Kernel 4.14
Kernel 4.14
Hi Everyone,
The merge window is open for the future kernel 4.14. A lot of source code has been added for the kernel 4.14 to the Linux git.
Here is the first alpha for the X5000 and X1000.
Download: vmlinux-4.14-alpha1-AmigaOne_X1000_X5000.tar.gz
Re: Kernel 4.14
Here is the second alpha with the first PowerPC updates for the X5000 and X1000.
Download: vmlinux-4.14-alpha2-AmigaOne_X1000_X5000.tar.gz
Re: Kernel 4.14
I released the alpha3 for the X5000 and X1000 today. The hardware 3D acceleration works again on the AmigaOne X5000 because I have removed the problematic instruction emulation patch.
Download: vmlinux-4.14-alpha3-AmigaOne_X1000_X5000.tar.gz
Screenshot of ubuntu MATE 16.04.3 LTS PowerPC with the alpha3 of kernel 4.14 with access to my OSX server:
Re: Kernel 4.14
Paul Mackerras has fixed the problem with the emulation of the dcbz instruction in the alignment interrupt handler. Therefore the hardware 3D acceleration works again on the AmigaOne X5000.
I compiled the alpha4 with his patch for the AmigaOne X5000 today. Additionally I compiled the alpha4 for the X1000. The X1000 isn't affected by this issue so it doesn't need this patch. Both kernels are included in the package below.
Further news:
Download: vmlinux-4.14-alpha4-AmigaOne_X1000_X5000.tar.gz
Re: Kernel 4.14
I compiled the alpha5 yesterday.
It works with ubuntu MATE 16.04.3 LTS and with the MATE PowerPC Remix 2017. Unfortunately lightdm doesn't work anymore on Debian Sid.
Error messages:
[+0.09s] DEBUG: Loading configuration from /usr/share/lightdm/lightdm.conf.d/01_debian.conf
[+0.09s] DEBUG: Loading configuration from /etc/lightdm/lightdm.conf
[+0.09s] DEBUG: Using D-Bus name org.freedesktop.DisplayManager
[+0.33s] DEBUG: Registered seat module xlocal
[+0.33s] DEBUG: Registered seat module xremote
[+0.33s] DEBUG: Registered seat module unity
[+0.33s] DEBUG: Registered seat module surfaceflinger
[+0.33s] DEBUG: Adding default seat
[+0.33s] DEBUG: Seat: Starting
[+0.33s] DEBUG: Seat: Creating greeter session
[+0.59s] DEBUG: Seat: Setting XDG_SEAT=seat0
[+0.59s] DEBUG: Seat: Creating display server of type x
[+0.59s] DEBUG: Seat: Starting local X display
[+0.59s] DEBUG: Could not run plymouth --ping: Failed to execute child process “plymouth” (No such file or directory)
[+0.59s] DEBUG: Using VT 7
[+0.59s] DEBUG: DisplayServer x-0: Logging to /var/log/lightdm/x-0.log
[+0.59s] DEBUG: DisplayServer x-0: Writing X server authority to /var/run/lightdm/root/:0
[+0.59s] DEBUG: DisplayServer x-0: Launching X Server
[+0.59s] DEBUG: Launching process 3781: /usr/bin/Xorg :0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
[+0.59s] DEBUG: DisplayServer x-0: Waiting for ready signal from X server :0
[+0.59s] DEBUG: Acquired bus name org.freedesktop.DisplayManager
[+0.59s] DEBUG: Registering seat with bus path /org/freedesktop/DisplayManager/Seat0
[+5.71s] DEBUG: Got signal 10 from process 3781
