New X5000 owner - USB issues
I've only had my X5000 for 6 days. For 5 days my MS wireless mouse frequently isn't recognized after power-on, reset or warm reboot. The mouse almost always fails after the first power-on of the day. My MS wired keyboard occasionally fails to be recognized by not nearly as often as the mouse. Here is what transpired when I first turned on my X5000 this morning:
X5000 powered on.
Booting complete & mouse pointer only moves vertically.
Warm reboot with keyboard.
Mouse works but keyboard fails to activate.
Used mouse to warm reboot (reboot command in a WB menu).
Keyboard still not activated.
Hit reset button.
Network started but neither YAM or Odyssey find a network.
USB HID keyboard crashes (see crashlog at the bottom of this post)
Hit reset button.
Neither keyboard or mouse work.
Powered down and back on.
Mouse & keyboard finally work.
Plug in USB flash drive but blank Usb widow pops up & drive inaccesable (even after several replugins).
FInally, everything works.
I did notice something that might be important. I use a network adapter that is powered from a USB connection. It has has an LED power indicator. On my X1000, the adapter power indicator comes on during CFE boot and stays on all the way through OS4 booting. On my X5000, the adapter power indicator comes on during UBOOT boot and goes of when UBOOT is completed. It doesn't come back on until OS4 boot is nearly finished. Personally, I don't see why the USB power should be shut off once it is on. It's possible that powering USB off and on is causing some of the USB peripheral recognition to fail.
I've seen posts where others have this mouse/keyboard failure. Is it being worked on and is there a workaround?
HID crashlog:
Crash log for task "HID Keyboard"
Generated by GrimReaper 53.19
Crash occured in module hid.usbfd at address 0x7FDD0D7C
Alert number: 0x80000003
Register dump:
   0: 00000001 6A637EA0 00000002 6A896390 6F8FAA30 0002D030 022D4E14 022D4E84
   8: 6B0E01D0 6A89641C 00000000 00000000 33953593 0000000D 6A65FDA4 6A673040
  16: 02380000 EFFD8190 6AC80000 6F9D6100 6FF19A90 6A89A104 6AC82C00 6A896390
  24: 6A896390 6A637EE8 6A89BD74 80000001 00000400 6FF612C4 6AC80000 6A896390
   0:     -1.1886e+148     -1.1886e+148     -1.1886e+148     -1.1886e+148
   4:     -1.1886e+148     -1.1886e+148     -1.1886e+148     -1.1886e+148
   8:     -1.1886e+148     -1.1886e+148     -1.1886e+148     -1.1886e+148
  12:     -1.1886e+148     -1.1886e+148     -1.1886e+148     -1.1886e+148
  16:     -1.1886e+148     -1.1886e+148     -1.1886e+148     -1.1886e+148
  20:     -1.1886e+148     -1.1886e+148     -1.1886e+148     -1.1886e+148
  24:     -1.1886e+148     -1.1886e+148     -1.1886e+148     -1.1886e+148
  28:     -1.1886e+148     -1.1886e+148     -1.1886e+148     -1.1886e+148
FPSCR (Floating Point Status and Control Register): 0xDEADBEEF
           Machine State (msr) : 0x0002D030
                Condition (cr) : 0x6F8B61BC
