I've currently run into what is for me a very weird boot issue that I would love to resolve...
I can boot my sam440-flex, it will show uboot as per normal without issues.
I can use *any* hdd with the dvd-rom drive hooked up..
If I use my existing system hdd, kickstart will load normally.
The issue is when Kickstart has finished the module loading procedure and there is a message about launching...
I have left my machine to boot (from both AOS4.1FE CD and Existing HDD...) for a whole day twice now...
I have NOT seen the boot image or anything beyond the Kickstart loading progress bar text which has completed loading.
What possible issues would affect this point of the loading process????
I also recently purchased a new pair of HDDs considering HDD errors as a possible point of failure...
but in attempting to boot with one of the new drives the AOS4.1FE CD showed the same issue as t HDD installed system.
Just what the hell is happening here?
Not quite sure how this was solved as I completely stripped the machine down and re-installed device by device until everything was present again...
loose connection or something else?,
Not exactly sure but the machine is fully functional again,
And I am cloning my entire 500GB drive pair over to a fresh pair of 1TB disks just so I have 3 compelete system copies now.
[SOLVED] Kickstart loads and nothing further?
Re: [SOLVED] Kickstart loads and nothing further?
Have you tried without the dvd rom on the chain?
Maybe it doesn't work together with your hdds?
I started by stripping and testing individual SATA devices, after pulling everything usb except the keyboard/mouse dongle...Raziel wrote:Have you tried without the dvd rom on the chain?
no change regardless of sata device any which way...
unplugging and re-seating the PCI cards (except graphics) seemed to have solved the issue.
Which let me boot my original system disk, and re-wiring the drive bays actually stripped a few uboot error messages too.
,mainly to do with read failures... since I had one 500GB drive in the top hdd bay with a sata cable between it and the next drive... so it was actually making the 500GB drives both ridiculously hot