[+5.71s] DEBUG: DisplayServer x-0: Got signal from X server :0
[+5.71s] DEBUG: DisplayServer x-0: Connecting to XServer :0
[+5.71s] DEBUG: Seat: Display server ready, starting session authentication
[+5.71s] DEBUG: Session: Setting XDG_VTNR=7
[+5.71s] DEBUG: Session pid=3918: Started with service 'lightdm-greeter', username 'lightdm'
[+6.35s] DEBUG: Session pid=3918: Authentication complete with return value 0: Success
[+6.35s] DEBUG: Seat: Session authenticated, running command
[+6.35s] DEBUG: Session pid=3918: Setting XDG_VTNR=7
[+6.35s] DEBUG: Session pid=3918: Running command /usr/sbin/lightdm-kde-greeter
[+6.36s] DEBUG: Session pid=3918: Logging to /var/log/lightdm/x-0-greeter.log
[+6.88s] DEBUG: Activating VT 7
[+6.88s] WARNING: Error using VT_WAITACTIVE 7 on /dev/console: No such device or address
[+15.16s] DEBUG: Session pid=3918: Greeter connected version=1.8.5
[+78.29s] DEBUG: Got signal 15 from process 4397
[+78.29s] DEBUG: Caught Terminated signal, shutting down
[+78.29s] DEBUG: Stopping display manager
[+78.29s] DEBUG: Seat: Stopping
[+78.29s] DEBUG: Seat: Stopping display server
[+78.29s] DEBUG: Sending signal 15 to process 3781
[+78.29s] DEBUG: Seat: Stopping session
[+78.29s] DEBUG: Session pid=3918: Sending SIGTERM
[+78.35s] DEBUG: Session pid=3918: Greeter closed communication channel
[+78.35s] DEBUG: Session pid=3918: Exited with return value 15
[+78.35s] DEBUG: Seat: Session stopped
Lightdm works with the alpha4 without any problems.
Maybe we have a new bug somewhere in the patches from Sep 13, 11:48AM till 15 Sep, 1:12PM.
Additionally the PCSX emulator doesn't work anymore with the new alpha5. If I start a game with the XVideo driver then I get the following error messages:
The program 'pcsx' received an X Window System error.
This probably reflects a bug in the program.
The error was 'BadAccess (attempt to access private resource denied)'.
  (Details: serial 49 error_code 10 request_code 130 minor_code 1)
  (Note to programmers: normally, X errors are reported asynchronously;
   that is, you will receive the error a while after causing it.
   To debug your program, run it with the --sync command line
   option to change this behavior. You can then get a meaningful
   backtrace from your debugger if you break on the gdk_x_error() function.)
I don't have these problems with the alpha4.
Please test it. Maybe some other X apps don't work anymore.
Download: vmlinux-4.14-alpha5-AmigaOne_X1000_X5000.tar.gz
This bug affects the X1000 and the X5000.
Re: Kernel 4.14
I was able to remove the fbdev updates. Maybe these patches are the problem.
git revert 503f04530fec97f93673ae9048b5312cc4455cfe -m 1
[master 0736a7d] Revert "Merge tag 'fbdev-v4.14' of git://github.com/bzolnier/linux"
After that I compiled the alpha6 without the fbdev updates.
Unfortunately, it didn't solve the problem.
Rgds,
Re: Kernel 4.14
I updated lightdm on Debian Sid but without any success.