      Instruction Pointer (ip) : 0x7FDD0D7C
       Xtended Exception (xer) : 0x6A49D028
                   Count (ctr) : 0x6FF6A4D0
                     Link (lr) : 0x7FBFD920
            DSI Status (dsisr) : 0x6A49CDE0
            Data Address (dar) : 0x019B1708
680x0 emulated registers:
FPU0:                0                0                0                0
FPU4:                0                0                0                0
Symbol info:
Instruction pointer 0x7FDD0D7C belongs to module "hid.usbfd" (HUNK/Kickstart)
Stack trace:
    module DEVS:USB/fd/hid.usbfd at 0x7FDD0D7C (section 5 @ 0x6D58)
    module DEVS:USB/fd/hid.usbfd at 0x7FDD25A8 (section 5 @ 0x8584)
    module DEVS:USB/fd/hid.usbfd at 0x7FDD2C44 (section 5 @ 0x8C20)
    native kernel module dos.library.kmod+0x000255c8
    native kernel module kernel+0x0003f660
    native kernel module kernel+0x0003f6a8
PPC disassembly:
 7fdd0d74: 7c7f1b78   mr                r31,r3
 7fdd0d78: 816302dc   lwz               r11,732(r3)
*7fdd0d7c: 980b001e   stb               r0,30(r11)
 7fdd0d80: 38000017   li                r0,23
 7fdd0d84: b00b001c   sth               r0,28(r11)
System information:
CPU
 Model: Freescale P50XX (E5500 core) V1.2
 CPU speed: 1995 MHz
 FSB speed: 798 MHz
 Extensions:
Machine
 Machine name: AmigaOne X5000/20
 Memory: 2097152 KB
 Extensions: bus.pci bus.pcie
Expansion buses
 PCI/AGP
  00:00.0 Vendor 0x1957 Device 0x0421
  01:00.0 Vendor 0x1002 Device 0x683F
   Range 0: 80000000 - 90000000 (PREF.MEM)
   Range 2: 90000000 - 90040000 (MEM)
   Range 4: 00001000 - 00001100 (IO)
  01:00.1 Vendor 0x1002 Device 0xAAB0
   Range 0: 90040000 - 90044000 (MEM)
  02:00.0 Vendor 0x1957 Device 0x0421
  03:00.0 Vendor 0x111D Device 0x8092
  04:01.0 Vendor 0x111D Device 0x8092
  04:02.0 Vendor 0x111D Device 0x8092
  04:03.0 Vendor 0x111D Device 0x8092
  04:08.0 Vendor 0x111D Device 0x8092
  04:10.0 Vendor 0x111D Device 0x8092
  05:00.0 Vendor 0x12D8 Device 0xE111
  06:04.0 Vendor 0x1095 Device 0x3512
   Range 0: 00001000 - 00001008 (IO)
   Range 1: 00001008 - 00001010 (IO)
   Range 2: 00001010 - 00001018 (IO)
   Range 3: 00001018 - 00001020 (IO)
   Range 4: 00001020 - 00001030 (IO)
  06:05.0 Vendor 0x13F6 Device 0x0111
   Range 0: 00001100 - FFFF1200 (IO)
  07:00.0 Vendor 0x10EC Device 0x8168
   Range 0: 00002000 - 00002100 (IO)
   Range 2: A0100000 - A0101000 (MEM)
   Range 4: A0104000 - A0108000 (PREF.MEM)
Libraries
 0x022d7cb2: exec.library V53.89
 0x6feceb88: cgxvideo.library V42.1
 0x68c82cd4: amigaguide.datatype V53.6
 0x68e63098: Separator.docky V53.2
 0x6890dcd4: amigaguide.library V53.8
 0x68d99f28: filesave.audio V6.5
 0x68e63a98: DiskLED.docky V53.1
 0x68a555c8: dopus.library V23.0
 0x691b7f40: getfont.gadget V53.9
 0x691b7ea0: fuelgauge.gadget V53.8
 0x691b7d60: getfile.gadget V53.12
 0x68d999fc: virtual.gadget V53.6
 0x68d99d08: clicktab.gadget V53.44
 0x691b7b80: 8svx.datatype V53.2
