211100
graphics.library P50XX optimizations enabled
RadeonHD.card (0): RadeonHD.chip
RadeonHD (2): Graphics card name is: Radeon HD VERDE
RadeonHD (2): Identified the chipset as: VERDE
Why did you copy from the sam and not start with a clean installed Workbench/Kickstart and then re-integrate preferences and applications?Antique wrote:I booted from mass storage. I copied 4.1 from my sam to a new hd. And copied over the x5k files to the new hd. I now get the same when booting from the hd. The screen never goes black.![]()
Also, many times the monitor won't show me a picture when starting/resetting the x5k. It just states no signal. If i plug the sam440. It shows a picture every time. I have tried 3 different gfx cards.
Antique wrote:@Spectre660
I can't make a copy now. Since i didn't recieve any os4 serial code. So i can't download the iso.
That log is that when you did the serial?
This is the only monitor i have now. It worked nice with sam440/460/3x X1000 before.
I think i'm using a dos/3 fs.
@Belxjander
I copied from the sam, because i get errors trying to copy from the usb, The plan was to just copy the files from the usb over to the hd using the sam. But that did not work. So i copied over the normal files. And copied the X5k files from the usb, The kickstart drawer. I once managed to get to the black screen. But this was using a 5450 with ddr3 ram. I do not think this is supported on os4.
That's the GFX card that I am using on most of my machines. Cheap and nasty, but I don't do games and it's fine for other stuff.Antique wrote:But this was using a 5450 with ddr3 ram. I do not think this is supported on os4.
