Disabling Startup Sound?
AndyGarton
Is there a way to do this please? I mean the one that happens when the AmigaOS 4.1 FE splash screen is being shown, not the second one which plays when the desktop appears (I've disabled that in prefs).
Re: Disabling Startup Sound?
Try editing System:Kickstart/Kicklayout and put a ; semicolon in front of MODULE Kickstart/bootsound.kmod, and save then reboot.
edit: Oops!
edit: Oops!
A semi-colon (";") would be the preferred character to comment out a line.
AndyGarton
Indeed, it seemed churlish to correct that though after such a prompt helpful response!
Even so, think of the potential future readers seeking the correct answer in this thread.
- LyleHaze
I don't do things halfway.tonyw wrote:A semi-colon (";") would be the preferred character to comment out a line.
