Outline Font OT_BaseLine data not found
blmara
Post by blmara »
in my program I use Text() replacement for font kerning and outputting Unicode glyphs. Fonts are handled through diskfont.library/bullet.library routines. As the bullet.library doesn't seem to support underlining (and for other reasons) I need to find the baseline of font. The query seems to fail, while other type of query works ok. Here is VBCC/GCC compilable example:
/* outline font baseline test */
/* gcc  testolfont.c -o ram:test -lauto */
#include <stdio.h>
#include <proto/exec.h>
#include <proto/diskfont.h>
#include <diskfont/diskfonttag.h>
#include <diskfont/oterrors.h>
STRPTR fname = "Dejavu Sans Mono.font";
uint32 devdpi = 72<<16|72;
uint32 ptheight = 16;
//struct DiskfontIFace *IDiskfont;
int main()
	struct OutlineFont *olfont;
	olfont = IDiskfont->OpenOutlineFont(fname,NULL,OFF_OPEN);
	if (olfont)
		if (!IDiskfont->ESetInfo(&olfont->olf_EEngine,OT_DeviceDPI,devdpi,OT_PointHeight,ptheight << 16,TAG_END))
			printf("Font %s point height %lu opened successfully!\n",fname,ptheight);
				int Ascend, Descend;
 				ULONG BaseLine,NumGlyphs;
 				if (!IDiskfont->EObtainInfo(&olfont->olf_EEngine,OT_BaseLine, &BaseLine, TAG_END) && ((BaseLine & 0xffff0000) != 0))
 					Ascend = BaseLine >> 16;
 					Descend = BaseLine & 0xffff;
					printf("Font ascend %d, descend %d\n",Ascend,Descend);
				else
					printf("Couldn't get font baseline data!\n");
				if (!IDiskfont->EObtainInfo(&olfont->olf_EEngine, OT_NumGlyphs, &NumGlyphs, TAG_END))
					printf("The font contains %lu glyphs\n", NumGlyphs);
				else
					printf("The font engine does not support OT_NumGlyphs\n");
			IDiskfont->CloseOutlineFont(olfont,NULL);
	return(1);
The OT_BaseLine seems to return always 0, but the font seems to have ascender/descender data as show by TypeManager. Why? The example is modified from diskfont/diskfonttag.h.
Marko
Marko
javierdlr
Re: Outline Font OT_BaseLine data not found
Post by javierdlr »
Can you try this:
 struct TextAttr ta = {0};
 struct TextFont *font;
 ta.ta_Name = fname;
 ta.ta_YSize = ptheight;
 if( (font=IDiskfont->OpenDiskFont(&ta)) )
  printf("Font: '%s' %d (%sproportional)\n",font->tf_Message.mn_Node.ln_Name,
           font->tf_YSize,(font->tf_Flags&FPF_PROPORTIONAL)? "":"no ");
  printf("Baseline=%d\n",font->tf_Baseline);
 IGraphics->CloseFont(font);
I get:
#test
Font: 'DejaVu Sans Mono.font' 20 (no proportional)
Baseline=14
Hope it helps somehow.
salass00
Post by salass00 »
TypeManager uses OT_BaseLine but also has fallback code which calculates the baseline based on the highest ascend and descend values of the glyphs if OT_BaseLine fails so I guess OT_BaseLine is not something that can be relied upon for all fonts.
blmara
Post by blmara »
javierdlr wrote:Can you try this:
 ta.ta_Name = fname;
I get:
#test
Baseline=14
So, the OpenDiskFont() finds the baseline somehow while the code example based on include file comment doesn't. How does it do that?
Marko
Marko
salass00
Post by salass00 »
This should be about the same method that diskfont.library uses to calculate the font->tf_Baseline value:
https://gist.github.com/salass00/c5ed9b ... 02f9d8b5b3
blmara
Post by blmara »
salass00 wrote:This should be about the same method that diskfont.library uses to calculate the font->tf_Baseline value:
Thanks! So, if I understood correctly, in this method every glyph in the current character set (256 chars) is looked at and the baseline is calculated based on their metrics. In my program I use internally UCS-4 character coding and the utility.library functions to be able to import UTF-8 coded strings from (MusicXML) files. In theory, such a string can contain characters that are from multiple character sets. This probably means that one would need to go through all glyphs of the font to be sure of the baseline? Do you know why the OT_BaseLine doesn't seem to provide this information?