 0x6ac5a9e8: sound.datatype V53.29
 0x691b7a40: slider.gadget V53.15
 0x691b79a0: arexx.class V53.5
 0x691b77c0: checkbox.gadget V53.9
 0x69cd9d04: device.audio V6.2
 0x68f17208: screenblanker.library V53.6
 0x692b9974: asl.library V53.49
 0x69cc6aa8: cmi8738.audio V5.18
 0x6ff616b8: listbrowser.gadget V53.62
 0x69cf2990: scroller.gadget V53.14
 0x6a66eeb4: xpkmaster.library V5.2
 0x6a186a5c: xadmaster.library V13.1
 0x6a66e720: mathieeedoubbas.library V52.1
 0x6a18b190: requester.class V53.18
 0x6a4ea050: space.gadget V53.6
 0x6a673ca8: chooser.gadget V53.21
 0x6a4ea190: penmap.image V53.5
 0x6a4ea230: bitmap.image V53.9
 0x6a4ea2d0: integer.gadget V53.12
 0x6a688020: string.gadget V53.20
 0x6f9d74cc: textclip.library V53.1
 0x6a673648: usbhidgate.library V53.3
 0x6f96333c: hid.usbfd V53.12
 0x6ac82680: button.gadget V53.21
 0x6ac82720: glyph.image V53.3
 0x6a8e69a0: window.class V54.7
 0x6a8806f8: popupmenu.class V53.2
 0x6ac23a58: popupmenu.library V53.11
 0x6ac825e0: label.image V53.13
 0x6ac82540: drawlist.image V53.3
 0x6feced68: layout.gadget V54.2
 0x6a880600: bevel.image V53.6
 0x6ac82180: ilbm.datatype V53.3
 0x6ac820e0: png.datatype V53.10
 0x6aeb7264: picture.datatype V53.7
 0x6af1d56c: ft2.library V53.2
 0x6aeb6600: Picasso96API.library V54.18
 0x6ff1dc4c: workbench.library V53.53
 0x6ac50710: gadtools.library V53.7
 0x6af119d8: timezone.library V53.8
 0x6ac263f8: application.library V53.12
 0x6ffa8c8c: commodities.library V53.7
 0x6af2ad40: datatypes.library V54.6
 0x6b0aa8cc: icon.library V53.16
 0x6ff14dc0: z.library V53.5
 0x6b0df748: version.library V53.15
 0x6b0e0a60: iffparse.library V53.1
 0x6ffb95cc: locale.library V54.2
 0x6ff1841c: diskfont.library V53.9
 0x6f9634a8: petunia.library V53.6
 0x6febb220: dos.library V53.158
 0x6ff14454: usbprivate.library V53.14
 0x6ff1523c: massstorage.usbfd V53.83
 0x6ff1430c: hub.usbfd V53.10
 0x6ff151a8: bootkeyboard.usbfd V52.3
 0x6ff15128: bootmouse.usbfd V53.3
 0x6ff15028: mounter.library V53.19
 0x6ff1407c: usbresource.library V53.14
 0x6ff9e518: hunk.library V53.4
 0x6fecee64: elf.library V53.27
 0x6ff6a4d0: intuition.library V54.26
 0x6ff87530: keymap.library V53.9
 0x6ff612c4: nonvolatile.library V54.2
 0x6fed1100: cybergraphics.library V43.0
 0x6ff9d4a0: RadeonHD.chip V2.22
 0x6ffa3420: graphics.library V54.226
 0x6ff9f320: layers.library V54.12
 0x6ff58150: rtg.library V54.90
 0x6ff9d324: PCIGraphics.card V53.15
 0x6ffaa258: newlib.library V53.36
 0x6ff9c1ac: utility.library V54.1
 0x6ffa8398: expansion.library V53.1
 0x6a11b91e: rexxsyslib.library V53.4 (Legacy)
Devices
 0x689fb284: clipboard.device V53.3
 0x69ada834: ahi.device V6.6
 0x69dc60a4: diskimage.device V53.4
 0x6ff9cd10: usbsys.device V53.14
 0x6fe5d024: p5020sata.device V54.69
 0x6ff9e870: ehci.usbhcd V53.24
 0x6ff9e7d0: ohci.usbhcd V53.21
 0x6ff9e730: uhci.usbhcd V53.13
 0x6ff9c848: console.device V53.99
 0x6ff613f0: ramdrive.device V52.6
 0x6ff8777c: input.device V53.5
