Hi, is there a way to load/install linux kernel on an SD (1GB) and and using SAM460ex internal SD unit then booting it?
TIA
Install (and boot) from internal SAM460 SD unit
Re: Install (and boot) from internal SAM460 SD unit
every thing is the same as using a USB thumb drive.
Just format the SDcard or SDcard partition to ext2 or ext3 and copy the kernel and 460.dtb to it .
If you only have one partition on the SDcard then the pt variable in the Amigados scripts for Uboot would be
nvsetvar pt="usb 0:1"
you can download the script examples here .
https://drive.google.com/open?id=0BxoZd ... 3QtVkl4SFk
javierdlr wrote:Hi, is there a way to load/install linux kernel on an SD (1GB) and and using SAM460ex internal SD unit then booting it?
TIA
- javierdlr
Spectre660 wrote:every thing is the same as using a USB thumb drive.
OK THX will ty it ASAP and post here results. THX again