Marko
Marko
salass00
Post by salass00 »
I'm adding this here just in case if someone finds this thread via a search engine (like I just did).
Rather than using tags to get outline font information, like OT_BaseLine, OT_IsFixed, OT_YSizeFacter, OT_SpaceWidth with EObtainInfo(), which won't work ever, these tags should be looked for in outlinefont->olf_OTagList.
The easiest way to do this is using the IUtility->GetTagData() function.
blmara
Post by blmara »
@salass00
Thanks, will adapt my code to that information. Could this be added to the SDK unless it's there already?
Marko
Edit: odd enough, with the routine described below the EObtainInfo() results in a reasonable value with Dejavu Sans.font while the GetTagData results a OT_BaseLine of 0. Other tags return a non-zero value. Using AmigaOS4.1FinalUpd, diskfont.library 53.9
uint32 FindDocFontBaseline(APTR doc,SGFONTNR fontnr)
	struct DocFontNode *dfnode;
	uint32 asc,desc,bas,bline;
	bline = 0;
	if (fontnr > 0)
		for (dfnode = FIRST_NODE(S_GetAttr(doc,SGT_FontList));NEXT_NODE(dfnode);dfnode = NEXT_NODE(dfnode))
			if (dfnode->Fontnr == fontnr)
				bline = dfnode->Font.bline;
				if (!IDiskfont->EObtainInfo(&dfnode->Font.olfont->olf_EEngine, OT_BaseLine, &bas, TAG_END))
					if ((bas & 0xffff0000) != 0)
						asc = bas >> 16;
						desc = bas & 0xffff;
						bline = (dfnode->Ptheight * dfnode->Pisz / dfnode->Posz) * asc / (asc+desc);
					D(bug("Success in FindDocFontBaseline/EObtainInfo!\n"));
				else
					D(bug("Using  FindDocFontBaseline/GetTagList method!\n"));
					bas = IUtility->GetTagData(OT_BaseLine,0,dfnode->Font.olfont->olf_OTagList);
					asc = bas >> 16;
				D(bug("GetTagData baseline %ld\n",IUtility->GetTagData(OT_BaseLine,0,dfnode->Font.olfont->olf_OTagList)));
				D(bug("GetTagData ysizefactor %ld\n",IUtility->GetTagData(OT_YSizeFactor,0,dfnode->Font.olfont->olf_OTagList)));
				D(bug("GetTagData spacewidth  %ld\n",IUtility->GetTagData(OT_SpaceWidth,0,dfnode->Font.olfont->olf_OTagList)));
				D(bug("FindDocFontBaseline bline %ld\n",bline));
				break;
    return(bline);
Marko
Marko
salass00
Post by salass00 »
@blmara
I was wrong about OT_BaseLine. Apparently it is one of the tags which should be used with EObtainInfo().
Quoting from the <diskfont/diskfonttag.h> header:
/* ? OT_BaseLine returns the ascender in the upper 16 bit
* and the descender in the lower 16 bit so you can compute
* the baseline faster if the font engine supports this tag.
* Even if the tag is supported you must check whether the
* result contains a zero ascender.
* Example:
* int Ascend, Descend;
* ULONG BaseLine;
* if (!ObtainInfo(engineHandle, OT_BaseLine, &BaseLine, TAG_END) &&
* ((BaseLine & 0xffff0000) != 0))
* Ascend = BaseLine >> 16;
* Descend = BaseLine & 0xffff;
* BaseLinePosInPixels =
* (LineHeightInPixels * Ascend) / (Ascend + Descend);
* else
* // assume the baseline from ascender and
* // descender values of a series of rendered glyphs as before