 0x6ff18024: keyboard.device V53.12
 0x6ff61050: timer.device V53.2
Tasks
 rhd_gc (Waiting)
  Stack: 0x6fec6000 - 0x6fece000, pointer @ 0x6fecdf70 (Cookie OK)
  Signals: SigRec 0x80000001, SigWait 0x00000000
  State: Task (Waiting)
 DepthToFront (Waiting)
  Stack: 0x69085004 - 0x69094ffc, pointer @ 0x690949e0 (Cookie OK)
  State: Process (Waiting)
 ClickToFront (Waiting)
  Stack: 0x69101004 - 0x69110ffc, pointer @ 0x691109f0 (Cookie OK)
  Signals: SigRec 0xe000d000, SigWait 0x00000100
 input.device (Waiting)
  Stack: 0x6fea6000 - 0x6feb6000, pointer @ 0x6feb5f00 (Cookie OK)
 SFS DosList handler (Waiting)
  Stack: 0x6d3e6004 - 0x6d3edffc, pointer @ 0x6d3edf20 (Cookie OK)
 USB stack (Waiting)
  Stack: 0x6fec2000 - 0x6fec6000, pointer @ 0x6fec5f20 (Cookie OK)
 EHCI Controller Task Unit 1 (Waiting)
  Stack: 0x6f9d9000 - 0x6f9e1000, pointer @ 0x6f9e0f10 (Cookie OK)
  Signals: SigRec 0xbe009000, SigWait 0x00000000
 EHCI Controller Task Unit 0 (Waiting)
  Stack: 0x6fa19000 - 0x6fa21000, pointer @ 0x6fa20f10 (Cookie OK)
 p5020sata.device Port 1 (Waiting)
  Stack: 0x6fc32000 - 0x6fc40a60, pointer @ 0x6fc408d0 (Cookie OK)
  Signals: SigRec 0xd000f000, SigWait 0x08000000
 p5020sata.device Port 0 (Waiting)
  Stack: 0x6fe4e000 - 0x6fe5ca60, pointer @ 0x6fe5c8d0 (Cookie OK)
 DH3/SmartFilesystem 1.293  (Waiting)
  Stack: 0x6d3d6004 - 0x6d3ddffc, pointer @ 0x6d3ddea0 (Cookie OK)
 DH7/SmartFilesystem 1.293  (Waiting)
  Stack: 0x6b0c5004 - 0x6b0ccffc, pointer @ 0x6b0ccea0 (Cookie OK)
 DH1/NGFileSystem 54.34  (Waiting)
  Stack: 0x6e6b1004 - 0x6e6b8ffc, pointer @ 0x6e6b8d60 (Cookie OK)
  Signals: SigRec 0xf0000000, SigWait 0x00000100
 DH4/NGFileSystem 54.34  (Waiting)
  Stack: 0x6d3ba004 - 0x6d3c1ffc, pointer @ 0x6d3c1d60 (Cookie OK)
 DH2/NGFileSystem 54.34  (Waiting)
  Stack: 0x6ddc0004 - 0x6ddc7ffc, pointer @ 0x6ddc7d60 (Cookie OK)
 DH5/NGFileSystem 54.34  (Waiting)
  Stack: 0x6c2ca004 - 0x6c2d1ffc, pointer @ 0x6c2d1d60 (Cookie OK)
 DH0/NGFileSystem 54.34  (Waiting)
  Stack: 0x6f878004 - 0x6f87fffc, pointer @ 0x6f87fd60 (Cookie OK)
 DH6/NGFileSystem 54.34  (Waiting)
  Stack: 0x6ef87004 - 0x6ef8effc, pointer @ 0x6ef8ed60 (Cookie OK)
 hid.usbfd (Waiting)
  Stack: 0x6a69e004 - 0x6a6a5ffc, pointer @ 0x6a6a5e90 (Cookie OK)
  Signals: SigRec 0xe0000000, SigWait 0x00000100
 HID Mouse (Waiting)
  Stack: 0x6a598004 - 0x6a5a7ffc, pointer @ 0x6a5a7f20 (Cookie OK)
  Stack: 0x6d4ef004 - 0x6d4f6ffc, pointer @ 0x6d4f6eb0 (Cookie OK)
  Signals: SigRec 0xe0000100, SigWait 0x00000000
  Stack: 0x6b1de004 - 0x6b1e5ffc, pointer @ 0x6b1e5eb0 (Cookie OK)
 ICD1/CDFileSystem 53.4  (Waiting)
  Stack: 0x69c5b004 - 0x69c6affc, pointer @ 0x69c6af30 (Cookie OK)
 ICD0/CDFileSystem 53.4  (Waiting)
  Stack: 0x69d7d004 - 0x69d8cffc, pointer @ 0x69d8cf30 (Cookie OK)
 hid.usbfd (Waiting)
  Stack: 0x6f901004 - 0x6f908ffc, pointer @ 0x6f908e90 (Cookie OK)
 HID Consumer (Waiting)
  Stack: 0x6a5fc004 - 0x6a60bffc, pointer @ 0x6a60bf20 (Cookie OK)