Error messages:
[+1.93s] DEBUG: Using VT 7
[+1.93s] DEBUG: Seat seat0: Starting local X display on VT 7
[+1.93s] DEBUG: DisplayServer x-0: Logging to /var/log/lightdm/x-0.log
[+1.93s] DEBUG: DisplayServer x-0: Writing X server authority to /var/run/lightdm/root/:0
[+1.93s] DEBUG: DisplayServer x-0: Launching X Server
[+1.93s] DEBUG: Launching process 3702: /usr/bin/Xorg :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
[+1.93s] DEBUG: DisplayServer x-0: Waiting for ready signal from X server :0
[+1.93s] DEBUG: Acquired bus name org.freedesktop.DisplayManager
[+1.93s] DEBUG: Registering seat with bus path /org/freedesktop/DisplayManager/Seat0
[+2.55s] DEBUG: Loading users from org.freedesktop.Accounts
[+2.55s] DEBUG: User /org/freedesktop/Accounts/User1000 added
[+6.17s] DEBUG: Got signal 10 from process 3702
[+6.17s] DEBUG: DisplayServer x-0: Got signal from X server :0
[+6.17s] DEBUG: DisplayServer x-0: Connecting to XServer :0
[+6.17s] DEBUG: Seat seat0: Display server ready, starting session authentication
[+6.17s] DEBUG: Session pid=3863: Started with service 'lightdm-greeter', username 'lightdm'
[+6.40s] DEBUG: Session pid=3863: Authentication complete with return value 0: Success
[+6.40s] DEBUG: Seat seat0: Session authenticated, running command
[+6.40s] DEBUG: Session pid=3863: Running command /usr/sbin/lightdm-kde-greeter
[+6.40s] DEBUG: Creating shared data directory /var/lib/lightdm/data/lightdm
[+6.40s] DEBUG: Session pid=3863: Logging to /var/log/lightdm/seat0-greeter.log
[+6.62s] DEBUG: Activating VT 7
[+6.62s] WARNING: Error using VT_WAITACTIVE 7 on /dev/tty0: No such device or address
[+6.62s] DEBUG: Activating ConsoleKit session d4f561b636716de50fe4740051265e84-1505587303.5374-678774364
[+6.63s] WARNING: Error activating ConsoleKit session: GDBus.Error:org.freedesktop.DBus.GLib.UnmappedError.CkVtMonitorError.Code0: Session is already active
[+14.25s] DEBUG: Greeter connected version=1.8.5 resettable=false
Re: Kernel 4.14
I updated Mesa to version 17.2.1/LLVM 5.0.0 on Debian Sid yesterday. Unfortunately Lightdm doesn't work again but I can start Xorg (MATE) with startx on VT1 without any problems.
There is another problem. I tried to compile the RC1 today but I got some error messages:
 CHK     scripts/mod/devicetable-offsets.h
  CHK     include/generated/compile.h
  CALL    arch/powerpc/kernel/systbl_chk.sh
  CALL    arch/powerpc/kernel/prom_init_check.sh
  CC      arch/powerpc/kvm/../../../virt/kvm/eventfd.o
arch/powerpc/kvm/../../../virt/kvm/eventfd.c: In function 'kvm_irqfd':
arch/powerpc/kvm/../../../virt/kvm/eventfd.c:568:19: error: 'KVM_MAX_IRQ_ROUTES' undeclared (first use in this function)
  if (args->gsi >= KVM_MAX_IRQ_ROUTES)
arch/powerpc/kvm/../../../virt/kvm/eventfd.c:568:19: note: each undeclared identifier is reported only once for each function it appears in
make[1]: *** [arch/powerpc/kvm/../../../virt/kvm/eventfd.o] Error 1
make: *** [arch/powerpc/kvm] Error 2
I had to remove the kvm support. After that it compiled. The kernel developers know the problem. Link: [mainline][bisected 36ae3c0] Build fail at virt/kvm/eventfd.c:568
Re: Kernel 4.14
I released the RC1 for the X5000 and X1000 today.
Download: vmlinux-4.14-rc1-AmigaOne_X1000_X5000.tar.gz
The kernel developers have removed some firmwares from the Linux Git. Maybe some firmwares are missing for some graphics cards. I restored these firmwares and after that I compiled an extra kernel for testing for your X5000. (uImage-4.14-4870)
git revert df85b2d767aad90fd2746f993fcd66dd322768f8
Output:
[master f7615c9] Revert "firmware: Restore support for built-in firmware"
git revert b38923a068c10fc36ca8f596d650d095ce390b85 -m 1
Output:
[master d9ae2e8] Revert "Merge tag 'firmware_removal-4.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core"
create mode 100644 firmware/radeon/RV710_me.bin.ihex
create mode 100644 firmware/radeon/RV710_pfp.bin.ihex
create mode 100644 firmware/radeon/RV730_me.bin.ihex
create mode 100644 firmware/radeon/RV730_pfp.bin.ihex
create mode 100644 firmware/radeon/RV770_me.bin.ihex
create mode 100644 firmware/radeon/RV770_pfp.bin.ihex
Re: Kernel 4.14
@Tom
Please Please Please test the RC1 on your X1000.
