Fedora 26 Server PPC64
I was able to upgrade my Fedora 25 Server PPC64 to version 26 today with the following commands:
sudo dnf upgrade --refresh
sudo dnf install dnf-plugin-system-upgrade
sudo dnf system-upgrade download --refresh --releasever=26
Output:
Fedora 26 - ppc64 - Updates 100% [===================================================] 1.5 MB/s | 12 MB 00:00
Fedora 26 - ppc64 [===================================================] 1.5 MB/s | 47 MB 00:30
Last medadata expiration check: ...........
sudo dnf system-upgrade reboot
Output after the reboot:
Starting system upgrade. This will take a while.
After the update I tested it for a while. Sound and 3D acceleration works. I tested it with Compiz, Neverball, and Glxgears. Network access also works without any problems. Unfortunately Firefox doesn't work and Midori has problems with wrong colors.
Re: Fedora 26 Server PPC64
Link to the official Fedora 26 PowerPC website: Architectures/PowerPC/26
Screenshot of Fedora 26 Server PPC64 with the RC4 of kernel 4.14:
There are some problems with PolicyKit1. The libmozjs-17.0.so is responsible for the PolicyKit1 issues. Alex patched the libmozjs-17.0.so. Fedora 26 works really better with Alex's patched libmozjs-17.0.so.
Download: libmozjs-17.0.so
Installation:
# mv /usr/lib64/libmozjs-17.0.so /usr/lib64/libmozjs-17.0.so.bak
# cp libmozjs-17.0.so /usr/lib64
Screenshot of Fedora 26 Server PPC64 with the stable longterm kernel 4.9.54 on an AmigaOne X1000:
I am creating a Fedora 26 Server PPC64 image for the upload. :-)
dd if=/dev/zero of=fedora26.img bs=1024k count=9000
mkfs ext4 -F fedora26.img
mount  -o loop -t ext4 fedora26.img /mnt
cd /media/christian/c87fa493-6827-4072-af93-7175972daf64
rsync --stats --progress --numeric-ids -axAhHSP . /mnt
cd
umount /mnt
gzip fedora26.img
I created with dd an img of my fedora 26 Server PPC64 installation today.
Be aware, that fedora is experimental and isn't supported. fedora 26 is alpha software! It's only for testing and tinkering!
Download: fedora26.img.gz
I suggest to download the fedora 26 img with a right click on the link and then with the menu point "Save target as" or something like that.
Please note: There isn't a graphical login. You have to login via a console (virtual terminal). After that you can start Xorg with startx.
Users:
root (password "amigaone")
fedora 26 Server PPC64 on an AmigaOne X5000:
fedora 26 Server PPC64 on an AmigaOne X1000:
BTW, I created a small fedora download webpage today: http://www.supertuxkart-amiga.de/amiga/fedora.html
If you want a graphical login then please try the command sudo systemctl isolate graphical.target. You change to the graphical runlevel with this command. In lightdm you can choose one of some desktops and login. If it works then you can set up it as the default runlevel with sudo systemctl set-default graphical.target. After that please reboot for testing.
TearsOfMe
Post by TearsOfMe »
Hi.
I upgrade Fedora25 with your Fedora26.img and have a problem that Xorg now will not work.
Only fbdev works now. Teseted with latest kernel and with 4.9.
Downgrade Xorg-server to 25 but no luck.
AmigaOneX1000 with radeonhd6450.
TearsOfMe wrote:Hi.
Hi TearsOfMe,
Have you seen any error messages? Did you start Xorg with 'startx'?
I wish you happy holidays and a happy new year.
TearsOfMe
Post by TearsOfMe »
Added screenshot. Used startx. Xorg -configure give me the same seg fault error.