 reaper.task (Waiting)
  Stack: 0x6b03d004 - 0x6b044ffc, pointer @ 0x6b044e50 (Cookie OK)
 RAM/ram-handler 53.172  (Waiting)
  Stack: 0x6af41004 - 0x6af44ffc, pointer @ 0x6af44d40 (Cookie OK)
 MainIPC0/CrossDOSFileSystem 53.11  (Waiting)
  Stack: 0x69b02004 - 0x69b11ffc, pointer @ 0x69b11eb0 (Cookie OK)
  Signals: SigRec 0x40000100, SigWait 0x00000000
 hid.usbfd (Waiting)
  Stack: 0x6a6c2004 - 0x6a6c9ffc, pointer @ 0x6a6c9e90 (Cookie OK)
 HID Keyboard (Waiting)
  Stack: 0x6a5bc004 - 0x6a5cbffc, pointer @ 0x6a5cbf10 (Cookie OK)
  Signals: SigRec 0x90001000, SigWait 0x00000000
  Stack: 0x6a584004 - 0x6a593ffc, pointer @ 0x6a593f20 (Cookie OK)
  Stack: 0x6a5e8004 - 0x6a5f7ffc, pointer @ 0x6a5f7f20 (Cookie OK)
  Stack: 0x6a644004 - 0x6a653ffc, pointer @ 0x6a653f20 (Cookie OK)
 hid.usbfd (Waiting)
  Stack: 0x6a6aa004 - 0x6a6b1ffc, pointer @ 0x6a6b1e90 (Cookie OK)
 hid.usbfd (Waiting)
  Stack: 0x6a6b6004 - 0x6a6bdffc, pointer @ 0x6a6bde90 (Cookie OK)
 HID Keyboard (Crashed)
  Stack: 0x6a628004 - 0x6a637ffc, pointer @ 0x6a637ea0 (Cookie OK)
  Signals: SigRec 0x00000010, SigWait 0x00000000
  State: Process (Crashed)
 IDF1/FastFileSystem 53.2  (Waiting)
  Stack: 0x69b7b004 - 0x69b8affc, pointer @ 0x69b8aed0 (Cookie OK)
  Signals: SigRec 0xa8000100, SigWait 0x00000000
 IDF0/FastFileSystem 53.2  (Waiting)
  Stack: 0x69bc7004 - 0x69bd6ffc, pointer @ 0x69bd6ed0 (Cookie OK)
  Stack: 0x69b1e004 - 0x69b2dffc, pointer @ 0x69b2dee0 (Cookie OK)
  Signals: SigRec 0x00010100, SigWait 0x00000000
 dos_filedir_notify (Waiting)
  Stack: 0x6f8bd004 - 0x6f8c0ffc, pointer @ 0x6f8c0ad0 (Cookie OK)
  Signals: SigRec 0x40001000, SigWait 0x80000000
 USBPRT/Port-Handler 52.2  (Waiting)
  Stack: 0x69ab2004 - 0x69ac1ffc, pointer @ 0x69ac1ee0 (Cookie OK)
 URL/launch-handler 53.38  (Waiting)
  Stack: 0x69df3004 - 0x69e6dffc, pointer @ 0x69e69fb0 (Cookie OK)
 RANDOM/Random-Handler 52.1  (Waiting)
  Stack: 0x6a4bb004 - 0x6a4caffc, pointer @ 0x6a4caef0 (Cookie OK)
 CON/con-handler 53.78  (Waiting)
  Stack: 0x68f2c004 - 0x68f3bffc, pointer @ 0x68f3be20 (Cookie OK)
  Signals: SigRec 0xa0000100, SigWait 0x00000000
  Stack: 0x68d08004 - 0x68d17ffc, pointer @ 0x68d17e20 (Cookie OK)
  Stack: 0x68dc1004 - 0x68dd0ffc, pointer @ 0x68dd0e20 (Cookie OK)
  Stack: 0x68e2e004 - 0x68e3dffc, pointer @ 0x68e3de20 (Cookie OK)
  Stack: 0x68fa6004 - 0x68fb5ffc, pointer @ 0x68fb5e20 (Cookie OK)
  Stack: 0x690b1004 - 0x690c0ffc, pointer @ 0x690c0e20 (Cookie OK)
  Stack: 0x69178004 - 0x69187ffc, pointer @ 0x69187e20 (Cookie OK)
  Stack: 0x691bc004 - 0x691cbffc, pointer @ 0x691cbe20 (Cookie OK)
  Stack: 0x6925c004 - 0x6926bffc, pointer @ 0x6926be20 (Cookie OK)
 AUDIO/AHI-Handler 6.2  (Waiting)
  Stack: 0x6a554004 - 0x6a564004, pointer @ 0x6a563ed0 (Cookie OK)
 ENV/env-handler 54.5  (Waiting)
  Stack: 0x6b035004 - 0x6b038ffc, pointer @ 0x6b038ef0 (Cookie OK)
 APPDIR/appdir-handler-in-dos 53.158  (Waiting)
  Stack: 0x6afd1004 - 0x6afd8ffc, pointer @ 0x6afd8dc0 (Cookie OK)
  Stack: 0x6b061004 - 0x6b068ffc, pointer @ 0x6b068e20 (Cookie OK)
 RAW/con-handler 53.78  (Waiting)
  Stack: 0x6b085004 - 0x6b08cffc, pointer @ 0x6b08ce20 (Cookie OK)
  Stack: 0x6b0b9004 - 0x6b0c0ffc, pointer @ 0x6b0c0e20 (Cookie OK)
 dos_nbmd_process (Waiting)
  Stack: 0x6f8cd004 - 0x6f8d0ffc, pointer @ 0x6f8d0f30 (Cookie OK)
 dos_lock_handler (Waiting)
  Stack: 0x6f8d5004 - 0x6f8d8ffc, pointer @ 0x6f8d8f00 (Cookie OK)
 RexxMaster (Waiting)
  Stack: 0x6960c004 - 0x6961c004, pointer @ 0x6961bf70 (Cookie OK)
 diskimage.device unit 6 (Waiting)
  Stack: 0x69ae2004 - 0x69af5ffc, pointer @ 0x69af5c50 (Cookie OK)
 diskimage.device unit 1 (Waiting)
  Stack: 0x69b5b004 - 0x69b6effc, pointer @ 0x69b6ec50 (Cookie OK)
  Stack: 0x69b97004 - 0x69baaffc, pointer @ 0x69baac50 (Cookie OK)
  Stack: 0x69c2c004 - 0x69c3fffc, pointer @ 0x69c3fc50 (Cookie OK)
  Stack: 0x69ca7004 - 0x69cbaffc, pointer @ 0x69cbac50 (Cookie OK)
 TEXTCLIP/textclip-handler 53.1  (Waiting)
  Stack: 0x6a45e004 - 0x6a46dffc, pointer @ 0x6a46deb0 (Cookie OK)
 compose.task (Waiting)
  Stack: 0x680d6000 - 0x680de000, pointer @ 0x680ddf30 (Cookie OK)
  Signals: SigRec 0x00000021, SigWait 0x00000000
  Stack: 0x69e7e000 - 0x69e86000, pointer @ 0x69e85f30 (Cookie OK)
 Workbench (Waiting)
  Stack: 0x69a9e004 - 0x69aadffc, pointer @ 0x69aadea0 (Cookie OK)
 ScreenBlanker Library. (Waiting)
  Stack: 0x68c3a004 - 0x68c4affc, pointer @ 0x68c4af00 (Cookie OK)
  Signals: SigRec 0xb4001000, SigWait 0x00000100
 dopus_clock (Waiting)
  Stack: 0x6843d000 - 0x6843f000, pointer @ 0x6843ed10 (Cookie OK)
  Stack: 0x6aefe004 - 0x6af0dffc, pointer @ 0x6af0df40 (Cookie OK)
 ContextMenus Command Dispatcher (Waiting)
  Stack: 0x68104004 - 0x68113ffc, pointer @ 0x68113f30 (Cookie OK)
 ramlib (Waiting)
  Stack: 0x6af87004 - 0x6af9fffc, pointer @ 0x6af9ff20 (Cookie OK)
 dopus_hotkeez (Waiting)
  Stack: 0x6882a000 - 0x6882c000, pointer @ 0x6882bf20 (Cookie OK)
  Stack: 0x69a1d004 - 0x69a2cffc, pointer @ 0x69a2cf00 (Cookie OK)
  Stack: 0x699c9004 - 0x699d8ffc, pointer @ 0x699d8db0 (Cookie OK)
 RinghioServer (Waiting)
  Stack: 0x68fc2004 - 0x68fe1ffc, pointer @ 0x68fe1380 (Cookie OK)
  Signals: SigRec 0xd8001000, SigWait 0x00000000
 AmiDock (Waiting)
  Stack: 0x6929c004 - 0x692abffc, pointer @ 0x692ab920 (Cookie OK)
 hub.usbfd (Waiting)
  Stack: 0x6f999004 - 0x6f9a0ffc, pointer @ 0x6f9a0f10 (Cookie OK)
 hub.usbfd (Waiting)
  Stack: 0x6f9a5004 - 0x6f9acffc, pointer @ 0x6f9acf10 (Cookie OK)
 Docket (Waiting)
  Stack: 0x68e02004 - 0x68e11ffc, pointer @ 0x68e11c70 (Cookie OK)
  Signals: SigRec 0xe0001000, SigWait 0x00000100
 ELF Collector (Waiting)
  Stack: 0x6f847004 - 0x6f856ffc, pointer @ 0x6f856e70 (Cookie OK)
 Clock (Waiting)
  Stack: 0x68cd4004 - 0x68ce3ffc, pointer @ 0x68ce3cc0 (Cookie OK)
  Signals: SigRec 0x70009000, SigWait 0x00000100
 ScreenBlankerEngine (Waiting)
  Stack: 0x6918c004 - 0x6919bffc, pointer @ 0x6919bbf0 (Cookie OK)
  Signals: SigRec 0xd8001000, SigWait 0x00000100
 Mounter GUI (Waiting)
  Stack: 0x6a78d004 - 0x6a7a0ffc, pointer @ 0x6a7a0e10 (Cookie OK)
  Signals: SigRec 0x80007000, SigWait 0x00000000
 Background CLI [Work:Programs/Opus4/DirectoryOpus] (Waiting)
  Stack: 0x68aa2004 - 0x68b21ffc, pointer @ 0x68b21230 (Cookie OK)
  Signals: SigRec 0x5c009000, SigWait 0x00000100
 Exchange (Waiting)
  Stack: 0x69055004 - 0x69068ffc, pointer @ 0x69068d20 (Cookie OK)
 ContextMenus (Waiting)
  Stack: 0x690cd004 - 0x690dcffc, pointer @ 0x690dcc90 (Cookie OK)
 dopus_arbiter (Waiting)
  Stack: 0x68783004 - 0x68802ffc, pointer @ 0x68802ef0 (Cookie OK)
 Background CLI [waitclip] (Waiting)
  Stack: 0x68bde004 - 0x68bedffc, pointer @ 0x68bedc80 (Cookie OK)
  Signals: SigRec 0x00005000, SigWait 0x00000100
 UsbSound (Waiting)
  Stack: 0x68d24004 - 0x68d33ffc, pointer @ 0x68d33c50 (Cookie OK)
  Signals: SigRec 0xc0001000, SigWait 0x00000000
 datatypes.library (Waiting)
  Stack: 0x6a970004 - 0x6a97fffc, pointer @ 0x6a97fe30 (Cookie OK)
 SGrab (Waiting)
  Stack: 0x68e4a004 - 0x68e59ffc, pointer @ 0x68e59d20 (Cookie OK)
  Signals: SigRec 0xc0007000, SigWait 0x00000100
 AsyncWB (Waiting)
  Stack: 0x69270004 - 0x6927fffc, pointer @ 0x6927feb0 (Cookie OK)
  Signals: SigRec 0xc0001000, SigWait 0x00000100
  Stack: 0x6ac81000 - 0x6ac81fa0, pointer @ 0x6ac81f10 (Cookie OK)
 RAWBInfo (Waiting)
  Stack: 0x6920b004 - 0x6921affc, pointer @ 0x6921aec0 (Cookie OK)
 DefIcons (Waiting)
  Stack: 0x6921f004 - 0x6922effc, pointer @ 0x6922edc0 (Cookie OK)
 « IPrefs » (Waiting)
  Stack: 0x6ac13004 - 0x6ac22ffc, pointer @ 0x6ac22960 (Cookie OK)
  Signals: SigRec 0x0000f000, SigWait 0x20000100
 ConClip (Waiting)
  Stack: 0x69dd7004 - 0x69de6ffc, pointer @ 0x69de6eb0 (Cookie OK)
 USB stack Process (Waiting)
  Stack: 0x6a7b9004 - 0x6a7c8ffc, pointer @ 0x6a7c8ee0 (Cookie OK)
 MassStorage Notifier (Waiting)
  Stack: 0x6fe65000 - 0x6fe6cd00, pointer @ 0x6fe6cc70 (Cookie OK)
 DST watcher (Waiting)
  Stack: 0x6abc8004 - 0x6abd7ffc, pointer @ 0x6abd7f10 (Cookie OK)
 hub.usbfd (Waiting)
  Stack: 0x6f94d004 - 0x6f954ffc, pointer @ 0x6f954f10 (Cookie OK)
 hub.usbfd (Waiting)
  Stack: 0x6f959004 - 0x6f960ffc, pointer @ 0x6f960f10 (Cookie OK)
 Mounter Task (Waiting)
  Stack: 0x6fe6d000 - 0x6fe7ba60, pointer @ 0x6fe7b970 (Cookie OK)
  Signals: SigRec 0xb0001000, SigWait 0x00000000
 Mounter Companion Process (Waiting)
  Stack: 0x6a7a5004 - 0x6a7b4ffc, pointer @ 0x6a7b4f40 (Cookie OK)
 ramlib.support (Waiting)
  Stack: 0x6afa4004 - 0x6afbcffc, pointer @ 0x6afbcf00 (Cookie OK)
  Signals: SigRec 0x80005000, SigWait 0x00000000
 dos_signal_server (Waiting)
  Stack: 0x6f8c5004 - 0x6f8c8ffc, pointer @ 0x6f8c8f10 (Cookie OK)
  Signals: SigRec 0x0000f000, SigWait 0x00000000
 idle.task (Ready)
  Stack: 0x6ff86000 - 0x6ff87000, pointer @ 0x6ff86fc0 (Cookie OK)
  State: Task (Ready)
Re: New X5000 owner - USB issues
This is the only one that I observe.
Also happens on a Sam460ex so it probably a a U-boot thing.
Only had a Mouse issue once .
Spectre660 wrote:This is the only one that I observe.
Thanks for replying. I've tried everything I could think of to remedy the situation, with no success. I tried moving USBCtrl to different positions in the startup-sequence and switched to an alternate boot partition that is formatted with SFS2. It didn't help but when I changed partitions by changing priority for a partition, saving the changes from Media ToolBox and rebooting, I endup with 2 more HID crashes.
Try a different keyboard and mouse.
I am using a Logitech M570 Wireless Trackball and a A-Eon AmigaOne wired keyboard .
Also have a StarTech Mini USB Bluetooth 4.0 Adapter constantly connect for use under Linux .
Spectre660 wrote:Try a different keyboard and mouse.
My Microsoft wired keyboard and wireless mouse work flawlessly on SAM440 and X1000 so I don't think it's those devices that are at fault. I have an A-Eon AmigaOne wired keyboard but the letter "t" started sticking and printing two t's but I might try it anyway. This morning when I turned my system on it was the keyboard that wasn't recognized. However, I have an icon on AmiDock that runs "USBCtrl RESET" that is working well and activated my keyboard. The reset seems to be more reliable that reboting.
I made this post and included a crash log so a betatester could file a bug report and get the problem examined. In the meantime, I'll try some other input devices and set up a "reset" workaround that will work from the keyboard too.
The common problem here is U-Boot. Note that it doesn't fail with CFE on the X1k.
Unfortunately it is very difficult to get any maintenance performed on the X5k's U-Boot, since it was not done by Hyperion and we devs have no sources for it.
Personally I am using a Microsoft wired kbd and mouse on my X5k and I have no problems. The model is "Microsoft 600 Wired Desktop".
tonyw wrote:The common problem here is U-Boot. Note that it doesn't fail with CFE on the X1k.
I'm also using a "Microsoft 600 Wired Desktop" keyboard but using a "Microsoft Wireless Mouse 5000". I rummaged through a closet and found an old wired mouse which solves my problems. For whatever reason the wireless mouse causes problems that even prevent the wired keyboard from working and effect the overall X5000 operation. However, I also discovered that I can plug the wireless mouse in through one of my unpowered USB2 hubs and it seems to work fine. Two other hubs I tried had no effect which seems peculiar. For now I have 2 solutions to the problem and my system is working normally. I think someone still needs to let whoever is responsible for UBOOT know that there is a problem with some wireless mice like my Microsoft Wireless Mouse 5000. It's not a cheap mouse and works great on my X1000.
On the subject of UBOOT, I noticed in the UBOOT menus that there is an option to start MorphOS. Does MorphOS work on the X5000??
Ribdevil
Post by Ribdevil »
I have same, and other problems with keyboards in the X5000.
Tested some different keyboards and mouses, with and without cord.
The only brand that work in all models is Logitech.
Virginio
Ribdevil wrote:I have same, and other problems with keyboards in the X5000.
Virginio
I know you're trying to be helpfull but my reason for reporting stuff here is to get it fixed. As I told Tony, I have a wired mouse that works and have discovered that plugging my wireless mouse into an external hub also works. The maximum satisfaction that can be expected from an excuse is zero so I suppose I need to report this problem elsewhere in an effort to get it fixed. Other than this USB issue, I'm happy with my X5000 so far.
xenic wrote:On the subject of UBOOT, I noticed in the UBOOT menus that there is an option to start MorphOS. Does MorphOS work on the X5000??
I believe so. And it was even shown on the X5000 already in Neuss almost two years ago by the MorphOS guys, so it presumably worked on X5000 before AmigaOS did. (Disclaimer: I don't know the details about how well it works or worked in daily use, but the demo was quite impressive.)
